thanks for your rom.
Im unable to flash the right way you rom or any rom with recovery in fact.
Each time I flash the rom, the tab boot in recovery mod with a list of error "E: cant mount/cache; E: cant mount data".
I find a way to flash your rom without recovery using your flash prog.
I just kept checked in flash prog: system, boot, kernel and parameter. In that way the rom is flashed correctly
If i try to add misc the rom tab wont boot; if i try to add recovery after same problem and if i try to flash whole rom i have the recovery loop with "e:/cant mount" error.
If some one have idea about it; anyway i can use your rom ant thats the most improtant
