New - Archos 80 Cobalt 900supersport 1.1 ROM
    Shame! I'll keep trying to build. I guess I'm learning something this way anyway! Running into problems with missing proprietary code etc but I reckon if I exclude it all there are already prebuilt libraries on the device. Just constrained for time just now with exams coming up haha.
      Same problem as this, except im a bit new to this and unsure on how he resolved it stated in his edit part. Any help please, greatly appreciated
      Edit, changed it from 0 to 1, still no luck.
      Also, i have previously rooted my tablet from the XDA forums, if thats any useful info into helping me.
      I also get device unable to install after plugging it in by usb attempting to get into flash mode
      Originally posted by millski View Post
      The rkandroid tool refuses to recognise my device, which is correctly showing up as RK30 in device manager. Can't flash ;(
      EDIT: Fixed it, changed SUPPORTUSB11=0 to 1 in Settings.ini. Flashing now...
        Hello all, I still have my problem with the tablet being unable to charge. Does anyone know a way I can flash the original ROM and recovery again so i can return it to tesco for a replacement?
          Hi, I had this problem in the folder you extracted the zip file to there is a file called settings.ini open it with notepad and look the line: SUPPORTUSB11=0 change the 0 to 1 so it looks like this: SUPPORTUSB11=1.
          It should see your tablet then.
            Managed to do that, still no luck.
            When i look in device manager, it's a "unknown device", but when the tablet is turned on it's reconised as ARCHOS.
            I'm not even sure if im getting into flash mode. Followed the instructions, but hard to tell :|.
              Is your device showing up as 'RK30' in device manager?
              Make sure the tablet is switched off and the USB is unplugged. Hold volume down button and plug in the USB. Your computer should detect a new USB device, when it asks for drivers/when you look in device manager and find the device with no drivers (yellow triangle beside it) install the correct drivers for your operating system from Supersport's rom download. Your device should now show up as RK30 in device manager.
              If you have RK30 in device manager the flash tool should recognise it and say so along the bottom in large black letters. If it doesn't try editing the Settings.ini as described and run the flash tool again.
                You haven't installed the drivers. Double click the unknown device, hit update driver and browse to the correct driver from Supersport's rom download.
                  Ah, major thanks. I didn't know i had to install the RK30 device. Like i said im new to this, so totally missed that step. RK30 device is now showing after selecting my OS.
                  It's now found my device.
                  I should be able to take it from here, i'll let you know when its done .
                  Thanks again.
                  Edit: All good and go, system has been rebooted. At the last stage of starting off with a fresh-like tablet... (whoop whoop).
                  Thanks for the rom and to the couple who just helped :}
                    Re: New - Archos 80 Cobalt 900supersport 1.1 ROM
                    That unrecognised device sounds like you don't have the drivers loaded for flash mode.
                    900Supersport
                    freaktab developer
                      Millski's help, helped me realise that After that, it was a stroll in a park. Missus is already happy with being able to have twitter on/halifax and natwest installed lol.
                      Thanks for the work
                        Managed to get mine back to stock from the XDA root tutorial thread, time to try to get a replacement from Tesco!
                          Ive got an odd charge thing with mine if its turned off and i plug the charger in it will switch on and fully boot, on the second unrooted one this doesn't happen .
                            Yea that happens on mine too, plug charger in, it fully boots.
                            Well i went to Tesco, as yoou would expect they had sold out everywhere so i was facing a refund. The woman testing the tablet somehow found a random charger in the back . Plugged the charger in and it worked, turns out it was the charger! Just for anyone with this problem in the future: I had tested the charger and it was producing 4 volts, i thought this would be okay ... turns out it wasn't.
                            Anyway all good now .. apart from the tablet telling me there is a corrupted SD card in when there isn't, odd.
                              do you have an sdcard it the tab? If not it may be that the internal sdcard needs to be formatted.
                              900Supersport
                              freaktab developer
                                Great work 900super sport, been following this for a while now, looking forward to flashing, also, does the rom still boot up with the default Archos logo, or have you changed it?
