CUBE Talk9X U65GT_V2.0.7LW_en_Lepi_150228
    Originally posted by M4tchB0X3r View Post
    Brilliant thanks, i do realize that it has to take the space from the sd storage.
    But i have still a probalby stupid question! I just flash this with recovery right? Or do you mean by OTG, to rename it as update.zip and apply it through system update in the OS ?!
    Yes , flash via recovery only. I don't think that is necessary to rename.
    Another solution is to copy the EBR1 and EBR2 files plus scatter file and flash via SP Tools. Now we are in murky waters, My preference is to overwrite the files to Brian's Rom and start from there.
    OTG is outside USB stick via (OTG)cable from USBmini port(charging port). Try it, works perfectly.
      Thx for the help, i'll flash with twrp. thats what i thought, just making sure ^^
      Edit:
      I flashed the 6gb zip. But now it only sees the 6gb app storage. I'm missing the 10gb partition.
        Edit:
        Pls clarify. Do you have a working tablet or not????
        If it works then in – SETTINGS/STORAGE/ – you must have -internal storage – usb storage – SD Card , give me Data for each Total space. Also if you have any data in usb storage.
        Internal storage – aka Memory around 6gb .usb storage – aka Internal storage space around 10gb=16gb, otherwise you must format the Usb Partition using TWRP then re-install Lepi's Rom from SD card.
          Pls clarify. Do you have a working tablet or not????...
          It works. Like I said, it only sees the 6gb internal storage, the others are empty.
          I'm not with the tablet atm.
          OK, I will format the partition from twrp. Sure I need to re-flash the rom? I'll try without first
            The best is to flash EBR1 EBR2 through SP Flash tools.
            Then you see only the Internal storage, Plug the tab to the computer and with a program such MiniTool Partition Wizard ot the standard windows format Utility format the space you don't see, you must see a message of formatting that space.
            format FAT32 and you are OK
              Thx, i hadnt hooked it up to the PC since the partition flash cous i did it on the go. I suspected it would be a formatting thing, but wanted to ask beforehand cous i couldn't check for myself and i actually thought the flash prozess would format the partition itself since a recovery should be able to do that.
              I'm sure i can figure it out once i'm back at the device.
              thx again for the help
              EDIT: Sorted, thx
                EDIT: Sorted, thx
                Hi my friend how many gb you formated the app partition? I Want 13gb but I cannot make it work over 6gb. I have a 32gb tablet.
                  I have the 6GB, so sorry i cant help u with that!
                    firstly, I want to thank you for your great work lepi . I'm really greatful for ROM. I install the v2.0.7Lw and so far everything works fine except the issue of sdcard storage which was the reason I install ur ROM hoping it will correct this issue bcos whenever I transfer to the sdcard be it apk, video and I intend to use it later , the file are often corrupted I couldn't make use of them. so what do u think could be wrong and how can u help
                      [QUOTE=abbey777;293226]firstly, I want to thank you for your great work lepi . I'm really greatful for ROM. I install the v2.0.7Lw and so far everything works fine except the issue of sdcard storage which was the reason I install ur ROM hoping it will correct this issue bcos whenever I transfer to the sdcard be it apk, video and I intend to use it later , the file are often corrupted I couldn't make use of them. so what do u think could be wrong and how can u help
                        Great job!
                        Hi, Lepi
                        I hana say many thanks for your (great) job!
                        I install and, until now, so far so good.
                          firstly, I want to thank you for your great work lepi . I'm really greatful for ROM. I install the v2.0.7Lw and so far everything works fine except the issue of sdcard storage which was the reason I install ur ROM hoping it will correct this issue bcos whenever I transfer to the sdcard be it apk, video and I intend to use it later , the file are often corrupted I couldn't make use of them. so what do u think could be wrong and how can u help? still waiting for ur reply lepi or anyone who could be of help.
                            Originally posted by valerima View Post
                            yes, I have tried MX and all available VLC, kmp, but none worked so far.
                            Looks will return to S.upersports ROM
                            I use Vlc and it works perfectly alright...
                              Using V2.0.9 on new Cube 9x S/N 1430xxxxxxxx
                              Originally posted by Lepi View Post
                              The patch for the visibility of white buttons navigation bar on a white background.
                              upd_U65GT_207LW_navButt_strokeBold.zip
                              Only for modrecovery CWM or TWRP!
                              There are no guarantees! Preview backup is required!
                              Successful upgrade!
                              Hello Lepi,
                              about 5 days ago I received my new Cube 9x U65GT (S/N 1430xxxxxxxxx), and with help of Giouncino I flashed it with your recovery 2850 (beautiful!) and your Rom 2.0.9. (Used Supersport900 EBR-files to increase program-storage to 4 GB too)
                              So far everything works REALLY WELL, however, maybe you feel there is a 'but' coming:
                              Im am a Dutch technician, I live in Spain, so I read a Dutch newspaper site (www.ad.nl) quite often.
                              Somehow, many browsers (Chrome, Firefox, Dolphin..) are not able to display any of the articles.
                              The main page is always showed perfectly, but after clicking on one of the articles, it tries to enter/display the selected article, but the new page is distorted (you see html-code), and 'loops' loading the article.....
                              The stock-browser however works perfectly, all the other browsers work OK on my Elephone P8 phone. (8-core MTK as well)
                              I have the impression the other browsers are 'lagging', or ' sluggish' on the Cube, so at the moment I use the Stock browser who seems a bit more 'snappier' , but I would love to be able to use one of the others as well.
                              Is there anything I can test, or is there any data I can collect?
                              Looking forward to your reply,
                              Un saludo,
                              Satbeginner
                                Try Boat browser, is fast and reliable as stock one!
                                Definitely faster than Chrome.
