    Originally posted by leolas View Post
    Ok, the drivers are for linux not for android, but I compile it with crosscompiler and use omegamoon kernel source for compilation, gives me this:
    Code:
    leo@leo-EX38-DS5:~/android/kernel/omega/smsc7500$ makemake -C /home/leo/android/kernel/omega/rockchip-rk30xx-mk808/  SUBDIRS=/home/leo/android/kernel/omega/smsc7500 ARCH=arm CROSS_COMPILE=/home/leo/android/kernel/omega/rockchip-rk30xx-mk808/omegamoon/toolchain/arm-linux-androideabi-4.6/prebuilt/linux-x86/bin/arm-linux-androideabi- modules
    make[1]: se ingresa al directorio «/home/leo/android/kernel/omega/rockchip-rk30xx-mk808»
      CC [M]  /home/leo/android/kernel/omega/smsc7500/smsclan7500.o
      CC [M]  /home/leo/android/kernel/omega/smsc7500/smsc7500usbnet.o
      LD [M]  /home/leo/android/kernel/omega/smsc7500/smsc7500.o
      Building modules, stage 2.
      MODPOST 1 modules
      CC      /home/leo/android/kernel/omega/smsc7500/smsc7500.mod.o
      LD [M]  /home/leo/android/kernel/omega/smsc7500/smsc7500.ko
    make[1]: se sale del directorio «/home/leo/android/kernel/omega/rockchip-rk30xx-mk808»
    So no errors, the driver link is:
    You must unzip it, copy it to your stick in /system/lib/modules/
    and give it permissions like rw- r-- r--
    then insmod it; and check if it works.
    If anyone wants me to make a TEST ROM with boot that insmod this to test, let me know. I need to know what ROM you want to try this on.
      Leolas, good luck with the 75xx driver. It has problems!
      I have already got a compiled KO and insmod it for people. It still wont work out the gate!
      From what many have said the driver source has a bug!
      If you figure that out, many will HUG you
      I hope that this new driver that orianadado gives us makes the magic. It is made for linux nor android, but with some changes in Makefile it compiles well, at least i try to do it
      I am having a lot of problems to compile my own driver for a rlt8191US usb wifi device I have a lot of problems with some funtions but i am triying it too
      My devices:
      Gearbest.com)
        Originally posted by Wizzy View Post
        get CifsManager from app store, make sure you have 'load cifs module' enabled in CifsManager settings. share path should be IP address of you NAS followed by shared folder, rest are self explanatory.
        Thanks I will try this out. and update.
          I've got a couple of android apps that have a phone version and a tablet version. with finless1.7 it seems that the apps load the phone version of the app, rather than the tablet version. Is anyone experiencing this?
          heres one of the apps:
            Code:
              MODPOST 1 modules
            Thanks a lot, I'll try this evening and I'll let you know ....
              Hi Bob
              great rom for me, donation is coming
              Thanks!
              Pietro
                Just to add the Note sent by SMSC Corporation:
                "Hello,
                Please try the attached driver.
                Regards,
                xxxxx
                25/03/2013 11:04 ISaturle:
                Additionally: Please do reconsider the standard in tree driver. This is mainatined when required and is used on many embedded platforms.
                ATTACHMENT INFORMATION
                (See attached file: lan7500_1.04.02.tar.gz)
                Note: this driver should build kernel up to 2.6.39.
                  Yes, pls let us know if it works.
                  My devices:
                  Gearbest.com)
                    Pls say me your device and give me a link, I will try to compile it for you.
                    First, what browser you use?, I am a 1080p user too and I use default dpi resolution, and the font don't see ansolute clear, but think android is not designed for 1080p so don't expect clear fonts in 1080p, i see fonts legible in stock browser an in dolphins hd browser.
                    well, i used different brower (dolphin, firefox, chrome) and the fonts are the same (in the address bar, not in the webpage itself)... it happens also on other applications such as skype for example.
                    if I use 720p it will be better ?
                      Mouse middle click not recognized
                      Bob,
                      Thanks for your great work on the ROMs! I just bought an MK808B because of your ROM. With Finless 1.7, this is a much better system than my previous tablet-to-TV setup.
                      There is just one thing missing here. My Logitech MK510 mouse can perform middle button click. It was recognized as "Menu" in my previous setup. Now it's doing nothing on the MK808B. The menu function is quite convenient especially in XBMC as you can just middle click one item and bring up the context menu. Hope there is an easy fix for this. I'd appreciate it if you could look into this. Many thanks!
                        Yes they will be a little better, but don't expect so much from android default fonts. If I understand well you complain about the system used font when you wrote something and no about the font in programs, maybe a font installer apk can help you?
                        My devices:
                        Gearbest.com)
                          in the address bar, where you type "www.google.fr" for example : here the font is "crappy"
                          and in skype, in the tchat window (but in this application, well, almost everywhere), font are crappy too.
                          but in android (system, or some others applications) fonts are just fine.
                          i tried to install different fonts from rom toolbox, but i will try again with very different fonts to see if it changes or not. :-)
                          by the way, thks for your answer :-)
                            Re: NEW - MK808 "all models" Finless 1.7
                            A pleasure try to help, if you find some goods fonts, please share them to us
                            My devices:
                            Gearbest.com)
                              Originally posted by begings View Post
                              Bob,
                              In this ROM I have enabled mouse wheel button as ZOOM. Something that never existed before and is needed for things like Google Earth! But you cant have BOTH! Sorry, for what you want, zoom is far more important for users and for me
                                Bob,
                                Thanks for your reply! Just to be clear. The middle click doesn't work as Menu even if I turn off mouse zoom in the Settings?
                                I was wondering if there is a way I could change the system myself to get the Menu to work. Would you please point me to the right direction for that? Many thanks!
