If anyone is keen I'll put together a post with details. Plan to look at creating a deploy.zip for use with CWM to simplify matters.
New - Archos 80 Cobalt 900supersport 1.1 ROM
cifs support
Originally posted by t-bon3 View Post
If anyone is keen I'll put together a post with details. Plan to look at creating a deploy.zip for use with CWM to simplify matters.900Supersport
freaktab developer
Originally posted by 900supersport View PostI've got these working by adding the drivers and setting permissions, then making use of init.d support to load them on boot.
e.g. insmod /system/lib/modules/cifs.ko
User will still have to copy the cifs.ko to that location and set permissions.
Or before the insmod you can set permissions for them with chmod and chown commands.
OR if you really want to make it easy for the user... put the cifs.ko module in /sbin in boot.img
Aftermount commands:
copy cifs.ko to /system/lib/modules
chown
chmod
insmod
But as you know ever boot it will copy the ko module. So not the most elegant way but works.
My thinking re deploy by clockwork and load via init.d is that the same deploy will work on all my cube roms too. Besides I've been looking for an excuse to experiment with CWM deploys and inti.d :-)900Supersport
freaktab developer
Re: New - Archos 80 Cobalt 900supersport 1.1 ROM
All i ever get is an error mount share failed no such file or directory in cifs manager. I know I have typed the shgare correct as I went as far as backing up cifsmanager in titanium on a working phone and restoring app and data on my archos (to rule out any typos) but still the same error. Now if i put in a false share on my phone I get an error of mount share failed no such DEVICE or address, so a different error than the archos.
Sent from my ARCHOS 80 COBALT using Tapatalk 2Last edited by stevvieb; 06 January 2013, 18:17.
Ok you will need esfileexplorer or equivalent as you need to be able to copy to system.img
Insrtuctions- Download the zip and extract the files.
- Copy the two ko files to /system/lib/modules
- Long press each in turn select properties and set permissions to rw-r--r--
- Copy 010insmod to /system/etc/init.d
- Long press it select properties and set the permissions to rwxr-xr-x
reboot the tab and after booting start a terminal (i use android terminal) and from the prompt enter lsmod and enter.
Hopefully among the modules listed will be cifs and md4.Attached Files900Supersport
freaktab developer
Originally posted by 900supersport View PostOk you will need esfileexplorer or equivalent as you need to be able to copy to system.img
Glad to hear it works, and for an even easier install I've wrapped the files in a cwm zip.
instructions- download the zip to the internal sdcard, do not extract
- reboot the tab to recovery (i've included Petrus's reboot app in the system tray)
- from recovery select 'install zip from sdcard' (scroll with vol +-, select with power)
- select 'choose zip from internal sdcard'
- navigate through the folders etc to find cifscwm.zip and select
- scroll through the nos and select 'Yes -Install cifscwm.zip' and let it do it's stuff
- select go back and then reboot systm now
Your done :-)Attached Files900Supersport
freaktab developer
Guest
I used the zip method and it installed fine. I see the modules listed when using a terminal.
Feel a bit stupid now though. How do I see the shares I have on my LAN - I have a NAS drive?
Thanks..
Edit.. Sorry ignore that. I found cifsmanager on playstore and see now
Thanks for confirming the cwm install and answering the difficult question yourself ;-)900Supersport
freaktab developer
Guest
Not a problem at all. I'm sure I speak for a lot of people, your work is very much appreciated.
I must say adding this CIF function is extremely useful. It's so handy having one icon access to my shares.
Thank You.
Help! My device comes up as ARCHOS with an orange triangle beside it and it wont let me install the driver. It comes up with the error "Windows could not find driver software for your device". The tablet is rooted, it's off and in flash mode and I've tried it with USB debugging off and on. I'm using windows 7 64 bit.
USB debugging will make no difference in boot loader mode. I take it to enter flash mode you have the tablet turned then hold power - and plug in USB. Release power minus after a few seconds. The tab screen should remain black. Hopefully windows should detect it and you can select the drivers from the ROM kit. I've read of people having to enable unsigned drivers on more recent versions of windows.900Supersport
freaktab developer
- from a rooted tab with a terminal emulator. Connect to the PC by USB then on the terminal emulator you can enter
Code:su reboot bootloader
i have done all the above , but dont now how too go about doing the last bit, & also dont now what terminal emulator is
can anybody please help with this
From google play search ron android terminal, you should be able to install android terminal emulator. Then follow the instructions from earlier on.
Alternately visit the app dev forum and look for petrus's reboot app.900Supersport
freaktab developer
There are currently 4148 users online. 1 members and 4147 guests.
