[ROM] Unofficial OpenELEC for MK808B+ and MXQ
Hi kszaq, I am new to this forum but have been using your builds of OpenELEC on a MK808B+ for some time now. The experience with OpenELEC is way better than the 'out of the box' Android experience. With Android the box used to crash, and I had loads of lip-sync issues and video jerking, so thank-you so much for all the amazing effort that you, and others on this forum keep putting into this.
I wanted to ask about a comment that you made a while ago about RetroArch. You said that you had it working with 6.90.1, and that you may put it somewhere for others. I would be interested to try it if you have. Does your rebuilt version of RetroArch still need to be configured for the hardware?
I know someone suggested that there should be a new forum thread for this topic, but I didn't start one in case there is one somewhere already. If you aren't aware of one, then I could start one.
Thanks again for what you are doing.
Originally posted by Shadi86 View PostThe latest version it's great was using it till now, but today when I start the box, my kodi just started to restart(not the whole openelec, just kodi, it's keep restarting without stop, what could it be, do everyone else have get this problem?
Skickat från min D6603 via Tapatalk
Hello everybody. Im using mbox's all black mxq. Using only Kodi, so openelec would be perfect for me. I tried to do toothpick boot, mut im not able to select nothing on boot menu (USB stick boot), remote dont work, wireless keyboard wont work, wireded mouse dont work. Tried also with SD-card, but not able to get on Android man screen, just hangs amlogic screen with 3 seconds and reboots all ovet again until i release toothpick button. What to do?
edit. managed to boot from sd-card, booted first time but on second boot only kodis backgroud shows. Trying now install 7.0 to nand memory.
Edit2. OpenELEC 7.0 build seems to work fine on my all black mxq box (nand).Last edited by Corsten; 20 March 2016, 12:21.
Ks
after installing 6.90.2 (toothpick, fresh install) and running it a bit, a few questions plz
Black MXQ AM_MXQ_A 20150825 bord
prior versions showed 812MB of memory and now it marks 796MB?
when i go to systeminfo --Hardwere i can see all 4 cpu's %, on every reboot only 2 cpu's show % change the other 2 are stuck, is that ok?
system temp is 60C, is that OK?
skin installation went ok with no erors(i think that was the first time every thing went smood), add on installed ok, did encaunter a self reboot by the system after navigating the menues and generated a log ,if u want i can post it.
movie play is ok
if any more questions appeare will post
THX for the build.
Originally posted by nigelg View PostHi kszaq, I am new to this forum but have been using your builds of OpenELEC on a MK808B+ for some time now. The experience with OpenELEC is way better than the 'out of the box' Android experience. With Android the box used to crash, and I had loads of lip-sync issues and video jerking, so thank-you so much for all the amazing effort that you, and others on this forum keep putting into this.
I'll post RetroArch for Jarvis beta together with next Jarvis build.
Originally posted by Shadi86 View PostHi thanks for your answer
Yes I was also suspect that it's not this build of openelec causing this restarting, it's have more to do with the 3 part addons I have installed or maybe tvheadend client addon because I use tvheadend addon a lot
An off-topic question: how did you manage to make Tapatalk work with this thread? I'm unable to see the latest posts since May...
Originally posted by Mudda_funkA View Postlo will the openelec with kodi 16 be a final release or another beta?
movie play is ok
THX for the build.
2 CPUs stuck is because of hotplug governor bug (that I'm not planning to fix) - when the cores are offline, system shows their last load value and not 0%. No need to worry about that either. If that's something that bothers you, you can change your CPU governor to ondemand or interactive.
Our boxes are passively cooled, 60°C is completely normal. I also wouldn't say that reading is very accurate but that's how thermal driver works.
hello,
i try Latest OpenELEC 7.0 beta release: OpenELEC 6.90.2 , but i have many error with tv , my configuration
Tvheadend , dvb-t2 ( rtl2832u ) , if play tv mpg2 no problem , if play tv mpg4 :
17:01:50 T:2766263200 DEBUG: PVRManager - OpenLiveStream - opening live stream on channel 'TF1 HD'
17:01:50 T:2766263200 DEBUG: opening live stream for channel 'TF1 HD'
17:01:50 T:2766263200 DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - demux open
17:01:50 T:2766263200 DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - demux subscribe to 1023887259
17:01:50 T:2766263200 DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - demux successfully subscribed to channel id 1023887259, subscription id 1
17:01:50 T:2866893728 DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - demux unhandled subscription message [subscriptionGrace]
17:01:50 T:2766263200 DEBUG: PVRFile - Open - playback has started on filename pvr://channels/tv/Toutes les chaînes/pvr.hts_1023887259.pvr
17:01:50 T:2766263200 DEBUG: CDVDInputStreamPVRManager::Open - stream opened: pvr://channels/tv/Toutes les chaînes/pvr.hts_1023887259.pvr
17:01:50 T:2766263200 NOTICE: Creating Demuxer
17:01:50 T:2766263200 ERROR: Get - failed to get stream
17:01:50 T:2766263200 DEBUG: CDVDPlayer::SetCaching - caching state 2
17:01:50 T:2766263200 WARNING: CDVDMessageQueue(audio)::Put MSGQ_NOT_INITIALIZED
17:01:50 T:2766263200 WARNING: CDVDMessageQueue(video)::Put MSGQ_NOT_INITIALIZED
17:01:50 T:2766263200 DEBUG: OnPlayBackStarted: play state was 1, starting 1
17:01:50 T:3037418048 DEBUG: PlayFile: OpenFile succeed, play state 2
17:01:50 T:3037418048 DEBUG: OnPlayBackStarted: play state was 2, starting 0
17:01:50 T:3037418048 DEBUG: ------ Window Init (DialogSeekBar.xml) ------
17:01:50 T:3037418048 DEBUG: CGUIInfoManager::SetCurrentMovie(pvr://channels/tv/Toutes les chaînes/pvr.hts_1023887259.pvr)
17:01:50 T:3037418048 DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
17:01:50 T:3037418048 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
17:01:50 T:3037418048 DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - Announce(flag=Player, sender=xbmc, message=OnPlay)
17:01:52 T:2866893728 DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - demux subscription start
17:01:52 T:2866893728 DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - id: 1, type H264, codec: 28
17:01:52 T:2866893728 DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - id: 2, type EAC3, codec: 86057
17:01:52 T:2866893728 DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - id: 3, type EAC3, codec: 86057
17:01:52 T:2866893728 DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - id: 4, type EAC3, codec: 86057
17:01:52 T:2866893728 DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - id: 5, type DVBSUB, codec: 94209
17:01:52 T:2866893728 DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - id: 6, type DVBSUB, codec: 94209
17:01:52 T:2866893728 DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - demux stream change
17:01:52 T:2766263200 DEBUG: CDVDDemuxPVRClient::RequestStreams(): added/updated stream 0:1 with codec_id 28
17:01:52 T:2766263200 DEBUG: CDVDDemuxPVRClient::RequestStreams(): added/updated stream 1:2 with codec_id 86057
17:01:52 T:2766263200 DEBUG: CDVDDemuxPVRClient::RequestStreams(): added/updated stream 2:3 with codec_id 86057
17:01:52 T:2766263200 DEBUG: CDVDDemuxPVRClient::RequestStreams(): added/updated stream 3:4 with codec_id 86057
17:01:52 T:2766263200 DEBUG: CDVDDemuxPVRClient::RequestStreams(): added/updated stream 4:5 with codec_id 94209
17:01:52 T:2766263200 DEBUG: CDVDDemuxPVRClient::RequestStreams(): added/updated stream 5:6 with codec_id 94209
17:01:52 T:2766263200 NOTICE: Opening stream: 0 source: 256
17:01:52 T:2766263200 NOTICE: Creating video codec with codec id: 28
17:01:52 T:2766263200 DEBUG: CDVDFactoryCodec: compiled in hardware support: AMCodec:yes MediaCodec:no OpenMax:no libstagefright:no VDPAU:no VAAPI:no iMXVPU:no MMAL:no
17:01:52 T:2766263200 DEBUG: FactoryCodec - Video: amcodec - Opening
17:01:52 T:2766263200 DEBUG: SECTION:LoadDLL(libamplayer.so)
17:01:52 T:2766263200 DEBUG: Loading: libamplayer.so
17:01:52 T:2766263200 ERROR: Unable to load libamplayer.so, reason: libamplayer.so: cannot open shared object file: No such file or directory
17:01:52 T:2766263200 DEBUG: Dll libamplayer.so was not found in path
17:01:52 T:2766263200 WARNING: CAMLCodec::CAMLCodec libamplayer.so not found, trying libamcodec.so instead
17:01:52 T:2766263200 DEBUG: SECTION:LoadDLL(libamcodec.so)
17:01:52 T:2766263200 DEBUG: Loading: libamcodec.so
17:01:52 T:2766263200 INFO: DVDVideoCodecAmlogic: Opened Amlogic Codec
17:01:52 T:2766263200 DEBUG: FactoryCodec - Video: am-h264 - Opened
17:01:52 T:2766263200 NOTICE: Creating video thread
17:01:52 T:2627724192 DEBUG: Thread DVDPlayerVideo start, auto delete: false
17:01:52 T:2766263200 NOTICE: Opening stream: 1 source: 256
17:01:52 T:2627724192 NOTICE: running thread: video_thread
17:01:52 T:2766263200 NOTICE: Finding audio codec for: 86057
17:01:52 T:2766263200 DEBUG: FactoryCodec - Audio: passthrough - Opening
17:01:52 T:2766263200 DEBUG: FactoryCodec - Audio: passthrough - Failed
17:01:52 T:2766263200 DEBUG: FactoryCodec - Audio: FFmpeg - Opening
17:01:52 T:2766263200 DEBUG: FactoryCodec - Audio: FFmpeg - Opened
17:01:52 T:2766263200 NOTICE: Creating audio thread
17:01:52 T:2627724192 DEBUG: CDVDPlayerVideo - CDVDMsg::GENERAL_SYNCHRONIZE
17:01:52 T:2766263200 NOTICE: Opening stream: 4 source: 256
17:01:52 T:2766263200 DEBUG: FactoryCodec - Overlay: FFmpeg Subtitle Decoder - Opening
17:01:52 T:2619335584 DEBUG: Thread DVDPlayerAudio start, auto delete: false
17:01:52 T:2619335584 NOTICE: running thread: CDVDPlayerAudio::Process()
17:01:52 T:2766263200 DEBUG: FactoryCodec - Overlay: FFmpeg Subtitle Decoder - Opened
17:01:52 T:2619335584 DEBUG: CDVDPlayerAudio - CDVDMsg::GENERAL_SYNCHRONIZE
17:01:52 T:2619335584 DEBUG: CDVDPlayerAudio - CDVDMsg::GENERAL_RESYNC(13055.000000, 1)
17:01:52 T:2766263200 DEBUG: ParsePacket - {2} iSampleRate changed from 3 to 48000
17:01:52 T:2766263200 DEBUG: ParsePacket - {3} iSampleRate changed from 3 to 48000
the video freeze with tv , but no with movie
There are currently 3384 users online. 0 members and 3384 guests.
