THanks.
Guest
Hi, I've been going crazy trying to create USB/BT Joystick Center (Joy2Touch) profiles with no luck, no matter what, I cannot add buttons in Edit Mode. I tried using Droidmote to emulate a touch screen mouse and nothing.... I read it was supposed to work on bob's rom but I still cannot make it work.... even Mouse mode works perfectly fine, just cannot add anything when in edit. Any ideas please ? I'm on 1.7b version.
THanks.
*WHICH* MK808???
Originally posted by Finless View PostPlease make sure you use the correct ROM for your hardware version!
MK808 Original (not for clones or B model) UPDATED to 1.7c as of March 15, 2013
I was just about to buy a device *knowing* that the first thing I'd do is flash this ROM when I bumped into the quote above. I honestly thought they were ALL clones.
Is there any way to tell in advance just what you're buying?
Thanks, Folks.
And especially THANKS Mr. Finless!
I was jut browsing this: http://www.geekbuying.com/item/UG008...ut-314507.html
I really like the form factor. For the cooling if for no other reason...
Re: NEW - MK808 "all models" Finless 1.7
Originally posted by tatubias View Postit still happening again. i have re instaled 1.7c and 1.6 and i keep loosing wifi.
i see wifi is connected but no trafic can be generated until you switch oof and on agaii have mk808original.
Sent from my MOMO11 四核 using Tapatalk 2
finaly fixed changing the router chanel to 11. channel9 i think will bea good option to
Stuck at boot
Hey everybody,
Since yesterday i'm having trouble booting my mk808 with finless1.7, it stays stuck on the boot screen (the shiny one with finless bob message).
The splash screen is still moving, but it's not going anywhere after that.
Anyone had the problem before, or do i need to reflash my mk808?
stuck
Happened to me too, reflashed and same problem. Found out the problem was the external Harddrive pluged in but unpowered. When I umpluged it, MK808 started without frezing. Try it out, umplug all nonesential usb plugs
I tried to boot only with hdmi and usb power, doesn't work
There are currently 3295 users online. 0 members and 3295 guests.
