    Hi Bob,
    thanks again for your Answer, Last week I've tested your ko file for SMSC7500 ETH adapter.
    I sow in the logcat trace that the device is recognized and should work... but he dind't I think Is a driver issues.
    For this I sent an email to the SMSC corporation asking for the updated Android Driver for LAN7500 Chipset. They answered today and sent me the updated driver, there Is way to send to you/someone else this driver and get the compiled (ko) ones?
    Thanks a lot.
      pb with fonts
      Hi people.
      So first, sorry for my bad english, but i'm french !
      So, i use this rom on my key (rk808b) and it works well, except for one detail : the fonts are sometines and in somes apps, very crappy.
      i use the 1920*1080 resolution and changed my dpi (i tried 120, 160, 220, 240,...)
      but for example, in the browser, in the address bar, the font are very....i don't know how to say "crappy"; not very readable. It is the same, in skype for example.
      is there a way to improve the quality of the fonts ? (like fonts smoothing ?)
      What do you use for dpi ? could someone share his configuration ? or do you have the same problem ? is it a problem from my tv ?
      by the way, great rom, except for the boot animation : i don't like it lol ! (but already changed it ! )
        Markus, plug your stuff in the main USB port not the OTG port and retry please. I see this stuff is plugged in the OTG. OTG is not a host port in this ROM.
          Hi Bob,
          thanks that worked. I have tried both ports before my post but the USB-ethernet adapter didn't connect to the hub. I think the rd9700 has issues with my hub / switch. So i didn't see that the main USB is the one to use. Using an other switch it worked in the main usb port. Also the virtual USB 7.1 to analog ouput is working now.
          What is the purpose of the OTG Port? The keyboard(s) work well plugged in there.
          BR
          Markus
            Originally posted by markusb68 View Post
            Hi Bob,
            BR
            Markus
            You use that port only for connecting to a PC where the PC is the host. This allows you to use the storage space as a removable hard drive on the PC and thus easily transfer files to it from the PC. And it is also used for flashing ROMs.
              Re: NEW - MK808 "all models" Finless 1.7
              Originally posted by orianadado View Post
              Hi Bob,
              Thanks a lot.
              Pls say me your device and give me a link, I will try to compile it for you.
              Originally posted by doudoufr View Post
              Hi people.
              First, what browser you use?, I am a 1080p user too and I use default dpi resolution, and the font don't see ansolute clear, but think android is not designed for 1080p so don't expect clear fonts in 1080p, i see fonts legible in stock browser an in dolphins hd browser.
              My devices:
              Gearbest.com)
                RK Remote:
                I just tested it myself on 1.7C and it works fine. I am using a RK Tablet (Yuandao N101). I do not know if the RK Remote APP works on devices that are not rockchip?
                Yes, it works perfectly. Using the Samsung Galaxy SII.
                MhagnumDw
                  This is the first time I am getting a Android miniPC so please bear with me.
                  I just got my mk808B shipped today. Thanks I got this updated ROM by finless 1.7 .
                  I installed it and everything works perfect. Wifi is excellent and consistent.
                  SKYPE is perfect , and I am able to do vide calls with my cousin in UK. I have a Logitech C110 webcam. The inbuilt mic pics up so well I can speak sitting from the couch and also from the kitchen which is about 20 feet out.
                  One thing I am unable to do is mount my nfs shares. I am able to successfully mount my NFS shares on my WDTV live. So I know that the problem is not with my NFS exports from my NAS.
                  When I use the busybox mount command in MK808B by logging in through SSH , I get a mount failed 'No such device error' . Some research said this could be because the nfs modules is not part of the kernel.
                  Does anyone know how to install the nfs modules for this kernel ?
                    get CifsManager from app store, make sure you have 'load cifs module' enabled in CifsManager settings. share path should be IP address of you NAS followed by shared folder, rest are self explanatory.
                      The cifs module is already present. I can mount my nfs share in an adb shell:
                      mount -t cifs -o username=name,password=pass //host/share /sdcard/mountpoint
                      Hth
                        Originally posted by entonjackson View Post
                        1. connect your MK808 with AC
                        2. connect with monitor or tv
                        3. plug in mouse in otg
                        4. let it boot up
                        5. go to settings -> usb -> connect to pc
                        6. unplug your mouse
                        7. connect MK808 otg with PC usb
                        8. launch RkBatchtool
                        9. you should see a pink square
                        10. click on switch
                        11. you should see a green square
                        12. launch FinlessFlashTool
                        13. You should see that your RK so and so is found
                        14. erase nand
                        15. if erase nand was successful, flash rom
                        16. pray
                        I feel like this should be in the notes, maybe also along with the fact that USB mass storage is in the RK settings, not stock Android settings. I tried two PCs, multiple USB ports on each, with all kinds of dev settings on and off until I realised this (and read the above 'connect to PC' method) >.<
                        That said, a big thank you to Bob for this release now that I have been able to flash, it's a much better experience with my MK808 now!
                          Hi Leolas,
                          thanks for your quick feed-back, here the link with the driver I've got yesterday:
                          My device is Mk808 original with Finless 1.7c.
                          Thanks a lot, waiting for your feed-back.
                            Finless, let me just say that you rule!
                            Without you, the MK808(B) would be a half-useless pos.
                            I just love your 1.7 rom.
                            Just a question across the thread: Are there ways to increase SNES emulation performance? Many side scrollers like Super Mario All Stars have minor lag when running. I already juiced up the CPU to 1,5GHz on performance governor and closed all background apps.
                              Leolas, good luck with the 75xx driver. It has problems!
                              I have already got a compiled KO and insmod it for people. It still wont work out the gate!
                              From what many have said the driver source has a bug!
                              If you figure that out, many will HUG you
                                Hi Leolas,
                                Ok, the drivers are for linux not for android, but I compile it with crosscompiler and use omegamoon kernel source for compilation, gives me this:
                                Code:
                                leo@leo-EX38-DS5:~/android/kernel/omega/smsc7500$ makemake -C /home/leo/android/kernel/omega/rockchip-rk30xx-mk808/  SUBDIRS=/home/leo/android/kernel/omega/smsc7500 ARCH=arm CROSS_COMPILE=/home/leo/android/kernel/omega/rockchip-rk30xx-mk808/omegamoon/toolchain/arm-linux-androideabi-4.6/prebuilt/linux-x86/bin/arm-linux-androideabi- modules
                                make[1]: se ingresa al directorio «/home/leo/android/kernel/omega/rockchip-rk30xx-mk808»
                                  CC [M]  /home/leo/android/kernel/omega/smsc7500/smsclan7500.o
                                  CC [M]  /home/leo/android/kernel/omega/smsc7500/smsc7500usbnet.o
                                  LD [M]  /home/leo/android/kernel/omega/smsc7500/smsc7500.o
                                  Building modules, stage 2.
                                  MODPOST 1 modules
                                  CC      /home/leo/android/kernel/omega/smsc7500/smsc7500.mod.o
                                  LD [M]  /home/leo/android/kernel/omega/smsc7500/smsc7500.ko
                                make[1]: se sale del directorio «/home/leo/android/kernel/omega/rockchip-rk30xx-mk808»
                                So no errors, the driver link is:
                                You must unzip it, copy it to your stick in /system/lib/modules/
                                and give it permissions like rw- r-- r--
                                then insmod it; and check if it works.
                                My devices:
                                Gearbest.com)
