NEW - U30GT H 1.10 900supersport 1.1
    no wifi probs anymore at all!!!
      problem installing the rom, every time when its checking download data it stops after 27741 size is 440098
      download the file several times.
      anybody idees or a other link , file was 261mb before unzip
        have you tried any other file or is this a special case?
        Share the link with us so we can check...
        I just saw it is a bigger file...the tab shuts down pretty much everything including the wifi-connection when screen is off for a while.
        I remember having that problem myself. Programming error from cube since my galaxy note is able to behave better
        "Solution":
        Keep the tab awake or raise the time to power saving when downloads like this are made.
          The full version should be a rar file of 274 mb. Normally I would expect the un-compress to fail if you did not have a full download. Usual advice is to use a quality cable and rear USB port.
          900Supersport
          freaktab developer
            if that is the problem...how the hell can he tell its a wifi problem.....
              Re: NEW - U30GT H 1.10 900supersport 1.1
              Please don't confuse 900ss advice to spridget's install issue with staygold's WiFi issue? Two different problems from different people....
              @ Staygold my tablet is happily waking up from sleep and connecting to WiFi so no issues for me but in earlier ROMs I had to flash a WiFi fix that mostly worked.
              @Spridget have a look at the other 1.1 (1.07) thread as Magnifico made a good post on how to select and use a quality USB cable for flashing. Maybe he could offer it again here? I vaguely remember the flasher tool crashing during the check on my laptop and if I ignored the pop-up to close it finished checking.
              Sent from my unknown using Tapatalk 2
                the link gives me a 261mb file (https://docs.google.com/file/d/0B7_2...gtclNWOUU/edit)
                how come ? downloaded it many times
                  If Wifi is turning off when screen is off, you might need to change wifi sleep policy.
                  Settings -> Wifi -> Menu -> Advanced -> Keep Wi-Fi On During Sleep -> Always
                  Might help. Might not.
                  Just trying to help!
                  Take care,
                  Stalks
                    I also get a 262 meg file from the link in the OP. Is this correct?
                      On an aside I was using Tabmodder's Infected v2 while I was waiting for 900ss offerings and his build prop allowed Gameloft games to work. I can't get Asphalt 6 to work on this ROM, even with the Build prop changes for Gameloft suggested on Slatedroid. Does anyone have suggestions to get these games working on this ROM?
                        That's the right download. I suspect the 261, 274 is based on binary and decimal thousands (1024 and 1000 respectively).
                        Has anyone sucessfuly downloaded and installed from this link.
                        900Supersport
                        freaktab developer
                          Originally posted by 900supersport View Post
                          What wifi issue?
                          this problem:
                          It came whilst I was on the 'cleaned' 1.04 rom. I was happy with that rom and tablet worked fine. suddenly wifi stopped working. it came back the following day then went again and never came back. i have used every rom in the universe and no luck. my seller tells me to send it back to china but i am still trying to fix it myself.
                          any help is welcome. I believe it is a hardware fault but want to exhaust all scenarios before i send it back
                          thanks
                            Take care,
                            Stalks
                            appreciate the response, i have tried it already but no luck. some people mentioned this works if you manage to connect, but i cant..
                              I was wondering why magnifico was banging his head on the well with what I said lol
                              what fix did you flash please?
                                You could open up the tab and check the soldering on the cable from the main board to the wireless receiver. Its a coaxial cable and both the inner and the outer should be connected.
                                900Supersport
                                freaktab developer
