Recovery with ROM dump
Thanks Neomode.
I'm not sure I set the permissions right when I copied the system.tar contents into my new system.img. Maybe there is a step I missed. Can you convert the tar file to an img without loosing the permissions?
RandyRandy
You cant just make a system.img from a CWM .tar file using simple file copy.
CWM uses a Edify script to copy the files and set permissions and make symbolic links. So you can convert a .tar to a real system.img but you have to write a script to do it.
I just ran this system through your script. There was only one error of a recovery install sh file that wasn't there. Otherwise, it worked well.
I'm uploading this new version to my tester.
RandyRandy
Screech, I'm uploading now.
RandyRandy
Randy
Ok now that we know it works I'll do a parameter file for 2gb for you.
I took it as back to stock as possible to get the thing working.
RandyRandy
R: Recovery with ROM dump
Originally posted by rrileypm View PostOk now that we know it works I'll do a parameter file for 2gb for you.
Randy
Meanwhile I can try to find a working CMW for my tablet ...
Inviato dal mio Nexus 4 con Tapatalk 2
Originally posted by screech View PostThis one work ! No 2gb partition ... It's my original ROM ... But now I can try some mods and to install cmw ...
Glad my tips on the script and how to convert from a .tar file worked!
It took me like 4 hours to put that together starting from scratch.... I am glad it is paying off.
Neomode... NO... you don't get the script! Only Randy gets it.... You must do it yourself....
Kidding.. check my post in the Dev forum about it.
Enjoy,
Hi finless ... i see a CMW modded by you for PIPO U1 ... i try it and give me some errors (like Randy's CMW)
you can't build it one for my tablet ?
i post a image of errors (same errors with Randy's CMW)
Unlimited space to host images, easy to use image uploader, albums, photo hosting, sharing, dynamic image resizing on web and mobile.
this images are from Randy's CMW:
thanks in advice.
Mauro
Try this parameter file
You mentioned you didn't have 2gb app space.
Try this parameter file. It should work:
ParameterRandy
There are currently 2174 users online. 9 members and 2165 guests.
