Was a bit expensive but worth every penny.
[ROM] Unofficial OpenELEC for MK808B+ and MXQ
Originally posted by michaelchen View Post
Using wd elements 1 TB usb3 connection plugged to my mxq and works fine.
Bit off topic, but we'll get back on track soon!
This looks like a good cheap drive and looks like it only needs usb power (1 port): http://www.amazon.co.uk/Samsung-Slim...ZRHTKQJ7X0CNQC
Tempted! Just don't have the pennies at the, but a contender together with the WD.
PatrickJB Thank you for your extensive testing and logs. I'll try to work on power/reboot thing but this is only possible if I can reproduce your issues or some other come up. Meanwhile please enjoy the release, I'm happy to hear that skin reset issue is no more.
I'm sorry if I sometimes sound harsh but I'm not a native English speaker and sometimes it's hard to find appropriate words to speak out my mind.
As for external drives, I use WD Elements - both USB-powered 2.5" and externally powered 3.5". I also have a USB-powered Seagate drive. They are all very silent!
Originally posted by kszaq View PostPatrickJB Thank you for your extensive testing and logs. I'll try to work on power/reboot thing but this is only possible if I can reproduce your issues or some other come up. Meanwhile please enjoy the release, I'm happy to hear that skin reset issue is no more.
As for storage anybody tried this: cant get link to work!!!
It looks almost like a mini home sever!
EDIT: wrong link if you didn't get the wifi drive, updated now though! I think!!
Edit 2: look for this on Amazon: " Toshiba Canvio AeroCast Wireless Portable Hard Drive 1 TB USB 3.0 "
Originally posted by PatrickJB View PostThat looks pretty good, is it quiet? I would probably get just the drive as I have several 2.5 caddies laying about, they're dirt cheap about £1.50 if that! Does that drive run from just one USB cable?
Quite like a mouseYou may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Originally posted by oceth View PostMy MXQ boots into SD card, everything works fine. Is it possible to to select if i want to boot nand or sd card?
EDIT: of couse you can boot from Nand by removing SD card. SD will work if inserted before boot.
I have two mxq all black. I was able to install openelec on both with out any trouble. On the v.10 board everything seems to work great but I finish my build and unplug it to take ie to the other room. When I plug it back up the setting I had just went back to default. On the v.03 board I just get no sounds. I have to unplug the hdmi then plug it back then I'll get sounds. I've tried with other hdmi and it does they same thing.
Originally posted by smilez View PostI have two mxq all black. I was able to install openelec on both with out any trouble. On the v.10 board everything seems to work great but I finish my build and unplug it to take ie to the other room. When I plug it back up the setting I had just went back to default. On the v.03 board I just get no sounds. I have to unplug the hdmi then plug it back then I'll get sounds. I've tried with other hdmi and it does they same thing.
Originally posted by Corsten View PostGuys, for what do you need external hard drives on mxq?
People like to transfer their own video and music library's to Hard disk so they never need their original cd/dvd/blu-ray again. Also people have emulators and have a library of roms. You can never fully rely on a stream anyway, they come and go like flies.
H MAn
There are currently 1657 users online. 0 members and 1657 guests.
