Re: NEW - MK808 "all models" Finless 1.7
Originally posted by dangerousp View PostREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by leolas View PostUse other usb cable?
Edit: still nothing.. tried several things and another cable. The computer doesn't see the device at all! I even installed windows over again and still didn't help.
OTG, normal mini USB etcetera, doesn't mather.. my computer sees all other devices (like my phone, USB stick and external hard drive) Also it used to work perfectly. When in the device I have switched off debugging etc. but I don't think that should be the problem, because it also doesn't go directly into flash mode with the reset button.
The device, when connected to my to tv, is working very good.. except for some anoying bugs, that's why I want to update.
Edit 2: O stupid me! I had to put the reset longer. I was doing it with a needle, so it hurt a bit and release to soon!Last edited by dangerousp; 27 April 2013, 15:31.
Originally posted by tsobo View PostHello guys am new, installed romantic fine, but I can't turn on wifi, every time I try to turn on wifi under settings, it keeps switching off. Please help.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by tsobo View PostI have a mk808 so installed the 1.7c the one from the 13 March? That's the right one for my deviceis is it not please?REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by apokalypse View PostHas anyone gotten an external harddrive running NTFS to work?
I flashed a USB key to NTFS, plugged it into the MK808, but when I stuck it back in my PC it said the device was not formatted anymore...REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
need some help
1. how can i change keyboardlayout to "qwertz" ?
a few more questions...
2. in the button right corner the is my wlan with the mac 00:00:00.... why?
3. has the ROM no BT support?
4. my stick will only boot if I give him power over the OTG port.only the power port is not enough for the boot. after the boot I can take the power of OTG port and the stick continues. why?
thx
vipLast edited by Viperdriver2000; 30 April 2013, 00:26.
RKRemote not working...
Hi, everybody.
My first post, as most, comes with a problem, I hope you can forgive me.
I don't understand why RKRemoteControl is not working on my MK808B original (with Finless 1.7).
Both devices (my smartphone is a Galaxy Nexus) are connected to same wifi network, but there is no way to get remote control to work properly.
I have tried to purchase Droidmote Server, and results is the same, does not work. My smartphone does not recognize any device.
I've found a way to get it work: activate wifi-tethering hotspot on the MK808, then connecting the Nexus to the network AP-Android. In this case everything works fine (both RKRemote and Droidmote). Of course it's frustrating because internet does not work in this situation... I've tried to ping both devices from my pc (smartphone and MK) and both respond.
Do you have any ideas to resolve this issue?
Thanks!
Thanks!
Might be your problem.
Originally posted by bautrupp View PostMy Router has a setting, something like "allow connected devices to communicate to each other".
I have deactivated WIRELESS ISOLATION on my netgear router and everything worked like a charme. THANK YOU!
There are currently 5639 users online. 3 members and 5636 guests.
