WOAH ! many thanks !!
Recovery with ROM dump
OK Screech...I'm uploading a ROM for you.
Your tablet looks just like the Pipo M1 Max. The interesting thing about it is that Pipo has released an Android 4.2.2 version of the firmware for their M1. You might consider trying it...it might work. This tablet may be an OEM version of the Pipo M1 Max. I have done a custom ROM for the Pipo M1 Max, here.
I have cooked a ROM based on your ROM dump. It took a little while because I had to recreate a system.img file from your dump.
It is rooted with 2gb user app space. I added Init.d support and added busybox commands.
I included both the stock recovery and the generic 3066 CWM Recovery. The CWM is the default...if it doesn't work, you can revert back to the stock recovery by renaming the files in the RileyROM folder.
See the Read Me First file for flashing instructions.
Here is the link to the Download
Randy
Clearly I can't test it, but what I have run into using the generic CWM you have to jump through some hoops to get it to work. After flash it boots first to CWM. Highlight Reboot to system and press the power button and it will boot to the system. Let it initialize all the way the first time and you will see a notification that the sd card is damaged...just touch on that and format your sd card. Then you are good to go.
I think I forgot to include the Petrus Reboot app. You can download it and install it yourself so you can reboot to recovery...here.
Let me know if everything works, and I'll create a new thread just for this tablet.
If this ROM makes a difference for you, please consider a donation to support future RileyROM's here at Freaktab.com Donate!!!Randy
A BIG THANKS !!!!
Originally posted by rrileypm View PostClearly I can't test it, but what I have run into using the generic CWM you have to jump through some hoops to get it to work. After flash it boots first to CWM. Highlight Reboot to system and press the power button and it will boot to the system. Let it initialize all the way the first time and you will see a notification that the sd card is damaged...just touch on that and format your sd card. Then you are good to go.
Hi, i'm downloading right now ... thanks for your time i tell you if work and how it work
and if make some difference i sure donate you !
i also try PiPO M1 4.2.2 rom ... and tell you if work !
Sure, man...no problem.
This was a first for me to start from scratch with a whole new system.img. Hopefully I got all the permissions set right.
I'm at work till late tonight, so any tweaking will have to be done tomorrow.
I really hope my Pipo M1 ROM works for you.
RandyRandy
Good Job Randy!
It is normal for CWM to act that way on first boot. After you manually format the internal memory it should mount everything. Sometimes it just won't though.
RandyRandy
Ok just try flashing the stock recovery. You might be able to add CWM later.
Did you try the Pipo M1 ROM?
RandyRandy
R: Recovery with ROM dump
Originally posted by rrileypm View PostOk just try flashing the stock recovery. You might be able to add CWM later.
Randy)
I have try pipo M1 ROM and when boot the screen flash and next all black ... If I leave USB cable connected I see in tool "mass storage connected"
Now I have to exit to eat something ... But I can reply with my smartphone ...
Thanks for the assistance too !
Inviato dal mio Nexus 4 con Tapatalk 2Last edited by screech; 18 May 2013, 01:17.
There are currently 2054 users online. 0 members and 2054 guests.
