Recovery with ROM dump
I have not worked on a CWM for a long time now. I am sure Randy can get one figured out for you. I don't have time right now sorry.
Originally posted by screech View Posti try this parameter just now ...
edit: WORK !!! many thanks !!
next step is cmw ... if i don't bother you
p.s. is possible to have a PARAMETER with 4Gb or 8Gb ??? (if you tell me how i can change myself, if is easy)
I'm afraid I'm not the authority on CWM either. Fun has made several on his site for specific devices. Since we failed with the generic version, you might ask him for one for this tablet. Just share him the link to this ROM.
Meantime, I'll create a new thread for this Rom.
RandyRandy
Randy, his error messages tell whats going on. The mk4fs binary is not compatible with this recovery kernel. Or the MTD block is wrong.
If you take the mk4fs binary from /system/bin of your ROM and put it into the sbin folder of the recovery. It may solve it. Also check the fstab in recovery and make sure all the block defs are correct.
Sounds good.
We had some really bad weather here for a while, so I was away from my computer.
I'll take a look at that recovery.
I've already put together some parameter files for this ROM.Randy
Originally posted by Finless View PostRandy, his error messages tell whats going on. The mk4fs binary is not compatible with this recovery kernel. Or the MTD block is wrong.
RandyRandy
There is a mke2fs.
RandyRandy
Is this 4.2.2 or when the stock recovery boots, what version of recovery does it say?
Oh and sorry if this is 4.2.2 the binary is called
make_ext4fs
His recovery gives that name on the screen shot so I assume it's there at least in recovery.
If's it's not in /system/bin then take apart the stock recovery and get it from there.
I think this is 4.1.1.
Anyway, neither of those files exist anywhere.
RandyRandy
yes it's 4.1.1 ...
now the tablet is better, thanks to Randy i have 2Gb partition and, most important, a recovery ROM !!
when you have time (Randy) and if you want, can you help me found a working CMW ? many thanks, you are very helpfull !
can i share your work ? i'm moderator of a italian android forum ...
Thanks for your help. I posted a new ROM in the MID Rom section if you want to provide a link to it on your site.
I'll keep working on a CWM as I get time. Right now I have two other ROMs to get out.
RandyRandy
I think the reason it freezes is that CWM has the wrong kernel inside it. I'll see if I can get your correct kernel into it and hopefully make it work.
RandyRandy
Yes, I tried mixing 4.1 stuff with 4.2 stuff, but nothing ever worked...too much difference.Randy
R: Recovery with ROM dump
Originally posted by rrileypm View PostYes, I tried mixing 4.1 stuff with 4.2 stuff, but nothing ever worked...too much difference.
6 and 8 give me 127Mb of system partition
And 4 give me correct amount of system but 0 for internal SD card ...
I flash 2gb now and continue testing and search for CMW ...
Inviato dal mio Nexus 4 con Tapatalk 2
There are currently 2874 users online. 0 members and 2874 guests.
