NEW - U30GT H 1.10 900supersport 1.1
    Here's a finalised version of this ROM, it is a full 900supersport 1.1 ROM.
    ROM=>U30GT H 1.1 900supersport 1.1 ROM (274 meg)
    Notes
    • Flashing will delete everything on your Cube consider backing up first and remve any sdcard
    • If you are on the Beta then follow post 15 to get to the full ROM
    Instructions
    • Download and extract to a folder
    • connect the tab to the PC (you did remove the sdcard)
    • start the ROM flash tool
    • put the tab into flash mode, the PC should detect it
    • erase idb
    • flash
    • the tab should boot to recovery (this will take a few minutes)
    • select reboot
    • the tab should now boot
    • first boot will probably complain about the nand simply select and format
    Let me know how this goes.
    So what do you get
    • touch based clockwork recovery
    • 2 gigs apps space
    • init.d support
    • root, debloat, market fixes, english by default
    Finally thanks those of you who downloaded the BETA and confirmed it working, a sepcial to Cel1971 for the testing he put in on the 1.09 firmware, without which this would have taken much longer, and the team here at freaktab, Finless gave me the missing piece to get the kernel sorted, as without their support I wouldn't be doing this.
    Currently the ROM dev's here are putting ROMs on Goggle Drive, DropBox, etc. But as you know these can be overwhelmed with downloads! So our policy has changed. FEEL FREE to put our roms UNCHANGED on mirriors, however can you credit freaktab and include and reference back to the original thread here if you post them elsewhere.
    Here's my BETA ROM for the Cube U30GT H based on Cubes U30GT-H_v1.10_20121130 firmware.
    ROM=> Cube U30GT H 1.10 900supersportROM (272 meg)
    This is the first time I've used drop box so hope this is right. Once we have a confirmation that the ROM works please feel free to mirror but give credit to Freaktab and include a link to this site.
    Notes
    Instructions
    • erase idb
    • flash
    • select reboot
    As this is a BETA I've included a few additional files to help with any problems we may encounter and possibly help with further developments I have planned.
    Finally thanks to Cel1971 for the testing he put in on the 1.09 firmware, without which this would have taken much longer, and the team here at freaktab as without their support I wouldn't be doing this.
    Feedback looks promising.
    See post 15 for an updated kernel giving init.d support
    Last edited by 900supersport; 02 December 2012, 21:37. Reason: prep for removal of BETA and upgrade to 1.1
    900Supersport
    freaktab developer
    Flashed as instructed, all working good so far and will test for the rest of the day and let you know if I find any issues. Like the Touch CWM offered with this ROM.
      Thanks for the feedback
      900Supersport
      freaktab developer
        Thanks, appreciate your efforts in giving us these roms always... i always look forward to them.
        May I ask if the 1.04 vin8ui was ever rooted?
        Also is their a way to preserve your system similar to a backup? i use titanium, but it doesn't seem to image or preserve the core of the OS...
        Thanks!
          just noticed, since official firmware 1.07 the camera's night mode is not working.
            Just flashed...no problems so far.
            Which kernel is installed by default?
            I've got a feeling its not the one delivered with the New 1.10 Firmware, but Im not sure.
              Re: NEW - U30GT H 1.10 900supersport 1.08 BETA
              For recovery then I'm using the kernel from 1.06. If you boot normally then the kernel from 1.10 should be used. What makes you think it's using the earlier kernel?
              900Supersport
              freaktab developer
                The kernel info....I thought I knew it before....but obviously I´m wrong.
                I just flashed...nothing else....so it has to be the new one.
                V1.09 was so much better than V1.07 right?
                I´m really very surprised that V1.10 is another step forward performancewise.
                You can feel it....or is it placebo?
                What others saying?
                Is it better/faster than V1.09 ?
                Tell us!
                  My u30gt h is broken so I am working blind on this. I have to rely on feedback to tell me how good or otherwise the ROM is.
                  What does the system info have to say about the kernel?
                  900Supersport
                  freaktab developer
                    thank you very much and the email too... but i am having a problem downloading from drop box in china.
                    Notes
                    Instructions
                    • put the tab info flash mode, the PC should detect it
                    • erase idb
                    • flash
                    • select reboot
                    • first boot will probably complain about the nand simply select and format format
                    If you would like to support my ROM development then please visit my google site donate page where you can make a paypal donation
                      Is drop box in china?
                      Could be I've exceeded my bandwidth allowance, I'll see what I can do.
                      900Supersport
                      freaktab developer
                        Notes
                        Instructions
                        • erase idb
                        • flash
                        • select reboot
                          thank you...yes seems a problem
                            sorry was using tapatalk and did not see your location. I'll see if I can upload to gdrive.
                            900Supersport
                            freaktab developer
                              I think I have the 1.10 kernel booting standalone now. This should give us the ability to get my customised boot.img into play.
                              Here's the link to the download
                              Cube 1.10 Kernel
                              Instructions
                              • go to the 900supersportROM folder
                              • rename kernel.img kernel1.06.img
                              • rename boot.img boot.img.stock
                              • rename boot900s.img boot.img
                              • rename kernel110s.img kernel.img
                              • Flash just boot.img and kernel.img, no need to EraseIDB
                              • if the tab boots then we are on a full 900supersport 1.1 ROM with init.d support
                              if not undo the changes we have just made and reflash just boot and kernel.
                              Please let me know how this works out.
                              Last edited by 900supersport; 02 December 2012, 13:20. Reason: added rename boot900s.img boot.img
                              900Supersport
                              freaktab developer
