CUBE Talk9X U65GT_V2.0.7LW_en_Lepi_150228
    Originally posted by honzas17 View Post
    Thank you sir! That dark version is fantastic. And of course thank you Lepi for your hard work!
    Odesláno z mého U65GT pomocí Tapatalk
    My experience and sentiments, exactly.
    P34c3
      Originally posted by Lepi View Post
      What is the application?
      Skype
        Originally posted by furonai View Post
        Skype
        I regret.
        videoTutor1 videoTutor2 videoTutor3 videoTutor4 videoTutor5 videoTutor6
        TWRP_2.8.1.0
        TWRP_2810_newTheme TWRP_2.8.5.0
        PayPal donate WMID410517421626
          I regret.
          Do you try to change the std font in the settings ? I have experienced the same trouble after changing it.
          But great job with this new release !
            Tried. No problem. Even in the English version.
            TWRP_2.8.1.0
              First patch
              The patch for the visibility of white buttons navigation bar on a white background.
              upd_U65GT_207LW_navButt_strokeBold.zip
              Only for modrecovery CWM or TWRP!
              There are no guarantees! Preview backup is required!
              Successful upgrade!
              TWRP_2.8.1.0
                Successful upgrade!
                Thank you Lepi! It works fine
                  Xbox 360 Wireless
                  Hey all,
                  had anyone tried to connect a Xbox 360 wireless controller with wireless dongle to this tablet? I can connect it to my Samsung S5 and Moto G without any problems, but i cant connect it to this tablet with original firmware or lepis firmware. I tried several things like this http://forum.xda-developers.com/show....php?t=1792531 but it doesnt work.
                  Can please anyone help me?
                  Thanks it advance and great job lepi
                    A really great job Lepi !
                      I have the 2.0 stock rom on my cube. The only thing I added is root access. What steps are necessary to get into cwm or twm mode?
                        Options are not displayed
                        I got the same result in twrp root manager reboot options menu
                          - Copy custom ROM zip file to the SD card root directory.
                          - Shutdown (Switch Off) tablet.
                          - Go to Recovery mode:
                          a. Keep pressed Power button for 1 second and after that press Volume+ button
                          to get a Boot Menu.
                          b. Select Recovery Mode with Volume+ button (use V+ button only to scroll in this section!)
                          c. Enter into Recovery Mode with Volume- button.
                          - Clear caches.
                          - Install ROM zip file. (The system backup has been prepared before)
                          There is another, simpler way to go Recovery mode
                          if you install Mobileuncle MTK Tools. It has a menu to go there.
                          Anyway, Lepi's ROM contains this tool (and much more) pre-installed.
                            to get a Boot Menu.
                            - Clear caches.
                            I'm confused... Lepi is saying Only for installation through modrecovery CWM or TWRP to install his ROM, but you're saying they are not needed. (Your method seem very easy, since I'm not even sure where to get the right version of the two tools above. )
                            Also, I would like confirmation that you get the extended space (6GB) and the Chrome fix.
                              Frozen boot prior to boot animation
                              Aloha from Greece,
                              I follow the progress on Lepi's distros quite some time now. It's the first time I come up with an issue, though.
                              After having installed 2.0.7 distro and during the first boot, booting freezes at boot image, just prior to the boot animation. It doesn't matter how much time I give to it, it remains frozen there.
                              Any clues?
                              Lepi, keep up the good work and don't stop doing it as a hobby. If it wasn't a hobby, it would not have been that good
                                I did not want to say modrecoveries are not needed. I just wrote about as I upgraded Lepi's ROMs.
                                Since Lepi published TWRP_2850_mod I install it and flash ROMs and patches with it.
                                Yes, I tried 6GB extended apps space, but my tablet has 16GB flash memory,
                                so I increased apps space to 4GB only.
                                I don't use the Chrome browser, but if you give me the link to the patch, I try it.
