[ROM] Unofficial OpenELEC for MK808B+ and MXQ
    Originally posted by PatrickJB View Post
    Have you noticed any improvement in video quality with Jarvis? Someone here did mention they had sound sink problems with some files/streams.
    To be honest I never tested Jarvis extensively because I had issues with the HD18Q build not saving my settings, so I have reverted back to 6.0.3.1 for now, they were lost on reboot. Ksaq is aware of this and he is releasing a new version to test. Now that you have mentioned about lip sync I will watch out for it when the new build is available and report my findings.
    H MAn
      sammaz That's great to hear! Do you have a link to a thread for RetroArch addon or - even better - to a GitHub? I have noticed that the addon doesn't work with Kodi Jarvis and maybe I'lll be able to recompile it for OE 7.0.
      New builds:
      • 6.0.3.3 with Broadcom WiFi fixes and profiles.xml fir for mike77. You don't need to update from 6.0.3.2 if you don't have any of these.
      • 6.90.1 Kodi Jarvis build based OpenELEC development branch with all fixes from 6.0.3.3. In most situations you can upgrade directly from 6.0.x, after first boot wait for all addons to upgrade.
        kszaq Updated, all seems fine, a few of my Favs had to be launched from addons before the Fav link worked but other than that seems fine. Will let you all know if I have any issues with vid playback, hopefully I may notice some improvement.
          OK, a more extensive check and I don't see any problems. I don't see any improvement in vid quality but that's probably because it's pretty much all done by the amcodac and Kodi has little to do with it.
          Quoting K:
          "As for the occasional judder, it has nothing to do with Codesnake's code, it's the Amlogic decoder and implementation in Kodi. Actually Codesnake is working on a new decoder for some time and from what he says it will let us get rid of many stuttering issues when it's released."
          I take it that once CS has sorted this it will be simple for you to add?
          EDIT: I think the color depth (deep color / wide color) is working or been improved. Therefore you get a slightly smoother image and contrast it improved. Might just be my eyes though!
            I have testing the 6.90.1 what just notice is that if make some changes on the configs of the skin wean i boot that changes go back to previous looks that kodi don't save then
            the system configs it save
              I just tried to change something, just told Kodi to show weather in top left, and when I rebooted Kodi reverted to default settings! Will try and restore a backup and see if that sorts it.
              EDIT: OK. restored backup, asked Kodi to show weather and then rebooted and this time it kept my settings! Will try a few more changes to make sure it's a fix.
              EDIT 2: Err, No it's not a fix! Just switched weather display back on and Kodi reverted to defaults on reboot!
                if make changes in skin and them go to system and change to another skin and them go back to previous skin the chances get save
                  I only use Confluence, with a custom background.
                    OK, I've gone to 6.0.3.3 which seems to be working. So I was on 6.0.3.2 moved to the Jarvis beta build which seemed fine until the skin problem was highlighted by zambu. Let you all know if I have any issues with 6.0.3.3.
                      zambu PatrickJB I'll have a look at the skin issue. Next time when you encounter something like that, please collect a system log and post it here, this will save me some time on reproducing the issue.
                        kszaq
                        I just tried update from 6.0.3.1 to OpenELEC 6.90.1I get error in check_update: mount_common: Could not mount /flash/SYSTEM *** Starting debugging shell... type exit to quit ### can't access tty: job control turned off. HD18Q update.tar
                        Update: I typed exit and rebooted. Box is running 6.90.1 so I don't know if that error has any significance or not. My changes are still not being kept, when I reboot they are gone, same as before.
                        H MAn
                          Originally posted by Hercules Man View Post
                          Guest
                          I just tried update from 6.0.3.1 to https://github.com/kszaq/OpenELEC.tv/releases/6.90.1"]OpenELEC 6.90.1[/URL]I get error in check_update: mount_common: Could not mount /flash/SYSTEM *** Starting debugging shell... type exit to quit ### can't access tty: job control turned off. HD18Q update.tar
                          H MAn
                          This is explained in release notes.
                            kszaq
                            ​This is where I found the retroarch plugin that works with our sticks :
                            I think that this addon was pulled out of a lakka C1 build...so probably just need to pull the latest from a working lakka C1 build.
                            Edit : It looks like they added Dreamcast support with the new reicast core. http://oph.mdrjr.net/meveric/pool/ma...eicast-odroid/ I am going to try to get a dreamcast iso working today.
                            Edit 2 : Fixing the sound code was actually hw:0,1 rather than hw:0,0 :
                            set audio_driver = alsa
                            audio_device = hw:0,1
                            Edit 3 : Sonic on Genesis at 60fps looks so good!
                              I updated the MXQ 6.90.1 over the HD18Q build and everything is working. No error on update and my changes have been saved. Nice one ksaq, I will report any further issues should I find them
                              H MAn
                                H MAn
                                I have updated again to HD18Q 6.90.1 over MXQ 6.90.1 and this time I never got any errors. However, changes are not being saved after shutdown/reboot. Reason I went back to HD18Q build is because I believe it runs better on my box. Almost faultless this apart from the mentioned bug, it could well be skin related yet, I have changed to default skin and rebooted and it has saved that change. but this is the first time this has happened. All other updates have not had that effect.
                                Many Thanks
                                H MAn
