CUBE Talk9X U65GT_V2.0.7LW_en_Lepi_150228
Originally posted by mattiesrag View Post...problem is the add ons ( 1 user.....multi user.....and buttstroke) cannot download. System says "file does not exist"...
You can download the files you are looking for from this link (ROM sections).
If you still can not download them, write to me I have it.
Originally posted by mattiesrag View PostLepi, would it be possible to upload your addon files to Yandex or Dropbox, and send me a link?
upd_U65GT_2.0.9LB_1user.zip
Originally posted by cri8mar View Posthi dear i have a problem... my cube dosn't see the usb storage... it see only one partition and when i mount it, give an error.. why? with brian rom (900Supersport v1.8) it work fine... what can i do?
make the necessary wipes tab ADVANCED:
1 Dalvik Cache
2 System
3 Cache
4 Data
5 Android Secure
Had the same problem, and that did it for me. I guess when I first made it, something didn't work properly. After I did the necessary wipes again, everything was perfect.
That being said, a huge thanks to Lepi and Supersport....
Originally posted by pluto69 View PostHi Lepi.
Thanks for your great roms.
Could you be so kind to share the fix for the white text on some menus for your rom v2.0.7LW?
Thanks in advance,
pluto69
What's new:
1. Fixed some bugs interface "white on white".
2. Implemented 3Minit Battery Mod, modified by me in bright theme with online selection of new icons and settings of all parameters 3MinitBatterySettings. Before using the battery modes, you must enable the transfer of data in any way (Wi-Fi or 3G).
3. Added the ability to display the traffic in the status bar settings by color and off as needed. I draw your attention that the color settings of texts in the status bar is only possible in portrait mode, the tablet in landscape confirmation button, the selected color is not visible.
4. Added a setting density screen for those wishing to increase the size of the entire display at the touch of a button.
5. By default, the check box is turned on Unknown sources in Settings \ Security for the convenience of a quick recovery applications via Titanium.
6. Black and Customizable gestures now in the bright subject.
7. Round avatars in contacts and SMS.
U65GT_V2.0.8LW_Lepi_150308.zip
Wills,
the tutorial is simple: WAIT
there is no lollipop version available at the moment for Talk 9x.if you appreciate my efforts this is the link for any donation:
There are currently 4097 users online. 0 members and 4097 guests.
