    Originally posted by dpejakovic View Post
    wifi had good signal on my mk808b, whit geekbuying stock release 24Mps i think but now wifi is not so good just 5Mps...
    You are the first to report this on the MK808B. Also this ROM is based off the geekbuying release using it's wifi drivers.
    I will wait to see if any more people have this issue before looking at it again. I do not have a MK808B I have a MK808B Sunvel Clone which has different wifi so I am unable to test!
      Finless
      I have mk808b from geekbuying, and i m not alone with this problem:
      Vinay says:
      March 16, 2013 at 5:24 pm
      Please do something regarding wifi signal in mk808b.
      Full signal in mk808b stock firmware
      version 1.6 mk808b signal shows only 1 bar & that too sometimes.
      version 1.7 mk808b signal now worse than version 1.6 & not at all connecting to wifi. Even though wifi router is just side to it.
      Currently I’m on fineless 1.6 custom rom & wifi signal are mostly times 1 bar or zero.
      So, please find a fix to it. The same problem is with 1.7 also.This thing also I have tested. I was facing the same issue in 1.7 custom rom of Freaktab.
      THIS IS POST FROM GEEKBUYING
        Do not always trust the signal bar! ROMs can be made to fake that.
        What you want to do is open settings and then click on the conection. You will get a pop up that shows connection data rate.
        Then go get wifi analyzer from Google Play and see what it is telling you! This is the best tool for seeing what wifi is doing.
        Finally if you read through here, the MK808B has always had wifi complaints due to the antenna being shorted and other issues. I even made a video showing how I moded my MK808 to resolve issues:
        http://www.freaktab.com/showthread.p...help-you-do-it!
        I am going to need more data than just the signal bars.
          Finless
          I install wifi analyzer and readings r (ch 11 2462 MHz , -66dBm)
          Now i have internet after reboot device...
          And thanks!
            Preventing screen from locking (blanking out HDMI Signal)
            in settings display there is a time out for sleep mode (screen Lock). It ranges from some seconds to 30 minutes. Is there a way to disable it completely?
            My ASUS TF101 has a "NEVER - Display always on" option in there.
            My internet streaming stops when screen blanks.
            Best Regards
            Markus
              Originally posted by Spotopolis View Post
              Oh, really? I thought I remembered that you had bumped it up to 1.4 a while back. Guess not. Either way it's still ramping the CPU clock all the way up and I'm having heat issues. Even if I set the max clock to 1.008 and min to 252. Or is that normal for everyone? Just worried it might burn out.
              Meaby SetCPU app reads cpu speed incorrect.
                Best Regards
                Markus
                By default first ROM flash there is a NEVER setting. But after you mess with lock screen, this dissapear for some reason. I forget how to turn it back on. Mess with lock screen settings and also keep wifi on during sleep settings for advanced wifi settings. One of those will give you back never option.
                  adverbs popping op in aps
                  I went from finless 1.7 > 1.7a > 1.7b > 1.7c
                  I did this by just only flashing the system.img
                  My problem is that in 1.7b and 1.7c I get adverbs popping up in a lot off aps.
                  So is there a way to stop this and get rid of these ads because the are really annoying ?
                    Hi Bob - can u pls take some seconds and check the pinch-to-zoom bug i got?
                    haynz
                    Hi - Pinch-to-Zoom works now, but if u single-click on the map (Gearth) after pinching > it does a "double-click-like" zoom at the first click ... and same if u pinch-out - it zoomes out once more at first click on map - nearly unusable ...
                      http://securitywatch.pcmag.com/security/309241-how-to-block-ads-on-android
                        Re: NEW - MK808 "all models" Finless 1.7
                        Install adaway aplication or similar. Now they are rempved from de market so look in other market.
                        Sent from my MOMO11 四核 using Tapatalk 2
                          K- sry for making troubles ... it might be a google earth bug at mouse-pinch - in browser it works perfect.
                            EDIT....Sorry Bob i am f### idiot
                            Sorry guys i am idiot, i have mk802IIIS to, and for him i dont have wall charger and that was problem with mi mk808b i dont used wall charger idiot!
                            BIG SORRY!!!
                            Vinay says:
                              Sorry guys i am f### idiot, i have mk802IIIS to, and for him i dont have wall charger and that was problem with mi mk808b i dont used wall charger f### idiot!
                              BIG SORRY!!!
                              Post has been edited.... No Profanity allowed...Consider this warning...........
                              JIM
                              MK808
                              FINLESS 1.7A
                                JIM
                                MK808
                                FINLESS 1.7A
                                Jim, You forget to edit the heading of his post.
