Thanks,well it's is a genuine mk808b it came 4.2.2 it's better to keep this version or flash the finless 1.7? also when i connect to wifi all are fine i can browse the internet flawlessly but when i try to connect to play store or youtube app it doesnt let me it says something about the connection...
P.S flashed fineless 1.7 all good now i flashed the 1080p kernel but i didn't like the performance so i reflashed 720p and its so smooth thnx finless for this awesome romLast edited by ShadowSora; 17 May 2013, 12:09.
Originally posted by ShadowSora View PostHi, i am new here and i just bought a MK808(non b i think) and i would like to know how to identify if it's a clone so i can know which rom to flash.Thanks in advance
Hi All,
I own a MK808b Android mini PC and a wireless keyboard with touch pad. I am having problems watching movie as the applications I have don't seem to work well with the keyboard. When I press the right left up down arrows nothing much happens in terms of fast forwards, rewind, pause etc. I have to press FN Key + F7 to pause etc etc. What application can I use to that I can use my current wireless keyboard and easily use the keys to pause, play, fastforward, rewind etc ?
second question - what sort of remote can I buy with my MK808b device to enable this as a TV so that I can easily do what I normally do with my DVD remote control ?
It is just what do want, air mouse , rc11 , xbmc remote or an app that functions as remote on your mobile phone.
Originally posted by CannaBioD View PostThere are dozens of different remote controls on ****, DX or dhgate.
I have one of those mini RF wifi keyboards from ****.
Kernel Source
I was wondering where I could find the kernel source for this rom. I've tried to locate it but didn't succeed. I would like to compile uvcvideo to build me a little webcam server so I can watch my cats when I'm from home :|. Also I would like to compile ftdi_sio so I can connect my arduino.
Thx,
Bram
In my ROM I used the stock kernel.
However for the MK808 kernel sources are available like from Omegamoon's blog.
"PerdĂłnalos porque no saben que lo que hacen"
Thx,
Bram
Also , last year i picked up an IP webcam with a pan & tilt function , IR illumination for night time, wireless & ethernet enabled , motion detection , two way audio , It can even send you an email alert if you want it.
This unit cost me $56 with free delivery....they're even cheaper now.
I have some good surveilence footage of my dogs destroying the furniture while i'm at work
Thx,
Bram
REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by dav_id View Postis there any way to safely remove the usb thumb drive??
unmount or something???
everytime i remove the thumbdrive something come out at the notification " Storege removed. Insert a new one."
is this normal??
I use the free StickMount app from the PlayStore to mount and unmount USB mass storage devices. It fills the missing gap that most JB ROMs have.
Re: NEW - MK808 "all models" Finless 1.7
I don't think the stickmount work...
Cos once I unmount from stick mount, I still access the usb thumb drive at /mnt/usb_storage/USB_DISK0/udisk0
..any you comfirm?
__________________________
Sent from Galaxy Note II (GT-N7100) using Tapatalk
Bob please help.
Bob can you please add the larger partition parameters files with the MK808b original 1.7 rom.
I flashed the 1.7 to my MK808b original and the partition size changed from 2gb os/6gb apps 8gb total on the stock rom to 2gb os /2gb apps 4gb total on the 1.7 rom??
Now I will need to reflash again with the correct parameters.
Never Mind Bob I ripped one out of the MK908 1.4 roms and edited it for the MK808b.
Works perfectly now so thanks much and very good job on this one!!Last edited by Justinbaileyman; 24 May 2013, 15:41.
There are currently 5032 users online. 1 members and 5031 guests.
