Originally posted by triplesilk View PostMy Works @XDA:
AVD Rom Xperia J The Way Stock Should Be
Pre Root Xperia J 4.12
Deodex Xperia L
Deodex Xperia Z kitkat
Stock Xperia Icon's For CM11
Originally posted by triplesilk View PostI'm in the same boat. Prahjister kindly sent me a ROM for the non-B to test that seems very fast and the wifi seems to work (had a drop out here and there but that could always happen). It freezes all the time though, for me anyway, so I can't use it.My Works @XDA:
Deodex Xperia L
Which rom should I install?
Wifi and Bluetooth don't work on Finless 1.0 and 1.1
Purchased from Gearbest
Any chance I can get a zip file to install? I can't seem to get teh image flasher to work in WIndows 8
You may only view thumbnails in this gallery. This gallery has 5 photos.5 PhotosLast edited by Roy360; 11 June 2015, 22:17.
Originally posted by Finless View PostUPDATE March 24, 2013:
I have added the 1.7 ROM for the MK808B V1 Clone. Consider it a BETA TEST ROM for now. Remember I cannot test this so I do not know if wifi and BT will work!
All the other models MK808, MK808B, MK808B Sunvel Clone are working as desired.
Enjoy,
_______________________
Features and release notes for my 1.7 ROM:
This is an entirely new system. This is not much from the original MK808 ROM in this as fas as system goes.
Many features from my 1.6 ROM are of course in this along with new features.
BE SURE to check out the mouse wheel ZOOM function to enable google earth etc to zoom!!!!
Set it by going into settings>accessibility> and turn on mouse zoom!
1) New "auto hide" status bar! To enable this go into settings>Display and turn it on.
Now anytime you run an APP it will automatically hide the status bar. Please note, some badly written APPs
can leave you in a stuck condition that you cannot exit the APP. You will need you keyboard exit key.
2) While you in settings>display there is another feature to force the settings menu icon in the status bar.
It is 3 dots vertically. Now anytime you in a APP that has a settings capability, if you click that you get settings!
3) Lock screen is back friends! Now is settings>security you can
A) Disable the lock screen completely (default is slide)
b) Setup a pattern for lock screen
c) Setup a PIN for lock screen
d) Setup a password for lock screen
4) Sleep is back like a tablet!!!! Go into settings>display and you can turn on sleep!
Now understand how this works
a) If there is no wifi or ethernet connection the MK808 when it goes to sleep will power off.
b) If there is a connection, it will simple go into low power mode and turn the display off. Moving the mouse turns it back on again
5) I enabled location services. This is now in the settings menu. Tested and working with all APPs that use it.
remember to turn off GPS as we have no GPS.
6) New "grid" style launcher available as a choice of launchers.
Some people still want the Alternate launcher that comes with many TV sticks for EZ TV use.
I took this from the Neo X5 ROM as I liked it better than previous versions. This of course comes with the RK settings as well.
If you want to remove this just use ES File explorer and delete these files from /system/app
LauncherNEW.apk
AllApp.apk
RKSettings.apk
RKBasicsettings.apk
Now just reboot and all this will be gone.
7) Gameloft fix. This fixes Gameloft games from crashing to the desktop.
Many of them do not run and crash to the desktop. This is due to a license check based on the device. Special thanks to Christian Troy for inventing this fix.
8) Build.prop edit to open up the Google Play store to APPs that normally say "not compatible".
I am spoofing a Samsung device that will show almost any APP as compatible.
Your device will show up in google play as NOT a MK808 device! Understand this please.
I also left the original build.prop in the ROM called build.orig.
If you want to go back, just use ES FIle Explorer or a root file explorer and rename build.prop to build.old. Then rename build.orig to build.prop.
Go into settings, apps, all and go into the Google Play app. Clear the cache and data.
Reboot!
9) Rockchip just released a updated libstagefright.so to try and fix HW decoding issues in XBMC.
I have added this to the ROM but have not fully tested it yet.
See info here regarding this new library.
10) As always, full init.d support! If you do not know what that is... ignore it. For geeks that want to use it. It is there!
11) RK Mirroring is enabled. I have yet to figure it out or how to use it but if we ever do, its there.
I think we need a client on our tablets to use it. Hopefully more info will come from WiMo about this.
12) Remote Control using RK Remote APP is now fully supported!
In the ROM kit is a RKRemoteControl.apk.
You install this on your phone or tablet and now it can remotely control your TV player!
Just put the APK on sdcard or something and install it on your Android phone, tablet, etc.
ENJOY this one! I had a HARD TIME getting it to work!
13) I added a reboot APP that will allow optional reboot options like reboot to bootloader (flash mode).
14) As always I added the Xbox XPAD.KO module is now injected on boot. This was by request! Enjoy!
15) I added Xbox360 keylayout to fix some games and camera spin with xbox 360 controller. Per this post here:
16) TUN.ko module is also added by request. (CIFS and MD4 are already in the latest kernel).
Be aware if you use another kernel other than whats in this ROM, you may have to manually insmod CIFS and MD4.
The files are in /system/lib/modules
For more information ALWAYS read the README in the ROM kit!
________________________
Here are the links for 1.7 ROM
Please make sure you use the correct ROM for your hardware version!
MK808 Original (not for clones or B model) UPDATED to 1.7c as of March 15, 2013
ROM -> MK808 Original Finless 1.7c ROM (240 megs)
MK808B Original model:
ROM -> MK808B Original Finless 1.7 ROM (240 megs)
MK808B Sunvel Clone
ROM -> MK808B Sunvel Clone Finless 1.7 ROM (240 megs)
MK808B V1 Clone
ROM -> MK808B V1l Clone Finless 1.7 ROM (240 megs)
Enjoy,
There are currently 2978 users online. 0 members and 2978 guests.
