Re: NEW - MK808 "all models" Finless 1.7
Originally posted by papzi View PostREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by leolas View PostIt is Extrange, i assume you are using the kernel provided in the zip. And geekbuying only sell mk808b(rk903). I suggest to download again the zip, Erase idb before and flash it again. I have this Rom installed withot those issues.
Now I'm working, tonight I will try it...
PS: he thing HAS a rk903 chip!
Yes, and tell me how it goes.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Very good!
I've just installed the Finless 1.7c ROM and works great. very stable!
I've a question, I found in previous 1.6 and right now in 1.7c a little problem: I've installed the SMB Filesharing for Android apps (Funky Fresh) either downloaded form Google Play or Xda Dev Forum.
When i configure the APPS i cannot reach from Win7 ultimace PC my Mk808 device .... I don't know why.
Second things, If I leave my mk808 with this apps up and riunning (tipically during the night) de day after I found the MK808 in freeze state, so.. I need to unplug the DC Power connector.
I've encountered this issue since Finless Rel. 1.6 : do you kno why?
Originally posted by underdog View Postpreviously I reported issues with Skype and Finless v.1.6. However it turned out to be an issue with my camera. Just bought a new one and it worked flawlessly.
If someone is wondering, Skype works great on Finless 1.7 too.when you have some time tell us wich webcam you bought, and if you report it in the device compatibility thread it will helpful for all
Great job!
I`m a noob at android devices,flashing etc..But I have to say, this forum made me a pro! I was on 1.6 Finless and I was very satisfied!As of today, I have 1.7c Finless and I can`t say anything except CONGRATULATIONS! The Rom is very fast, stable, fluid, wifi works great, for now no problem with any apps.. Once again, great job! I hope I wont have any issues with this device and Bob`s awesome ROM!
skype issue
I have skype issue - after 2 seconds my call is failed ( camera logitech c270)
cheers
Originally posted by leolas View PostNicewhen you have some time tell us wich webcam you bought, and if you report it in the device compatibility thread it will helpful for all
Try the first option, if boots install titanium backup or similar, then erase nand and install 1.7 . Seems nand corruption issue
This is cause I encourage people to have a nandroid backup with cwm. If your system get corrupted you can easy come back it to a funtional state in 5 minutes.[/QUOTE]
I re-flashed it with 1.7 and it is working fine, but now when I try to use the Ethernet option through the usb to Ethernet adapter, every time I turn the Ethernet option on I get signal, then when I turn the device off then on, I will not get signal until I turn the Ethernet off then on.
So, any advice,
Originally posted by ab77ab View Postcould you let me know what camera have you used before and what model you have now?
cheers
Jim
XT907 Tapatalk II
Hi!
I've good news: my MK808B working fine!
I erased twice the NAND, then flashed the ROM (Finless 1.7): success! Wifi and Bt working fine!
I dunno what was the problem.
Maybe I do not wait enough time for reboot after flashing?
Just one question: reboot in recovery: what should I seen?
In recovery no menu, just one DRoid with red triangl.
Sv: NEW - MK808 "all models" Finless 1.7
Originally posted by orianadado View PostSecond things, If I leave my mk808 with this apps up and riunning (tipically during the night) de day after I found the MK808 in freeze state, so.. I need to unplug the DC Power connector.
Skickat från min GT-I9100 via Tapatalk 2
There are currently 5552 users online. 1 members and 5551 guests.
