[ROM] Unofficial OpenELEC for MK808B+ and MXQ
Originally posted by rev6 View Post
This clip works fine with the latest beta.Originally posted by kszaq View Post
anthonytex Yes, it has been fixed some time ago. The problem was kernel driver and an update from Amlogic fixed it.and kszaq for the excellent work
Thanks,i have tronsmart mk808b plus , work great with OpenELEC 5.0.8 (p15) 5.0.8-20150610, only issue HD-Audio passthrough not working.
Hello,
Im using the p15 openelec version and when im watching live tv stream im getting audio noise on sport tv 1 (portuguese channel) and its running on Standart quality. All the others channels audio are working fine.
I checked the same channel on computer and the audio is ok so it must be some rom problem. Im not posting here the link cause i dont now if i can do it but you can find it on vdubt25.
MK808b Plus @ gearbest
Originally posted by karl0ss View PostHey, any chance of a new build based on Kodi 15? The last beta must be pretty old now
ThanksOriginally posted by ovidiu31 View PostHello Matt
What is the ETA on SD card booting version?
Some feedback after 2 week using your rom (p15) on beelink MXQ :
- Sometimes wifi doesn't work at startup I have to reboot severall times before it get connected.
- Sometimes video and audio are not synchronized it seems to happen only with the hardware decoder (need some more testing to be sure)
- Tearing in kodi interface. (Video not affected)
- Kodi less stable than the x86 version but nothing dramatic just some random crash.
Overall the experience is really good despite this little problems. I'm really happy for a box that cost me less than 50€ it work really good and got a lot of potential.
Originally posted by mac1202 View PostSome feedback after 2 week using your rom (p15) on beelink MXQ :
Overall the experience is really good despite this little problems. I'm really happy for a box that cost me less than 50 it work really good and got a lot of potential.
I have had video audio go out of sync a few times.
Tearing here on all 3 versions.
I had the latest beta freeze today while watching a movie from an external harddrive. Going to try p8 now.
Originally posted by ofear View PostCan I flash one of those version on the Chiptrip MXV S805 ?
It's have the same specs....
Everybody, thank you for your tests and reports. I released a new version today with booting from SD card possible for all supported devices. See first post for links and full info!
HD18Q users: I don't own a HD18Q therefore I wasn't able to test this release. TAR upgrade is completely safe but I can't guarantee that new installs - both SD and NAND versions would work!
kszaq, only to be sure of process: SD card:- Download img.gz file from SD release folder.
- Unpack image to you hard drive and burn it to SD card (you can read how to do it here:http://wiki.openelec.tv/index.php/HO...The_Disk_Image).
- To boot the system for the first time you have to use "toothpick" method. You have to do this only once or after Android update.
Originally posted by Mafarricos View Postkszaq, only to be sure of process: SD card:- Download img.gz file from SD release folder.
There are currently 3259 users online. 1 members and 3258 guests.
