NEW - 900 Supersport 1.1 rooted ROM for Cube U30GT Mini 1.05 16 Dec 2012
    Help
    So, can't wait anymore.
    -Erased NDB
    -Flashed ROM
    -Reboot, but it goes into CWM instead formating partitions and boot OS
    It seems it has not formated partitions
    Now I'm stuck into CWM
    Should I format myself some of the partitions with mounts and storage ? (wich ones)
    Should I go for a flash with 1.04
    Is ther a way to finish from CWM ?
    E:Can't open /dev/block/mtdblock1
    (no such file or directoryu)
    E:Can't mount /cache/recovery/command
    E:Can't mount /cache/recovery/log
    E:Can't open /cache/recovery/log
    E:Can't mount /cache/recovery/last_log
    E:Can't open /cache/recovery/last_log
      In the manual is only this: "At the clockwork screen press the power button to restart"
      I think that everything is deleted in the correct installation procedure.
      I apologize for my English, most of the text translates uncle google
      Sorry for my english.
      SK-CZ XPERIA TEAM BLOG - All of our projects one common... (ROMs, addons etc.)
      SE xperia NEO V - root, unlock BL, SK-CZ xperia team EDT2
      CUBE U30GT mini white - root, 2GB ram
        That's what I've done (hit the power button)
        I'll try the 1.04 if I can go again in flash mode.
        Regards
          Re: NEW - 900 Supersport 1.1 rooted ROM for Cube U30GT Mini 1.05 16 Dec 2012
          First option in cwm is reboot, press this.
          The tab should now boot, it will take a minute or so.
          900Supersport
          freaktab developer
            Regards
            No more chance with 1.04...
            In a hurry, I've tried to flash the kasty_cube 1.05, with the standard RBT 1.5 and it has worked fine.
            I got french and AZERTY keyboard. No mor process.acore errors and what seems to be a fully functional system like what I'm used to from years with Android...
            Thanks everybody.
            May be I'll be back here in a time to try again your firmware.
            But I was in a hurry to have a working device at Xmas, and I leave for hollydays tomorrow...
            See you later...
            ps: reply to the last post of 900ssport while I was writing this: I'd tried to choose the first option many times... after 1.05 and 1.04... no luck...
              You need to do it in a calm, always in a hurry anything can happen.
              Have a nice Christmas.
              PS: what charger you have with your cube?
                The one that HongKongGeek has supply with it to me
                Power-Adaptor
                Model : HN 528
                100-240VAC0.3A
                50/60hz
                Output 5v 2000mA
                Happy Xmas and Happy new year 2013 (if there is one
                Alni
                ps: I was in Yucatan last month for hollidays, and mexicans were solding 2013 calendars...
                  Cube 30gt Mini +Azerty
                  Hi everyone,
                  I received yesterday my U30GT Mini for a young girl as Xmas present.
                  But I'm very disapointed by the stock firmware and lots of annoyances like "android.process.acore" bugs coming out each time the keyboards pop up or when trying to change language settings.
                  The french language is not good, and the keyboard attached is not even AZERTY.
                  Of course I've tried the stock reset with no success.
                  I'm on the way to try an alternative firmware, and wonder if I can flash your 1.05 based firmware from my stock 1.04.
                  Can I flash it ?
                  Will I have a good french localisation with AZERTY keyboard ?
                  regards from France...
                  Cube 30 gt mini has an azerty keyboard setting included into the standard Android system. No need to flash a new rom. Beside of this, if you want to use an external Azerty keyboard there is an App allowing this.
                    He had more problems with ROM (android.process.acore) and reset did not help him.
                      When did he have these issues.
                      On my last install I flashed the full Rom. From recovery selected re-boot. After the reboot I went to settings, storage, mount sdcard, format.
                      To get the keyboard working I copied the LatinIME.apk to the sdcard then used explorer to browse to it and pressed it to install.
                      I could then setup my accounts etc.
                      I'd advise following this process and then maybe installing an alternate keyboard.
                      900Supersport
                      freaktab developer
                        This ROM is really good. Thank you for your effort!
                        No problems with flashing, and functionality is incredible. Keyboard apk install smooth as well.
                          Will You upload Cwm rom update zip?
                          Its safer than other flashing methods.
                            My mind: no, because the flash ROM also with kernel
                            But maybe I'm wrong.
                              Hamry is right in that to take advantage of the newer kernel and boot.img the ROM has to be flashed via USB. I plan too look at updating via cwm but any such update will be partial, either no kernel update but updated boot and system images or kernel, stock boot image and system.
                              900Supersport
                              freaktab developer
                                I cant save images to my Cube, I have the SDCARD in and VLC media and Astro File Manger recognises its there and it can see the files on it. But when i open Gallery it says No external Storage Available. I formatted it to FAT32 if that helps
