To check open system, storage look for nand flash, you should see about 14 gig. If that is OK then I'd check the sdcard using windows.
NEW - 900 Supersport 1.1 rooted ROM for Cube U30GT Mini 1.05 16 Dec 2012
That sounds odd, did you format the 'internal sdcard' on first boot?.
To check open system, storage look for nand flash, you should see about 14 gig. If that is OK then I'd check the sdcard using windows.900Supersport
freaktab developer
Gameloft bug in rom?
I have seen some reports on this forum regarding some Gameloft games going into a loop when trying to start. For example Asphalt 7 seems to start fine, but then loops when trying to check license and go into the game menus.
I have had this also happen on Modern Combat 4.
However, some other Gameloft games work fine!
Is this a bug with regards to the license check from Gameloft, or is it a bug in the ROM of some sort?
Thanks for all help!
problem
Well I have a problem, I have tried to instal new ROM to my Cube U30GT-M and it failed while updating... now I have only acces to Android system recovery <3e> and I have no idea how to fix it. I tried to reboot but with no results. Please help
Edit:
I also try to flash my tablet again but flash tool dont see tablet and windows cant instal driver.... PC see just unknown device U30GT-MLast edited by Donar; 22 December 2012, 17:11.
Re: NEW - 900 Supersport 1.1 rooted ROM for Cube U30GT Mini 1.05 16 Dec 2012
Put it back into flash mode and reflashing. Try a different usb port (at the back of the pc) and if possible different cables.900Supersport
freaktab developer
Originally posted by jab132 View Post1.04 with me.. if i put the charger plug in tablet restores itself over and over again..i have 2 tablet was the same problem
the problem was resolved in the updated 1.05
Probably not to both questions.
It is possible to make up a battery pack that you can charge from but this requires some soldering skills.900Supersport
freaktab developer
Okay... ;/ But now I have default china rom, 4.1 and kernel 1.04 i think, and there are a lot of chinese apps. I downloaded app killer but they still launch. I think they consume battery also. And by the way, what do you think about underclocking? I found some apps in Google Play, such as Antutu and they allow lowering Maximum CPU frequency. Would that improve battery performance and would system be stable if I underclocked it for like 300mhz (to 1300Mhz Cpu frequency) ?
I'd not noticed that, did notice the antutu score of 11,800. Most importantly I like the performance and usability of the tab.900Supersport
freaktab developer
Tried with full hd 25 frame Mov video (made with my Canon eos 550d) but sometimes froze the Cube sometimes played not smoothly and slow motion. When i bought this machine that was on the description : support full hd 1080p video.... its look like the hardware is weak for 1080p or may i have to try different players, any advice?
There are currently 1534 users online. 0 members and 1534 guests.
