Hi guys!
Haven't had any issues with wifi and connection speed before. Netflix and other streaming services working ok. Also watching pictures on the NAS. But since I got a new smartphone (a HTC One) with a good camera I've started to shoot 1080 video in mp4 format with it.
My problem is that when I store those films on my NAS and try to play them on the mk808 (finless 1.7c) over wifi The video lags. If I store the files locally on the mk808 they play fine. Tried a couple of different players and get pretty much the same behavior. My player of choice is MX.
Even if I have good wifi connection with 54mbps the video lags.
I got the folders on the NAS mounted as cifs. Is that maybe the problem? Can I access/mount them in any other way over wifi? Or is the only solution getting lan via cable to the mk808 (which would be a pain since the router is in another part of our home)?
Thanks for any help or input!
EDIT: did some more searching of the forum and found some posts that mentioned something called NFS and that it would be to prefer over CIFS and give better transfer speeds (I'm not that good at this stuff and dont know the difference). But those posts also stated that NFS is not supported by the MK808. Is this correct - or is there some way of using NFS instead of CIFS?
Skickat från min HTC One via Tapatalk 2
