MEGA provides free cloud storage with convenient and powerful always-on privacy. Claim your free 50GB now!
i'll try Flashtool with TWRP_Recovery_T98_4G.rar first
dingdongtoolbox only russian and chinese i'm scared of SCAM
GOOD LUCK
PS I'm waiting my t98 from china now...so i cannot test it... for darki2k no vendor in europe only 330 euro on **** from italy!
GOOD LUCK
where did you bought it in china? how much do you pay with taxes? thanks
Does anyone of u guys know a seller which is shipping this tablet from europe ? with a price cheaper then 300 € ? I wanna buy it :/.. And im Scared of the grainy screen of Cube's T9 :/...
thanks!
Never heard of grainy screen on Teclast T98, don't worry
I suggest you to buy through Aliexpress and not from Europe. You will pay a lot less buying from there!
well the tab would be priced on ali with shippment for 277 €, if i have to pay taxes ( here in germany 19 % ) this tablet will be priced for 331 €, is there a way to avoid taxes? somehow i cant find the tab for 270 $ from the official sellers of teclast.
Thanks guys ..
GOOD LUCK
Thanks a lot. Right now I've made a complete backup to the MicroSD card.
IThe flash process was made using flashify,...the easiest way available so far. I absolutely recommend it.
TECLAST T98 4G C6R2 has a working TWRP custom recovery...
I think hanuma50 was the developer, all credit for him, and for hocuspocus69, who make us aware of this news..., and also published a working link hosted in MEGA.
[QUOTE = darki2k; 291130] Ima li netko od u momački znati prodavatelj koji je transportno ovu tabletu iz Europe? uz cijenu jeftinije od 300 €? Želim kupiti: / .. i im Scared od zrnatom zaslonu kocke T9: / ...
! hvala [/ QUOTE]
I have looked at _https://www.fastcardtech.com/goods.php?id=14048
have the option to Netherlands Post +
option from 5% to avoid customs duty! (if you pay customs duties) they give you back the money !?
But I am at the end I order to _http: //www.chinistore.com/ $ 246 + $ 20 DHL
The package came for five days, but I had to pay customs duties: //
Good luck
Does not anybody have the will to write instructions as upgraded T98?
Is the P98 4G worth it for 190€ ?The seller said it's equivalent to T98 only 4G has lesser frequency.If anyone had one.
P98 and T98 are totally different tablets!
P98 is equipped with a quadcore cortex A15 (allwinner a80) and a fast GPU. Ideal for games but with low battery life (less than 6 hours).
T98 is equipped with a octacore cortex A53 64bit (mediatek MT8752) and a mid range GPU. Good general purpose performance with an outstanding battery life (10 hours).
Just to summarize: if you want a game machine go for P98, otherwise T98 is a better choice!!!
