[ROM] Unofficial OpenELEC for MK808B+ and MXQ
kszaq I just tried the new build but sadly it gets stuck at either "Starting Kodi Hacks" on first boot or if I reboot it gets stuck at "Starting Kodi clean debug logs". I tried installed the update both ways either via the zip method as well as installing the previous 5.08 0429 version and then updating via the tar file. Both resulted in same situation.
Originally posted by kashmoney View Postkszaq I just tried the new build but sadly it gets stuck at either "Starting Kodi Hacks" on first boot or if I reboot it gets stuck at "Starting Kodi clean debug logs". I tried installed the update both ways either via the zip method as well as installing the previous 5.08 0429 version and then updating via the tar file. Both resulted in same situation.
EDIT: It looks like there are missing dependencies for a bunch of things.
Originally posted by kszaq View PostUnfortunately, this kernel brings no fix for HD-Audio or multichannel audio support, stuttering 29.97 videos nor DVB issues.
However, please download, test and report any new issues or improvements that you observed. Thanks in advance!
Mine works perfectly well with a Sony PlayTV device (dual DiBcom 7000PC DVB-T), with 5.08-20150511.Last edited by Dez; 28 May 2015, 05:30.
kashmoney, Dez I'm sorry for the boot issue. I will look for what have gone wrong and post a new build today evening. I must have screwed something up when rebasing the code.
If you want to revert to a previous version without losing your settings, use a toothpick method but before putting the SD card in the box edit the factory_update_param.aml file and delete these lines:Code:--wipe_data --wipe_cache
Code:--update_package=/sdcard/OpenELEC-Amlogic.MK808B.Plus.arm-5.0.8-update.zip
No worries with reverting back, I wanted to re-install anyway.
The DVB issue seems like it might be a driver problem. (?)
I just quickly connected my IT9135 based tuner and it didn't appear in TVHeadend.
Reconnected the PlayTV and it appears without a problem and works perfectly.
The IT9135 tuner I have worked fine in earlier versions of Openelec.
When I get a chance later, I'll try a dmesg on each and see how far they get
Dez have you checked whether you can tune to a channel and watch it with no issues with the IT9135 tuner? I couldn't make that work, no matter if I used a in-kernel driver or a media-build one. With some modifications I made it work but half of image was green and the rest distorted. I guessed it is an USB driver issue since there were some messages about errors in USB bulk data transfer and also RPi users had problems with dwc_otg driver and DVB tuners among others.
I have noticed I made a stupid typo in Bluetooth firmware loader script that might have prevented the latest build from booting. I have corrected the typo and uploaded a new build: http://s805.eu/releases/5.0.8-20150528/ Note that is has not been tested, update with care. I hope this time it boots.
Originally posted by kszaq View PostDez have you checked whether you can tune to a channel and watch it with no issues with the IT9135 tuner? I couldn't make that work, no matter if I used a in-kernel driver or a media-build one. With some modifications I made it work but half of image was green and the rest distorted. I guessed it is an USB driver issue since there were some messages about errors in USB bulk data transfer and also RPi users had problems with dwc_otg driver and DVB tuners among others.
At the time, I put it down to being a cheap tuner with not as great a frontend as the PlayTV.
I've seen a similar thing with using other media players, like a RK3288 based box with Kodi and a Celeron based one running Openelec.
5.08-20150511 does not appear to load the IT9135 drivers successfully, as it doesn't appear in TVHeadend (4.3.13) at all, whereas in earlier versions of your Openelec port it would.
The other difference could be that my IT9135 stick is actually a IT9137 and IT9133 (basically a dual IT9135).
I tried different version of this openelec and i can't set manual ip. Mac address change every reoot (also in 4.95) but the autostart workaround solved. I had another problem. The beelink mxq s85 freeze itself after some minutes...also if i do nothing. I solved by reverting the CPU governor to hotplug. Very strange. I use tvheadend but only frontend (backend is installed in bananapi with bananian distro), no problem at all. Now i'm using 20150511 version since some days and, with that two workaround, works perfect. I donate you some euros. My mxq is reborn with this rom! Many thanks!
Originally posted by kashmoney View Postkszaq even with the newer 0528 file both sticks still get stuck at "Starting Kodi clean debug logs". Any chance that you could just take the 0511 version and only do the AP62x2 patch only to see if it works with that alone. then we can look into the new kernel updates and what not?
Originally posted by adonebert View PostI tried different version of this openelec and i can't set manual ip. Mac address change every reoot (also in 4.95) but the autostart workaround solved. I had another problem. The beelink mxq s85 freeze itself after some minutes...also if i do nothing. I solved by reverting the CPU governor to hotplug. Very strange. I use tvheadend but only frontend (backend is installed in bananapi with bananian distro), no problem at all. Now i'm using 20150511 version since some days and, with that two workaround, works perfect. I donate you some euros. My mxq is reborn with this rom! Many thanks!Code:systemctl restart kodi
Thanky you a lot for your donation!
First time using this unofficial port, overall it's pretty snappy, much snappier than a Raspberry Pi 2 so thank you.
Tried the test version out, but obviously it had problems so went to the stable release.
I have an issue video scrapping, it seems limited to only 75 movies on my hard drive. If I try updating the library by looking for new content it can see all the missing videos but it won't add it to the library.
Sorry if this has been asked before, or has been fixed in a newer release.Currently Using:
2 x Nvidia Shield TV | MiniMX III
Retired Devices:
MiniMX III-II | Mk808b Pro | Mk808b Plus | Raspberry Pi 1 + 2 | UBOX R89 | MK808 | MK808b | CS008 | X1 4K (rk3288_809) | CYX_809III | Ouya | CX-919 | S82 Plus | Tronstmart R68
kszaq the newest 0528 does bootup properly however it goes to a blue screen. I can hear kodi working though cuz if I press the arrows keys on the keyboard I can hear the sounds. Also if I power my tv on after I power the MK808B Plus on it will actually show me Kodi and everything but a really hazy screen. Would that have to do with the fb1 hack you mentioned for csgabe. With regards to the AP6212 though it didn't show up in the network section at all for me to enable as it does on my older unit with the AP6210. The MK808B Plus with AP6212's don't work still.
Originally posted by ididmytime View PostFirst time using this unofficial port, overall it's pretty snappy, much snappier than a Raspberry Pi 2 so thank you.
Sorry if this has been asked before, or has been fixed in a newer release.Code:cat /storage/.kodi/temp/kodi.log | paste
Originally posted by kashmoney View Postkszaq the newest 0528 does bootup properly however it goes to a blue screen. I can hear kodi working though cuz if I press the arrows keys on the keyboard I can hear the sounds. Also if I power my tv on after I power the MK808B Plus on it will actually show me Kodi and everything but a really hazy screen. Would that have to do with the fb1 hack you mentioned for csgabe. With regards to the AP6212 though it didn't show up in the network section at all for me to enable as it does on my older unit with the AP6210. The MK808B Plus with AP6212's don't work still.
Something a bit weird with loading the IT9135 drivers.
It shows the stick being found: "usb 2-1: New USB device found, idVendor=048d, idProduct=9135"
...but then does not appear to load the firmware at all, or the drivers properly: "New USB device strings: Mfr=0, Product=0, SerialNumber=0"
I'm guessing maybe firmware and maybe missing files, as dvb_usb_it913x, dvb_usb_v2 and dvb_core are there (however it may also need it9135x-fe and it913x to work properly).
The firmware files dvb-usb-it9135-01.fw and/or dvb-usb-it9135-02.fw don't appear to load at all, maybe because of some missing files.
This might also be the case for other tuners.
My Sony PlayTV (which works perfectly) shows:
"usb 2-1: New USB device found, idVendor=1415, idProduct=0003"
"usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3"
"usb 2-1: Product: SCEH-0036"
"usb 2-1: Manufacturer: SONY"
"usb 2-1: SerialNumber: ALROO1LNGS"Last edited by Dez; 29 May 2015, 09:15.
Dez firmware is not missing nor the drivers, they simply do not work properly. It needs time looking into it.
kashmoney If the regular MK808B+ Android works for you, please try the new test version (just built, untested!): link removed
I modified automatic NVRAM selection to match implementation I got from Nexteon. Let's hope it works with the new chip you have...
Edit: I have just tested it and it doesn't work. I will work on it and post an updated build.Last edited by kszaq; 29 May 2015, 19:42.
There are currently 2153 users online. 2 members and 2151 guests.
