iMito MX1/2 - Finless ROM 1.5 - Root, debloat, init.d support
    USB LAN hang up
    Hello, Bob
    Thank you very much for your work! 1.5 1080 is the best! But I have one problem - today try USB2LAN adapter http://www.****.co.uk/itm/221120582009 and it get correct IP, start download but in several seconds my UG007 hang up. Only turn off can help. what do you suggest to me? may be this is common problem? may be I should replace several drivers in firmware or send you some logs?
    thank you
      Lots of people are having issues with that specific adapter! The recently changed the chip in it and the driver for Android appears to have a problem. Sorry... But there are many posts about it here. Mostly I think in the MK808 forum.
        USB LAN hang up
        Bob hello
        I found drivers for my USB LAN adapter. Can you explain me where should I place it?
        http://forum.x-drivers.ru/index.php?...e=post&id=2049 this is a link to archive with android and other drivers. I can't do it myself if you would so please to help me.
        Thanks in advance
          Originally posted by tredn View Post
          Bob hello
          Thanks in advance
          OK so those are the sources and need to be compiled for the specific kernel. However people have tried this as well. The driver code itself seems to have a bug for Android is what people are saying.
            US to LAN
            Hi Bob
            I found what is the problem - my hub! when I connect USB2LAN adapter directly to my UG007 it works good. But one problem - speed is only 10 mbps. Is there any option in firmware to turn the speed 100 mbps? thanks
              No, Android seems to only support 10mbps.
                USB2LAN
                Bob,
                I found in linux command to set the linkspeed of eth0 - ethtool, mii-tool. So we don't have analog command or utility in android? Does android have any configuration file to set up the link speed? Otherway all USB2LAN adapters are absolutely useless because of very low connection speed.
                  Remote problems
                  Unfortunately I cannot get any remote app to work with my MX1 with finless 1.5. Tried many different ones, including google tv remote, rkremote, rockchip remote. Non of the apps manage to find my MX1, even though they are on the same network. Does anyone have an idea what could be the problem?
                    Download file fail
                    Dear all,
                    do you have any idea how to fix this issue ? I try two usb cables, two computers (win7 and XP) and result still same
                      Try this fix!
                      http://www.freaktab.com/showthread.p...some-USB-ports!
                        Hi Bob,
                        unfortunatelly it didn't help
                        Erasing ok, writing ok, checking at 52k ng
                          Originally posted by kastan4175 View Post
                          Hi Bob,
                          OK I had a very similar problem. My cable was bad. When I moved to a different USB port on my PC it would work sometimes. On another port it would fail just like you are having every time. Finally got another cable and it stopped failing. The connection pins on the micro USB port are cheap and just a small resistive connection will cause download or download check failure.
                          Best I can tell you at this point.
                            iMiTO Finless ROM 1.5
                            Thanks for this v1.5 custom ROM, super smooth!
                              iMito MX1 doesn't turn on.
                              Hi, i have a problem its start 3 month after i got it and use it ok. i try to turn it on and its just staying on the screen that say's: "iMito MX series" at the beginning. i tried many other usb's cable and its just staying on that screen and won't turn on! what should i do?
                              Thanks you!
                                I bought new usb cable and it's working... It's very interested how sensitive it is. Thanks Bob
