Originally posted by papzi View PostHi!
After succesfull flash my MK808B with v1.7 have same problem:
when I switch taskbar "auto hide", don't come back...
the time (and date) is resetting after sleep or switch off.
Are you telling us the hidden notification bar can't be unhidden, or you don't know how to unhide it? You should be able to click your cursor at the bottom edge of the screen and drag it up to unhide the notification bar.MK808 w/Omegamoon kernel, CWM recovery, & Finless 1.7 ROM
Originally posted by hikaricore View PostFlashed this build last night and my mk808 is running like it never has before. Had to switch my externalsd and sd back under vold.fstab again but that was easy enough and a small enough price to pay for the epic improvements. Thanks for the release. ^_^
What are you liking better about it?
Originally posted by gautam View PostI just have one problem. Copying a file over network from my windows 7 Laptop, I get only 4 Mbps speed...whereas the MK808 wifi setting shows connected at 65 Mbps and the laptop network shows connected at 130 Mbps ( I have TPlink 300 Mbps Wifi Router)
I tried different File browser and explorer but same results.
Is this normal or i can do any tweak to improve the file copy speed over network....Thanks
The performance of your laptop should always be better than the tv sticks as the laptop should have better quality antenna, probably better quality wifi chips and a faster processor/disk system.
Originally posted by whatsupskip View PostThere may be a problem with the file server as it is taking me around 4 hours to download the mk808b_finless_17.zip file. I have a 100Mbps internet connection, that is hardly doing any downloading.
Thanks for your very sexy Firmware !!!
As i need an 1080p Kernel, is there a way you include that in your releases ?
I tryed the kizs kernel v3 720p and 1080p and that ended up in an non working (no light) MK808.
The 2dark4u Kernel is working but now i´m not really able to read the text anymore because it gets so small even if i use the biggest fonts....
So hey i like your firmware with 720p support very much....how can i get 1080p ?
An other problem i use my mk808 with a motorola lapdock, but every time i close the lapdock and reopen it the screenmode was broken. I think this is because of the autodetection for screenmode.
Broken in this case means it is reseted to an ugly one
So is there a way to tell this damn thing to just use one STATIC screenmode ?
RK remote control
Thank you very much for this awesome rom. The only trouble I am having is the RK remote control. I´ve installed it on both my phone and tablet but it doesn´t find any devices. Is there anything I need to do in settings on the Mk808 first? I´m hoping to get this to work since Droidmot doesn´t function in games
drop a freaktab
Thanks Bob& all for the sharing of info.
Had RK808v2 for a month now, Im like a child with a pack of lollies.
Flashed 1.7c, tis unstoppable, Will try bt dongle & web cam later, whats the chance!
Stock browser plays flash streamswifi is acceptable but will mod, power upgrade a must.
1 question, can I use root explorer to link flash player with dolphin browser?Last edited by chrisofnaki; 24 March 2013, 08:24.
Originally posted by mishtag View PostTry the first option, if boots install titanium backup or similar, then erase nand and install 1.7 . Seems nand corruption issue
This is cause I encourage people to have a nandroid backup with cwm. If your system get corrupted you can easy come back it to a funtional state in 5 minutes.
So, any advice,[/QUOTE]
Should I open an new thread, i feel that my question might be lost among all other questions.
Anybody has same problem with keeping the Ethernet option on.
There are currently 2977 users online. 0 members and 2977 guests.
