CUBE Talk9X U65GT_V2.0.7LW_en_Lepi_150228
    Originally posted by Maxwell View Post
    Aloha from Greece,
    I follow the progress on Lepi's distros quite some time now. It's the first time I come up with an issue, though.
    After having installed 2.0.7 distro and during the first boot, booting freezes at boot image, just prior to the boot animation. It doesn't matter how much time I give to it, it remains frozen there.
    Any clues?
    Lepi, keep up the good work and don't stop doing it as a hobby. If it wasn't a hobby, it would not have been that good
    Welcome to your first Brick.
    I presume that you played with the TWRP recovery trying to erase Delvic cache etc. and accidentally formatted the system. Solution is simple:
    1.- Copy U65GT_V2.0.7LW_150228_mod Lepi to your Sim card manually or use an
    OTG cable and copy it to another good USB stick. (TWRP allows OTG installation.)
    My problems started with a corrupted Usb Stick.
    2.- Switch off your system and start it again pressing ( Start and Volume +) in the middle
    left corner of your Tablet will appear some very small letters with 3 choices.
    The first is Recovery mode. Just press (Volume -) and TWRP will start. Install etc. etc.
    Fyg while experimenting with Brian's mod I overextended the EBR to max 32gb by overzealous accident. Tablet worked flowerlesly using the external Sim as storage. Of course I lowered EBR to 8gb.
      Originally posted by furonai View Post
      Options are not displayed
      Fix bugs. Skype and YouTube settings. Soon publish.
      videoTutor1 videoTutor2 videoTutor3 videoTutor4 videoTutor5 videoTutor6
      TWRP_2.8.1.0
      TWRP_2810_newTheme TWRP_2.8.5.0
      PayPal donate WMID410517421626
        As you've solved ?
        How?
        Thank You
          video do not working
          As you've solved ?
          How?
          Thank You
          especially mkv
          do not open
            this build causes problems for video review
            Cannot open several video files, especially mkv. One of common messages is that sound is not available because ac3 codec is not supported.
            Any hints?
              Any hints?
              Do you use MX Player? As far as I remember ac3 support was removed there some time ago because of licensing restrictions.
                Lepi, again thanks for your hard work. Today i will try it!
                  New black Version: http://4pda.ru/forum/index.php?showt...#entry38547220
                    video does not working
                    yes, I have tried MX and all available VLC, kmp, but none worked so far.
                    Looks will return to S.upersports ROM
                      Any hints?
                      Do not write nonsense. MKV is a container, which is packed video and audio. Just as AVI file. Therefore, reproduction of the container depends on the presence in the system or codec quality player. Personally checked in their ability to play MKV. Everything is working properly. Best player MX with codecs for him.
                      TWRP_2.8.1.0
                        Originally posted by driver001 View Post
                        Hi Lepi, Love your new (2.0.9) dark ROM. Only problem is the add ons ( 1 user.....multi user.....and buttstroke) cannot download. System says "file does not exist" Please check for me. Thank you.
                          Sorry for my english. To be able to download a file from a site 4pda, you must first create an account.
                            video
                            while trying several kind of video files got sam emessage that this video cannot by played.
                            another message was that these players do not support ac3 audio.
                            Interesting if anyone expereince any problems with video so far.
                            Always exist possibility of faulty hardware, too.
                              Your English is 1000 times better than my nonexistent Russian.
                              Is it possible to post a link for these downloads? ROM download was OK but addons did not work. I cannot create an account.......I have tried. Thank you for your reply.
                                look
                                https://github.com/USBhost/MX_FFmpeg is my modified source where i'm building from You can download recent codecs here ( GitHub releases ) and 1.35.0-1.8.6 here ( Google Drive ). Also the XDA download tab is no longer updated as for some reason I...
