CUBE Talk9X U65GT_V2.0.7LW_en_Lepi_150228
    Only for tablets with a serial number higher than B1426XXXXXXX!
    Serial number can find on the back cover at the bottom near the connector Micro USB.
    Hi, my friends. I publish new mod-version
    U65GT_V2.0.7LW_150228_mod Lepi.
    Made on the basis of previous firmware
    U65GT_V2.0.6L_150222_mod Lepi.
    ChangeLog:
    The publication of this mod without the consent of the author !!!
    The next release of the white version 2.0.x.
    1. Fully deodex.
    2. ROOT by default Superuser app from Clockworkmod.
    3. Remove all software in Chinese.
    4. By default, the English language GB on first boot
    5. Modified the boot.img:
    a) support init.d through busybox;
    b) Permissive mode by default;
    c) checkbox is checked USB debugging on first boot, then you can disable.
    6. Traditionally, lowered the minimum manual brightness of the display to 4% and Auto Brightness level.
    7. Implemented a system application in the Font Chooser Settings \ Screen to change the font. Development hartec.
    8. Traditionally modified file platform.xml for full access to the memory card.
    9. Improved user interface firmware for better readability of the text on the buttons and panels, returned to stock status bar settings.
    10. Deleted gps.conf.
    11. Default stock Launcher 3.
    13. Implemented development niorix flash drives to mount the file system NTFS.
    14. Implemented animation notifications in status bar. Thank SlimHouse and grisha84 for recipes and cherva70 for help.
    15. On the USB connection now button instead of doing Tap on the picture. Thank grisha84 for the recipe.
    16. When you start the dialer in white topic immediately opens the numeric keypad to dial. Thank lekha1980.
    17. Changed power_profile in the hope of correct statistics of battery discharge.
    18. Off the default Power Saver Mode. To enable it you need to uncheck the check box. After rebooting daw back. That is exactly the opposite against stock options. The idea of ​​user CatB. His test was successful.
    20. Removed mourning triangles on the avatars of contacts.
    21. Removed annoying BEEP when you press the volume rocker.
    22. Settings \ For developers introduced Engineering menu and test menu.
    24. Changed the white theme. Made design a la Lolipop.
    25. Implemented management applet folder init.d, ie system tweaks based on scripts. Thank grisha84 for the recipe.
    26. Introduced to remove all recently opened applications. Thank Alexey arsenev.
    27. Stock radio replaced the radio from Lenovo. Thank Joker2010 finder and aid in the treatment of this application bugs.
    29. Change the default wallpaper and icons many system applications.
    30. Preinstalled keyboard Android L Keyboard. After the firmware you want to run it, and set up a shortcut.
    31. Implemented library against stuttering sound when online viewing. Thanks to everyone who participated in this patch.
    Among the new changes:
    32. Ability to disable system applications in the Settings \ Applications. Thanks for the recipe RekGRpth
    33. Change style icons Android L
    34. Screenshot in Power Menu. Thanks for the recipe Alexey arsenev and cherva70 for troubleshooting.
    35. Blocking in the Preferences, the application AdAway. Thank you for the idea Graevka.
    36. Light theme settings Google aссount.
    37. Rounded corners dialogs and some icons in the style of LEWA OS.
    38. Video recording from the screen. Thanks for the recipe and grisha84 and cherva70 for troubleshooting.
    39. Sound unlock additional tab in the Preferences. Thank FatuRe for the recipe.
    40. Mode multiuser for 5 people.
    41. Returned undeservedly forgotten flashlight.
    42. Traffic in the status bar. Thank the_vanya1 for manual.
    43. Animation notification with customizable animation. Thanks grisha84 for the recipe.
    Download: U65GT_V2.0.7LW_en_Lepi_150228.zip
    md5: f7f4248d153c8aa65d25e338013685fb
    Installation Instructions:
    Only for installation through modrecovery CWM or TWRP!
    Archive firmware to put in the root of the internal or external memory (can be in any directory with the Latin name). Boot into recovery. Make a backup of the current mandatory firmware better on an external memory card. Then make the necessary wipes tab ADVANCED:
    1 Dalvik Cache
    2 System
    3 Cache
    4 Data
    5 Android Secure
    Then select Install (TWRP), specify the path to the file to confirm the firmware and swipe process of firmware. Wait for a successful finish and boot the system. Make settings by yourself.
    The first boot lasts a long time, you need to wait patiently and not to touch the display.
    If you put this firmware over the last firmware version 2.0.6, you can wipes are also not do.
    There are no guarantees! Risk and assumes responsibility fully by the user.
    Preliminary backup is required!
    Successful upgrade!
    ADDONS:
    Patch for 1 user (disable multiuser mode)
    upd_U65GT_207LW_1user.zip
    Install only from CWM or TWRP.
    TWRP_2.8.5.0_mod_Lepi.rar
    only for SP Flashtool!
    TWRP_2850_LEPI+darkTheme.zip only for modrecovery!
    TWRP_2850_LEPI+lightTheme.zip only for modrecovery!
    videoTutor1 videoTutor2 videoTutor3 videoTutor4 videoTutor5 videoTutor6
    TWRP_2.8.1.0
    TWRP_2810_newTheme TWRP_2.8.5.0
    PayPal donate WMID410517421626
    Thanks verry good rom again
    And the new recovery great!
    and a question will you release a dark version of this rom too?
    Thanks for your hard work
      No. Sorry
      TWRP_2.8.1.0
        I have tested this Version but i use the Version UPD_U65GT_V2.0.7LB_Lepi_150223 from 4pda.ru. I like the black thema.
          Very useful information.
          TWRP_2.8.1.0
            Can we expect an upgrade from you which not only looks like Lollipop,
            but it really is?
              Can you give me a link to download this black version? I also prefer it. Thanks.
                I flashed this ROM on B1423xxxxxx and I have no touchscreen issues. Amazing features, but I really don't like the light thema. Could somebody please upload the UPD_U65GT_V2.0.7LB_Lepi_150223 version? I can't find it on 4pda.ru, Google translator is really messing the site up and I would like to try the dark version. Thanks!
                Odesláno z mého U65GT pomocí Tapatalk
                  We wrote about v2.0.7LB on this page.
                  You can find two links to download files on that page, too.
                    Thank you sir! That dark version is fantastic. And of course thank you Lepi for your hard work!
                      dark theme vs light theme
                      I do firmware for themselves and simply share with you my modifications. Black theme from now on I is not modified, because I like the light theme. I hope this is clear. This is not my work. This is my hobby.
                      TWRP_2.8.1.0
                        Thank you. It's nice to have a person like you to our great tablet ...
                          Its loud and clear
                          Light theme will do the job too
                          Its only a matter of tased
                          Keep on with your good hobby so we all can have the bennefits of it,iff you share it
                            Options are not displayed
                              What is the application?
                              TWRP_2.8.1.0
