Arnova 10 G2 Custom ROM by Finless Version 1.3
    Originally posted by Damo View Post
    That sounds good. If not we could s et up a remote connection between your computer and another with a program called team player, than we could
    Re create the steps you are doing remotly. Just have the firmware folder on your desktop so it is easy to find. Up to you
    teamviewer damo
    http://www.cirrusminor.info
      Originally posted by cirrus View Post
      teamviewer damo
      Dope, that the one, hehe
      </form>
        That sounds interesting. I will do whatever it takes to mget the tablet up and running
          I have sent you a private message if you want to try
          </form>
            Help please....Didn't erase IBD whatever that means??
            Hi all
            I am a new forum member so please be gentle with me!!
            I have 'flashed the ROM' to my new tablet but failed to click Erase IBD as per instruction No 5, a senior moment!
            Do I need to do anything to correct this?
            I was very chuffed that I even attempted this
            but with such good instructions & positive follow up I thought I would do it, not bad for a silver (female) surfer! And I didn't 'brick' it, yet another new term I have learned, means something totally different in the UK.
            Thank you Mr Finless for providing this ROM
            Joy x
              Carrowniskey we have lost connection you need to restart teamviewer again, pm me
              </form>
                Installing Drivers!
                Carrowniskey
                Thanks for the remote connection earlier
                What I did notice was that when your tablet was plugged in, it showed up in the wrong place of device manager due to having it connected to a hub.
                Like we discussed, Put your device into recovery mode, plug your tablet into the USB ports from the motherboard on your PC. When you do this and open up device manager you should notice that this now shows up under UNKNOWN DEVICES. Open device manager and find the device there. Update driver and direct it to the firmware folder/drivers/32bit/win7 and now hopefully this should install the drivers properly.
                Fingers Crossed and let us know how you get on
                </form>
                  Carrowniskey
                  I tried removing all the usb connection but no joy. I also tried iy on my laptop with nothing other than tablet attached - again no go!
                  Thank you for all you help. I think a visit to the shop is all that is left.
                  Folks this is a great site with lots of helpful experts
                    Damo did a tutorial on a laptop that had never had the drivers installed. http://www.freaktab.com/showthread.p...s-for-flashing!
                    Not sure if it will help in your case but it might. Definitely plug your tablet straight into your laptop and not a hub when you try, which I believe you have already tried.
                      Thanks for this I will keep on trying
                        i didnt see it explained so i have to ask - how did the free space get to 1gb? what was removed from the stock firmware?
                        Arnova10G2: USB to Ethernet - PLEASE TELL ME HOW?
                          Nothing was removed.
                          App space or even /system is not in RAM it is in NAND memory.
                          Nand memory holds all disk drives
                          /system
                          /storage
                          /data (where apps go)
                          etc
                          By changing the userdata space value in the parameter file we can go to a max of 1gb for /data (all the kernel will allow). So this took away some of the /storage space from NAND.
                          Why Arnova limited /data to only 255MB in stock ROM I do not know. I think they just used a parameter file from some other ROM that has limited NAND memory. Stupid if you ask me
                            After a few nail biting minutes I managed to do this Many thanks!! I was so worried I was going to mess it up but its rebooted and is working yyyaayyyyy
                            thankyou!!!
                            EDIT: do you have a donate button as I really was at the end of my last nerve not been able to get onto android market
                              thankyou!!!
                              Glad you got it... I think you will love the ROM
                              Yes look at the top menu bar of the web page. There is a donate link up there. Thanks.
                                urm one question i need to do this
                                a) Again using a file manager that has root access go in and delete the follow folders from the /data/data directory.
                                com.android.vending (not com.applib.vending!)
                                com.android.vending.updater
                                com.google.android.gm
                                com.google.android.gsf
                                where do i get the file manager to do it?
                                thanks Bob
