[ROM] Unofficial OpenELEC for MK808B+ and MXQ
Originally posted by kszaq View Postmpp.  MK809 Plus is reported to work but is not guaranteed. As you may already know, your device doesn't have a "recovery button". From what I looked into bootloader source code, you may be able to enter recovery by repeatedly pressing Menu button right after powering on the box - and you should be aware that even if it works, you'll lose that ability after flashing OpenELEC as the included bootloader is intended for devices with recovery button and not without. If the Menu button method doesn't work for you, you can either use Terminal Emulator or connect over ADB and issue ;reboot recovery.
Thinking forward I have a Tronsmart TMS01 2.4 Ghz remote for the MK809 Plus. I am thinking that once flashed with your Openelec ROM this remote will not work; correct?
Is there a default keyboard or keyboards supported by default once flashed with Openelec for this device?
I am in a bit of a pickle as somehow everything on menus that I click on for the MK809 Plus now seems to run the browser by default under Android. With Geekbuying dropping support for this device I don't know what to do to flash the new Android Update ROM as I cannot execute the update instructions as detailed in this link:
http://blog.geekbuying.com/index.php...ased-20150403/
Even on a cold boot it keeps running into this cycle.
I pretty much have to get Openelec going now to regain use of this box or consider a new box.
Thanks.
Originally posted by medeiros405 View PostHello to alls.
Here I'm only get audio in SPDIF interface, in HDMI has no audio.
Someone know how to fix this?
Thanks in advance
Originally posted by braguzz View PostThank you I'll try it this evening..
and what about acestream, p2pstream, ecc..? I dont understant if it should work or not.
thank you again,
PB
Originally posted by Compos View PostCould you please expand on this Kszaq? Where do the changes have to go and also, how do we find the correct GPIO for the LEDs?
For LED GPIO, first you need to look up power_led port in Android by typing cat /sys/kernel/debug/gpio. Then you have to modify this patch: https://github.com/kszaq/OpenELEC.tv...ower_led.patch
I pretty much have to get Openelec going now to regain use of this box or consider a new box.[
Thanks.
kszaq
You might have no idea, but I thought I would ask anyways. I'm trying to figure out if the KWorld UB435-Q TV Tuner will work. You can see it here:
It also appears in the Openelec supported TV Tuner list, but from my reading it seems not all those work with the MK808B+? http://wiki.openelec.tv/index.php/Supported_TV_Tuners
Thanks.
Originally posted by kszaq View Postmedeiros405 You need to tell me which version you are using, what device and provide logs. It also seems that there might be an issue with audio passthrough with 5.95.3.1 build which I plan to fix quite soon.
Hello kszaq, Im using a MXQ, and the Version is 5.0.8.20, but this issue happen in the beta version too.
My log files is in this URL https://drive.google.com/open?id=0Bx...UhDQlRWdjF5LW8
Thanks for the help.
Medeiros405
Hello,
i want to customize a few things with openelec, so i downloaded the packages and edited what i wanted. now i want to compile it, so i ran (for MXQ):
PROJECT=Amlogic ARCH=arm DEVICE=MXQ make release
after 2 hours it finished and i got a new directory with many sub-directories. now im kind of at a loss, what do i do now? sorry if this is a stupid question.
thank you
Sorry for this offtopic question not related directly with any openelec problem. But only to know if I can use this openelec on the box I bought.
The MXQ supported by this openelec version is the one sold on gearbest (http://www.gearbest.com/tv-box-mini-pc/pp_80704.html)?
It seems that many guys are making MXQ's. I already spotted one from tronfy, acemax have 2 versions (one without button and one that looks like the one from gearbest), and beelink.
Originally posted by Mafarricos View PostSorry for this offtopic question not related directly with any openelec problem. But only to know if I can use this openelec on the box I bought.
thank you
Originally posted by medeiros405 View PostHello to Alls,
I have two MXQ boxes, and Installed this version in theses boxes, but all boxes get the same MAC address for the Ethernet 00:11:22:33:44:55, like the two MXQ have the same mac address I had problem in my network.
Have any way to fix this?
Thanks in advance
Romeu Medeiros
There are currently 2968 users online. 1 members and 2967 guests.
