    Cats, for backward compatibility I put busybox in both /bin and /xbin.
    When you install a new busybox it asks you where you want to install. I think it defaults to xbin.
    So what you should probably do is use ES file explorer and delete the busybox in /xbin and install the new to /bin. Or visa versa. which ever you prefer.
    Thanks for the info, Bob.
    The thing is, I can only find one copy of busybox (in /bin) (I'm using File Manager with root explorer enabled).
    If I rename the busybox in /bin and run busybox installer, it says that v1.11.1 is installed in /bin, which I then updated to v1.21.0.
    However, after a reboot, busybox installer will detect more than one copy of busybox again.
    I'm not sure where v1.11.1 is installed as using which from a terminal windows shows that busybox is in /bin and executing busybox from the command line shows that it's v1.21.0... I'm confused!
    Cheers!
      hey all,
      thanks to Bob and everyone in here for all contributions, these android sticks are getting there! One question I have is where can I look for info on how to make a loading screen animation? How do you call these in android tech terms? Thanks!
        Originally posted by CannaBioD View Post
        I use the exact same USB-ethernet adapter from DX, the strange thing is that the tool works over ethernet but when I want to start the rkremote tool I cannot discover the eHomeMedia. When I disable ethernet, enable Wifi I can see the eHome. If I then disable Wifi and enable ethernet I can connect to it. So it kinda works but I have to do 4 actions to connect.
        I use my MK808 as NAS with FTP/Sambadroid/PowerNZB/Dlna server, so my network connection seems ok, I download with 6 MB/s and over ftp I get a constant 12 MB/s also streaming to my LG tv works fine.
        Also wathing movies on my MK808 works fine I use XBMX and I can watch several movies without a network hickup.
        Also I use the Yatse XBMC remote and that works like a charme.
        I also use a remote app for my TV and I use Youtube stream to LG tv so it seams that my personal network is working ok, the Rkremote tool is the only app I have problems with on my network.
        The crashing of the app is the rotation I turned auto rotate of and no more crashed,
        Thanx for this info. That problem is solved
        I have the same problem with rkremote, I'm on the same network, but I can not see the device till I fiddle with the network settings.... sometimes reflashing magically fixes things? (I'm still running 1.6 rom)
          I use 1.7c ROM with the rkremote from the Finless 1.7c rar file.
            How can I tell which mk808 I have so I know which rom to install
              Originally posted by vasanthtcs View Post
              I was able to mount my samba shares using your cifs command. But still unable to access my NFS shares.
              NFS is faster than CIFS. My 25 GB MKV files are stuttering with CIFS .... Any idea on how to mount with NFS ?
              xmount 192.168.1.149:/opt/usb/iomega/Media pogoplug nfs rw,proto=tcp
              this command works in my wdtvlive but not in MK808 ...
              My WDTV plays the 25GB files without a stutter.
              bumping with the hope of getting help. I am able to mount SMB/CIFS shares . I need help mounting NFS shares. Anyway NFS can be supported by the kernel ?
                I have the same problem with rkremote, I'm on the same network, but I can not see the device till I fiddle with the network sings.... sometimes reflashing magically fixes things? (I'm still running 1.6 rom)
                I reflashed the Finless 1.7c rom on my MK808 and now the rkremote works better over ethernet. Also the app stopped crashing.
                When I quit the rkremote and try to reconnect later I can not see the eHomeMediaCenter anymore.
                I then must disable/enable ethernet and after that the eHome shows up again in the rkremote app.
                So problem almost solved.
                  USB Lan Ethernet adaptor problem
                  Originally posted by d4dane View Post
                  Hi and nice work with this custom roms. I have a fresh arrived MK808B original version from geekbuying. Just flashed it with finless 1.7 rom for MK808B with the 1080 img and got a problem with an usb Lan ethernet adapter. Got it from china from buyincoins.com and the android stick does not see it. The driver has the chipset HG20F9 and the linux and windows drivers can be found here http://m2.img.dxcdn.com/CDDriver/160918.zip
                  Any chance of geting it to work on the MK808B? I only have Windows 7 on the PC, hope it will work. Any answer is good, thanks
                  Sorry if I misspelled anything
                  Any answers for me, is there any chance to make the adapter work on the MK808B with finless 1.7c?
                    Re: NEW - MK808 "all models" Finless 1.7
                    Ok, i will try, i didn't see your, post and now i am triying make my wifi dongle work. I am going to open a new thread when i arrived home.
                    My devices:
                    Gearbest.com)
                      Originally posted by alvin12341 View Post
                      It never finds any devices on my droid razr, and it sometimes crashes if i keep tapping it. I have tried reboot my router stick and phone, none works. Any help?
                      I got this to work by turning on droidmote server on the device but I actually did not find this remote any better, worse if anything. It keeps shutting down, loosing signal. At least droidmote is stable (for me).
                        NFS Filesystem support
                        Looks like there is no nfs file system support. I see cifs/smb suupport. nfs is way fast than cifs/smb . Please help on how to add nfs support to the kernel.
                        Code:
                        [EMAIL="u0_a61@android:/"]u0_a61@android:/[/EMAIL] $ cat /proc/filesystems
                        nodev   sysfs
                        nodev   rootfs
                        nodev   bdev
                        nodev   proc
                        nodev   cgroup
                        nodev   tmpfs
                        nodev   devtmpfs
                        nodev   debugfs
                        nodev   sockfs
                        nodev   usbfs
                        nodev   pipefs
                        nodev   anon_inodefs
                        nodev   devpts
                                ext3
                                ext2
                                ext4
                        nodev   ramfs
                                vfat
                        nodev   cifs
                        nodev   fuse
                                fuseblk
                        nodev   fusectl
                        nodev   mtd_inodefs
                          First time Finless ROM user. Just wanted to say excellent work, this is a real improvement over the stock ROM! Looking forward to messing with the 4.2.2 build as it solidifies
                            Sorry but triying to make my wifi dongle works, i compiled the ko file for it, it loads well but i only can connect it to open essid, :banghead:when i finish with it i will open the thread to compile drivers.
                            My devices:
                            Gearbest.com)
                              Hi everyone, i have just a quick question.
                              Is the problem of the status bar in xbmc solved or not?
                              With problem i mean the strange displacement that happens when you hide the status bar.
                              im searching in the posts but i cant find the right one.
                              FIRMWARE & HARDWARE COMPATIBILITY LIST FOR ANDROID TV STICKS
                              https://docs.google.com/spreadsheet/pub?key=0ApGXribKk_8gdEc3YnlmOHlfRlRQVUxFbkJ3Zzg3U EE&output=html
                              My Plexi MK802IV mod
                              http://www.freaktab.com/showthread.p...xi-MK802IV-mod
                                Hay guys got a question about xbmc and this Rom , I've installed xbmc from February with hardware support plus added the playercorefactory file and all works fine mx loads and plays.
                                It's when I reboot I get no boot loop but the Rom just never boots completely so I need to reflash I've used the custom xbmc to from lewy with the same problem.
                                Any idea's?
                                Sent from my HTC One S using Tapatalk 2
