MK808 - Finless 1.6 Custom ROM
    Help!!
    I trying to install rkremote and xmbc but when i click on app i got 2 options cancel or install. it wont let me click install but will let me click cancel. I have checked sources etc in settings. I tried using es explorer. I also gett launcher stopped working a lot. Any ideas
    Apps from Play install fine
      When I click on "Reboot to flash mode" the program gives me an error message "Flash mode Failed"
      ( in the bottm of windows I have "fOUND rK808 MASS STORAGE"... now I've installed 1.5a on the 808 so I already have the drivers!
        Originally posted by exglynco View Post
        No, Finless 1.6 is based on JB 4.1.1. Multiple user support was introduced with JB 4.2.
        Sent from my MK808 using Tapatalk HD
        I hope in the next future ;-)
          @ andr3a
          Mr.Finless say, in "readme" file : "If you do not ever see the flash tool say "Found RKAndroid MASS Storage USB" or reboot to flash mode does not work, then use this manual proceedure.
          1) Have the USB cable unplugged.
          2) Near the HDMI port are 2 holes in each corner. One is the blue LED hole.
          The other in the corner is a reset button under the hole.
          Use a paper clip or something to push the reset button in this hole.
          I actually enlarged the hole so a paper clip would fit.
          You will feel the button "click" when you are on it.
          3) Hold this button down and while holding it, plug the USB cable from the PC to the OTG port on the MK808.
          4) YOu should here windows BONG it found a new device. The LED will not light!
          5) You are now in ROM flash mode. Read below for installing drivers."
          Good luck !
            R: NEW - MK808 - Finless 1.6 Custom ROM
            Ah ok I Disney Read "or The flash doesn't works".. Tnx Very much. I'll try !
            Inviato dal mio Galaxy Nexus con Tapatalk 2
              hey, how can i turn the stick on after i turned it off?
              My remote does not work
              Any iPhone app or something?
                Unplugged it and plug it again, thats your only option (you can also use the switch on a power bar if you prefer).
                  The system.img is not in the download. Than you get the error message (Flash mode Failed )
                  (it is not MSC device). Maybe I have it wrong I'm not a software expert. Sorry for my bad english I'm dyslexic.
                    Originally posted by fratello View Post
                    @ andr3a
                    Good luck !
                    I try to put it in reset mode but doesn't works! I hold the button ( usb cable unplugged) and then i insert the usb cable and I hear the sound on windows but than the blue light is off
                    the key doesn't automatically turn on!
                      Thank you!
                      I just wanted to say thanks Bob!
                      The flash process was extremely easy, the only hard part was getting the drivers installed.
                        andr3a :
                        -Unplug everything
                        -Plug the USB cable into your PC (use USB port located at back of PC, not in front !)
                        -Press with paperclip the hidden button and HOLD IT DOWN
                        -Plugin the microUSB cable in to the OTG port of MK808 (while still holding the paperclip button down).
                        The PC should almost instantly beep and you are in flash mode !
                        The MK808 doesn't require a 2nd cable for power. The MK808 WILL get power and run from the PC over the OTG port. So the only thing required to be connected is the PC-OTG cable. You don't even really need HDMI to flash these.So check your USB cables if you run into problems. The Hidden Button needs to be pressed and held before powering the unit on.
                        Also, check/change the power adapter (5 volts @ 2 Ampers !).
                        LE : With original USB cable delivered with my MK, I was unable to re-flash my stick. I used an USB cable from my digital camera (Canon) and all worked smoothly !!!
                          Blue screen
                          I can not get him out of the blue screen. I can do something?
                          thanks
                            andr3a
                            Check FinlessROM folder there is no system img. You must put the system.img in the FinlessRom folder
                            then it works.
                            -Unplug everything
                            Open the rkadroidtool v1.35 see if the mk808 connect
                            Press the button in the flash tool "Erase NAND (IDB)". Let it finish.
                            YOU MUST DO THIS OR THE FLASH WILL NOT WORK!!!!!
                            Press the "Flash ROM" button. It will take several minutes to do it's thing. Watch for errors!
                            After flash and no errors, the mk808 will reboot.
                              Every game or emulator I've tried suffers frame drops or stuttering, is everybody having the same problem ?
                              It only works well for browsing internet and watching videos.
                                Yes, I tried this procedure step by step but doesn't works... I'll try to change usb cable!
                                andr3a :
                                -Unplug everything
