Originally posted by pieri70 View Post
Originally posted by pieri70 View PostHi Bob
It's usb 2.0 to fast ethernet adapter model ky-rd9700 bought from geek
Thankyou!
Inviato dal mio GT-I9300 con Tapatalk 2
Did you have this problem right off the beginning? Or did you install some APPs etc and then it stopped. Again it should work.
Maybe try reflashing the ROM and try it right away. Just this week I helped a guy solve a similar problem and it was an rooted APP he was using causing the problem with a different Ethernet device.
Also, you are using a MK808 right? not something else? You have to realize some people are flashing this ROM to other devices with the same wifi chipset yet they are having issues. WHY? becasue hardware difference maybe more than just the wifi chipset!
DLink e100 ethernet adapter
Hello,
I just flashed the finless 1.7 rom on my MK808B with the hope that my DLink e100 usb-to-ethernet adapter would work (it wasn't working on the factory firmware) but it still doesn't start. Clicking on the on-off switch for the Ethernet tab (in the settings) never switches it to ON. On my ubuntu computer, the device works fine using the asix.ko and usbnet.ko modules. I have the install CD with the linux drivers for my device but do not know how to compile them for the MK808B. I am wondering if I can get some help here. I have uploaded the drivers to dropbox here : https://www.dropbox.com/sh/cbaoxbegmhmq15m/tbWqlHMweQ
Any help is appreciated.
R: NEW - MK808 "all models" Finless 1.7
Hi bob
It was working on original rom.
On 1.7 does not. I didn't install any app other than gmail and nova launcher..
May be it's the hub usb that is a crap, it's not with power supply so for example I can't connect an external hd..
Can you suggest me a good usb to ethernet adapter that is faster than this one but not too expensive?
Thanks again
P
re remote not working
Originally posted by Hardbox View PostThank you very much for this awesome rom. The only trouble I am having is the RK remote control. I´ve installed it on both my phone and tablet but it doesn´t find any devices. Is there anything I need to do in settings on the Mk808 first? I´m hoping to get this to work since Droidmot doesn´t function in games
RK Remote:
I just tested it myself on 1.7C and it works fine. I am using a RK Tablet (Yuandao N101). I do not know if the RK Remote APP works on devices that are not rockchip?
Some notes we know about RK Remote:
1) It only works over wifi! Not Ethernet or 3/4G connection.
2) Both device must be on the same network or they will not find each other.
3) It relies from E-home media center. If you remove that APP it wont work!
4) You must run the E-home media center at least once to set it up.
Re: rd9700 Ethernet adapter:
I don't have this so I cannot test. Please try my 1.6 MK808 ROM and let me know if it works.
I might be missing a driver for it OR it could be the new kernel they did not put it in?
When you say it worked on the stock ROM, which revision? I need to know kernel date and # and well as system date.
If you flash the 1.6 ROM and it works, then you might try using that kernel.img from 1.6 with the 1.7 ROM.
Bottom line I need you to help me figure out why. So I need much more details.
MK808B V1 clone BETA ready
I have added the 1.7 ROM for the MK808B V1 Clone. Consider it a BETA TEST ROM for now. Remember I cannot test this so I do not know if wifi and BT will work!
All the other models MK808, MK808B, MK808B Sunvel Clone are working as desired.
Enjoy,
Hello Bob, I could use the latest kernel (4.1.1) on my dell'Uhost2 MK808B? so I can use TricksterMod and SetCPU without problems and do not have bugs 1008Mhz blocked.
I read that "smog" user has flashed the Finless 1.5 on his Uhost2 without problems and suggested for those who want to flash the kernel dell'Uhost2 on MK808B (uhost2 has rk903).
How do I flash the kernel without reflash the whole rom? I extracted the kernel.img with the kit Wendal rk29tool, I use the ClockworkMod recovery?
Thanks in advance. EDIT: I have Flash kernel 11/03/2013 Uhost2 on Finless 1.7, Wifi/BT not work, I must test kernel 29/01.Last edited by Mandrake2; 25 March 2013, 11:41.
Originally posted by Finless View PostI have added the 1.7 ROM for the MK808B V1 Clone. Consider it a BETA TEST ROM for now. Remember I cannot test this so I do not know if wifi and BT will work!
Enjoy,
Bobjust downloaded and flashed your 1.7 on my 808b v1 clone
-WiFi/BT works!! wifi analyzer clocks my signal strength at 25db
-Auto-hide works on almost all apps
- somehow this ROM gets Hulu official apk to work, had no such luck in 1.6
will keep you posted on any glitches.
Originally posted by mishtag View PostAnybody has same problem with keeping the Ethernet option on.
Using the eth. adapter from geekbuying and finess 1.7 (not a, b or c)
Doesn't bother me too much. Main thing the mouse works straight off, so I can click ethernet off and back on, then it works again.
ky-rd9700
Hello Bob,
can you check the DMESG Part for the USB Ethernet adapter?
Code:<6>[ 2918.132941] usb 1-1.2: new full speed USB device number 17 using usb20_otg <6>[ 2918.234100] usb 1-1.2: New USB device found, idVendor=0fe6, idProduct=9700 <6>[ 2918.241129] usb 1-1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0 <6>[ 2918.248667] usb 1-1.2: Product: USB 2.0 10/100M Ethernet Adaptor <7>[ 2918.260670] usb%d: qf_write_reg() reg=0x00, value=0x01 <7>[ 2918.260928] usb%d: qf_read() reg=0x10 length=6 <7>[ 2918.261274] usb%d: qf_write_reg() reg=0x1f, value=0x01 <7>[ 2918.281651] usb%d: qf_write_reg() reg=0x1f, value=0x00 <7>[ 2918.283952] usb%d: qf_write_async() reg=0x16 length=8 <7>[ 2918.283964] usb%d: qf_write_reg_async() reg=0x05 value=0x31 <7>[ 2918.283975] usb%d: sr9700_android_mdio_write() phy_id=0x00, loc=0x00, val=0x8000 <7>[ 2918.283982] usb%d: qf_write() reg=0x0d, length=2 <7>[ 2918.284276] usb%d: qf_write_reg() reg=0x0c, value=0x40 <7>[ 2918.284474] usb%d: qf_write_reg() reg=0x0b, value=0x1a <7>[ 2918.284726] usb%d: qf_read() reg=0x0b length=1 <7>[ 2918.284999] usb%d: qf_write_reg() reg=0x0b, value=0x00 <7>[ 2918.285225] usb%d: sr9700_android_mdio_write() phy_id=0x00, loc=0x04, val=0x05e1 <7>[ 2918.285234] usb%d: qf_write() reg=0x0d, length=2 <7>[ 2918.285395] usb%d: qf_write_reg() reg=0x0c, value=0x44 <7>[ 2918.285599] usb%d: qf_write_reg() reg=0x0b, value=0x1a <7>[ 2918.285850] usb%d: qf_read() reg=0x0b length=1 <7>[ 2918.286122] usb%d: qf_write_reg() reg=0x0b, value=0x00 <7>[ 2918.286351] usb%d: qf_write_reg() reg=0x0c, value=0x40 <7>[ 2918.286599] usb%d: qf_write_reg() reg=0x0b, value=0x0c <7>[ 2918.286850] usb%d: qf_read() reg=0x0b length=1 <7>[ 2918.287035] usb%d: qf_write_reg() reg=0x0b, value=0x00 <7>[ 2918.287225] usb%d: qf_read() reg=0x0d length=2 <7>[ 2918.298002] usb%d: read shared 1 0x00 returned 0xffff, 2 <7>[ 2918.298010] usb%d: sr9700_android_mdio_read() phy_id=0x00, loc=0x00, returns=0xffff <7>[ 2918.298019] usb%d: sr9700_android_mdio_write() phy_id=0x00, loc=0x00, val=0xffff <7>[ 2918.298027] usb%d: qf_write() reg=0x0d, length=2 <7>[ 2918.298147] usb%d: qf_write_reg() reg=0x0c, value=0x40 <7>[ 2918.298350] usb%d: qf_write_reg() reg=0x0b, value=0x1a <7>[ 2918.298601] usb%d: qf_read() reg=0x0b length=1 <7>[ 2918.298872] usb%d: qf_write_reg() reg=0x0b, value=0x00 <6>[ 2918.302246] SR9700_android 1-1.2:1.0: eth0: register 'SR9700_android' at usb-usb20_otg-1.2, SR9700_ANDROID USB Ethernet, 00:e0:4c:53:44:58 <7>[ 2918.304522] eth0: qf_write_reg() reg=0x0c, value=0x41 <7>[ 2918.314778] eth0: qf_write_reg() reg=0x0b, value=0x0c <7>[ 2918.315001] eth0: qf_read() reg=0x0b length=1 <7>[ 2918.315279] eth0: qf_write_reg() reg=0x0b, value=0x00 <7>[ 2918.315490] eth0: qf_read() reg=0x0d length=2 <7>[ 2918.326291] eth0: read shared 1 0x01 returned 0xffff, 2 <7>[ 2918.326313] eth0: sr9700_android_mdio_read() phy_id=0x00, loc=0x01, returns=0xffff <7>[ 2918.326339] eth0: qf_write_reg() reg=0x0c, value=0x41 <7>[ 2918.326533] eth0: qf_write_reg() reg=0x0b, value=0x0c <7>[ 2918.326745] eth0: qf_read() reg=0x0b length=1 <7>[ 2918.326932] eth0: qf_write_reg() reg=0x0b, value=0x00 <7>[ 2918.327155] eth0: qf_read() reg=0x0d length=2 <7>[ 2918.337909] eth0: read shared 1 0x01 returned 0xffff, 2 <7>[ 2918.337929] eth0: sr9700_android_mdio_read() phy_id=0x00, loc=0x01, returns=0xffff <7>[ 2918.337956] eth0: qf_write_reg() reg=0x0c, value=0x44 <7>[ 2918.338173] eth0: qf_write_reg() reg=0x0b, value=0x0c <7>[ 2918.338423] eth0: qf_read() reg=0x0b length=1 <7>[ 2918.338704] eth0: qf_write_reg() reg=0x0b, value=0x00 <7>[ 2918.338921] eth0: qf_read() reg=0x0d length=2 <7>[ 2918.349658] eth0: read shared 1 0x04 returned 0xffff, 2 <7>[ 2918.349678] eth0: sr9700_android_mdio_read() phy_id=0x00, loc=0x04, returns=0xffff <7>[ 2918.349703] eth0: qf_write_reg() reg=0x0c, value=0x45 <7>[ 2918.349907] eth0: qf_write_reg() reg=0x0b, value=0x0c <7>[ 2918.350028] eth0: qf_read() reg=0x0b length=1 <7>[ 2918.350180] eth0: qf_write_reg() reg=0x0b, value=0x00 <7>[ 2918.350405] eth0: qf_read() reg=0x0d length=2 <7>[ 2918.361236] eth0: read shared 1 0x05 returned 0xffff, 2 <7>[ 2918.361277] eth0: sr9700_android_mdio_read() phy_id=0x00, loc=0x05, returns=0xffff <6>[ 2918.361328] SR9700_android 1-1.2:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0xFFFF <7>[ 2918.369347] eth0: qf_write_reg() reg=0x0c, value=0x40 <7>[ 2918.369592] eth0: qf_write_reg() reg=0x0b, value=0x0c <7>[ 2918.369828] eth0: qf_read() reg=0x0b length=1 <7>[ 2918.370146] eth0: qf_write_reg() reg=0x0b, value=0x00 <7>[ 2918.370414] eth0: qf_read() reg=0x0d length=2 <7>[ 2918.381356] eth0: read shared 1 0x00 returned 0xffff, 2 <7>[ 2918.381396] eth0: sr9700_android_mdio_read() phy_id=0x00, loc=0x00, returns=0xffff <7>[ 2918.381433] eth0: qf_write_reg() reg=0x0c, value=0x41 <7>[ 2918.381731] eth0: qf_write_reg() reg=0x0b, value=0x0c <7>[ 2918.381983] eth0: qf_read() reg=0x0b length=1 <7>[ 2918.382271] eth0: qf_write_reg() reg=0x0b, value=0x00 <7>[ 2918.382553] eth0: qf_read() reg=0x0d length=2 <7>[ 2918.393408] eth0: read shared 1 0x01 returned 0xffff, 2 <7>[ 2918.393428] eth0: sr9700_android_mdio_read() phy_id=0x00, loc=0x01, returns=0xffff <7>[ 2918.393454] eth0: qf_write_reg() reg=0x0c, value=0x44 <7>[ 2918.393671] eth0: qf_write_reg() reg=0x0b, value=0x0c <7>[ 2918.393884] eth0: qf_read() reg=0x0b length=1 <7>[ 2918.394084] eth0: qf_write_reg() reg=0x0b, value=0x00 <7>[ 2918.394296] eth0: qf_read() reg=0x0d length=2 <7>[ 2918.405157] eth0: read shared 1 0x04 returned 0xffff, 2 <7>[ 2918.405177] eth0: sr9700_android_mdio_read() phy_id=0x00, loc=0x04, returns=0xffff <7>[ 2918.405202] eth0: qf_write_reg() reg=0x0c, value=0x45 <7>[ 2918.405408] eth0: qf_write_reg() reg=0x0b, value=0x0c <7>[ 2918.405619] eth0: qf_read() reg=0x0b length=1 <7>[ 2918.405806] eth0: qf_write_reg() reg=0x0b, value=0x00 <7>[ 2918.406035] eth0: qf_read() reg=0x0d length=2 <7>[ 2918.416785] eth0: read shared 1 0x05 returned 0xffff, 2 <7>[ 2918.416805] eth0: sr9700_android_mdio_read() phy_id=0x00, loc=0x05, returns=0xffff <7>[ 2918.416830] eth0: link_reset() speed: 100 duplex: 1 <7>[ 2918.416871] eth0: qf_write_async() reg=0x16 length=8 <7>[ 2918.416895] eth0: qf_write_reg_async() reg=0x05 value=0x31 <7>[ 2918.417187] eth0: qf_write_async() reg=0x16 length=8 <7>[ 2918.417237] eth0: qf_write_reg_async() reg=0x05 value=0x31 <7>[ 2918.417942] eth0: qf_write_async() reg=0x16 length=8 <7>[ 2918.418009] eth0: qf_write_reg_async() reg=0x05 value=0x31 <7>[ 2918.419363] eth0: Link Status is: 0 <7>[ 2918.419984] eth0: qf_write_async() reg=0x16 length=8 <7>[ 2918.420029] eth0: qf_write_reg_async() reg=0x05 value=0x31 <7>[ 2929.292747] eth0: no IPv6 routers present
It shows up in Dmesg:
Code:<6>[ 538.873026] usb 1-1.4: new full speed USB device number 13 using usb20_otg <6>[ 538.974423] usb 1-1.4: New USB device found, idVendor=0d8c, idProduct=000e <6>[ 538.981357] usb 1-1.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0 <6>[ 538.988764] usb 1-1.4: Product: Generic USB Audio Device
Best Regards
Markus
There are currently 3762 users online. 0 members and 3762 guests.
