Originally posted by moob View PostFor me my Xperia S found my device fast with finless 1.7 and mk808b(rk903) device.
REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by nybom View PostJust grab with the mouse in the bottom of the screen and pull up.
Your suggestion works if you'd manually hidden systembar with the button. I don't like that though, as the bar is hidden even on the home screen which leaves a strip of corrupted graphics if the cursor moves along the bottom of the screen.
HELP keyboard maping
please someone help i have my MK808 on rom 1.7 and i can keyboard map everthing except the HOME KEY
ive scaned my keyboard and the code is 127 so ive tryed
qwerty.kl
Generic.kl
with the line key 127 HOME
and it total ignores me
this key is the windows start key on the keyboard
ive also tryed the externel keyboard helper
and idears and help work me recieved with many thanks
I solved problem #2 by purchasing a Logitech K400 which is working very well.
Any help with problem #1? I still can't get Amazon on Demand videos to work on this device. Please help.
Originally posted by ThePol View PostJust got my MK808 from Amazon and flashed Finless 1.7.
Bob -- thank you very much for putting this firmware together!
I have two questions:
1) I can't get Amazon Video on Demand working. I installed Dolphin 8.5.1 for Adobe Flash support. When I click on a video, the 'loading' screen shows, but then it just goes blank with no video. How do I install a working version of Adobe Flash so I can watch videos from Amazon on Demand?
2) I have a powered USB hub with a USB to Ethernet adapter and a Logitech K350 (Unifying keyboard and mouse). It seems like every so often the MK808 looses a connection to the keyboard and mouse. It requires I pull the USB plug out of the MK808 and re-insert for it to work. Any thoughts?
Originally posted by robgee65 View Postplease someone help i have my MK808 on rom 1.7 and i can keyboard map everthing except the HOME KEY
qwerty.kl
Generic.kl
Make sure you keep the file permissions correct after you edit it and you should comment the line that defines the HOME assignement as well as the line that defines the key 127.
that said, you can't have duplicate assignements on the generic.kl
thank you
no sure what you mean by comment the line as well as the line that defines key 127
could you give me a example as thet on the same line
thank you
Originally posted by philocritus View PostI have mapped the home key in Generic.kl.
Originally posted by robgee65 View Postno sure what you mean by comment the line as well as the line that defines key 127
thank you
key 127 HOME
You will have to comment(add # at the beggining of the line) any existing line with the number 127 or HOME like on this example:
# key 127 MENU
# key 120 HOME
thank you
ok i see now but if i alter the Generic.kl ib anyway it goes wroung totally so going to see if i cant make a ventor file
thanks again
Originally posted by philocritus View Poston the original generic.kl you will add a line:
key 127 HOME
# key 127 MENU
# key 120 HOME
I've updated my mk808 a few months ago to 1.6. Now I want to update it to 1.7, but my computer does not detect the device, I also can't get it into flash mode.
I tried all the methods and while pushing the reset button and then plug in the usb cable, doesn't work. Also then the blue light burns, which I thought shouldn't be happening.
Anyone an advice?
There are currently 2300 users online. 3 members and 2297 guests.
