New - Archos 80 Cobalt 900supersport 1.1 ROM
Originally posted by 900supersport View PostFrom google play search ron android terminal, you should be able to install android terminal emulator. Then follow the instructions from earlier on.
Alternately visit the app dev forum and look for petrus's reboot app.
Any major update say to Jelly Bean would require a new kernel and so flashing via usb.900Supersport
freaktab developer
Hey
Ive been trying to do this, ive started off by downloading the Rom pack and then i hold down the - volume button and plug in the usb device to the pc. It comes up on my device manager under "Other Devices" unknown device with the triangle, i then have tried to update the drivers with the Rom Pack but i get this:
im really stuck and want to be able to get this ROM! thanks for any help
Thanks!
CWM problem?
I just did a CWM factory reset & wipe of the cache & Dalvik cache but after this the tablet would not boot & stuck at the splash screen. I managed to do a CWM restore & it's now running fine. Is there likely to be a glitch with CWM? I gave it a good 25 minutes to see if it would eventually boot.
Re: New - Archos 80 Cobalt 900supersport 1.1 ROM
Just tried that, booted up just like a new tab with set up wizard. Now testing the restore.900Supersport
freaktab developer
I have installed the rom but now every time tablet goes idle and comes back on wifi goes crazy. It was not happening on the factory preinstalled rom. What has been done to the wifi module? I would like to revert that setting to the factory although i like the fact that icons on the desktop are being placed correctly now. Overal feel of the system is still not as smooth as it should be but I'm sure that any further developments will improve that. Thanks for a great work supersport.
Originally posted by fuegos View PostI have installed the rom but now every time tablet goes idle and comes back on wifi goes crazy. It was not happening on the factory preinstalled rom. What has been done to the wifi module? I would like to revert that setting to the factory although i like the fact that icons on the desktop are being placed correctly now. Overal feel of the system is still not as smooth as it should be but I'm sure that any further developments will improve that. Thanks for a great work supersport.
Originally posted by paradox View PostTo make Tunein Radio and other apps compatible in the market add the following to /system/etc/permissions/tablet_core_hardware.xml
Apps STILL listed as 'incompatible' in the play store:
Gumtree - https://play.google.com/store/apps/d...umtree.android
My XBOX Live - https://play.google.com/store/apps/d....microsoft.xle
I've been looking at implementing Christian Troy's Gameloft fixes, now have asphalt 7 working on my cube mini. All being well I'll have the fix available for the Cobalt at the weekend.900Supersport
freaktab developer
There are currently 2926 users online. 0 members and 2926 guests.
