New MK808 Owner
Just got my MK808 from Amazon and flashed Finless 1.7.
Bob -- thank you very much for putting this firmware together!
I have two questions:
1) I can't get Amazon Video on Demand working. I installed Dolphin 8.5.1 for Adobe Flash support. When I click on a video, the 'loading' screen shows, but then it just goes blank with no video. How do I install a working version of Adobe Flash so I can watch videos from Amazon on Demand?
2) I have a powered USB hub with a USB to Ethernet adapter and a Logitech K350 (Unifying keyboard and mouse). It seems like every so often the MK808 looses a connection to the keyboard and mouse. It requires I pull the USB plug out of the MK808 and re-insert for it to work. Any thoughts?
Originally posted by joe9003 View PostReflash! I've had this constantly but been told no one else has the problem I put it down to xbmc but with 1.6 I have no trouble.
I've tried all three kernels and different xbmc apps and after a few days I need to flash my mk808 again.
Even the recovery gets messed up my I can flash perfectly every time.
Sent from my HTC One S using Tapatalk 2!
Guys ive found the problem im (maybe some of us are) having with the corruption with the mk808 , what I noticed is that I got a lot of pink or green lines across the screen and after that it would get stuck loading and then never reboot again until a re flash.
So I started to experiment with different kernels and noticed the same problem from about february releases is this down the the HDMI black screen fix that I never suffered from? I believe its some thing to do with the HDMI loading or being detected, my problem has completely gone now no corruption no screen glitches this was down to the first release from geakbuying and an old kizs kernel I had kicking around from November.
I have a apple 2amp charger new usb cables and a fresh install of 1.7 plus this kernel https://www.box.com/s/hi57bz5iglsenpxbjc6h you do need to do a fresh install before using this kernel try it out and post back if the corruption has gone and massive thanks to kizs and of course Bob for is hard work.
Originally posted by crasdan View PostHi, i have problem with Mk808. I install the Finless 1.7 on my mk808, i set the my time, location etc on first run of system after the installation, all running ok.
The problem is after each reboot or shutdown the time is reset to 2:00 date 1.1.1970.
how to fix ? thx.
Re: NEW - MK808 "all models" Finless 1.7
Yes you need to run ehome apk at least 1 time (if it was not launched automatic), and no kill it if you use a task killer.Last edited by leolas; 22 April 2013, 12:58.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
There are currently 6542 users online. 1 members and 6541 guests.
