Originally posted by Sniglar View Post720
Oh and please be on 1.7 not 1.6.
Im getting connection timed out regularly in play store and crawling speeds with the img you just uploaded, im on a fresh install ( i also had to return to 1.6 for this exact reason). and am currently watching freaktab take over 50 seconds to load. In comparison with about 8 seconds on 1.6 10 minutes ago on the same website. (im still waiting for freaktab to even load or play store to connect)
Originally posted by sammassam View PostIm getting connection timed out regularly in play store and crawling speeds with the img you just uploaded, im on a fresh install ( i also had to return to 1.6 for this exact reason). and am currently watching freaktab take over 50 seconds to load. In comparison with about 8 seconds on 1.6 10 minutes ago on the same website. (im still waiting for freaktab to even load or play store to connect)
Originally posted by Finless View PostThe wifi drivers etc have not changed from 1.6 to 1.7. So wifi in general and the issues you are having cant be ROM related. However streaming of videos is what I am work with Singular now as I did make changes there. Gplay and other issues should not at all be effected! Again some other issues is going on there. No one else is reporting this and I have not seen that kind of issue either.
I hate to argue but Im doing everything correctly I think. Im erasing the nand before flashing tried both 720p and 1080p tried different access points (there are 4 in my house). But still no speed on this rom. all the others ive tried and have used work fine.
And yes 1.6 is up and running and im already half way through downloading google chrome and have loaded freaktab about 5 times. I am using the same network and same stick at almost the same time.
And thank you for youre help by the way, i can see youve worked really hard on this rom its very polished !
Sorry to take so long but I did a full flash and had to re-download you tube and netflix apps (I wasn't building the tension, honest!)
A thousand thanks for your help.
Re: BETA - MK808 "all models" Finless 1.7 BETA TEST - Report thread
What is your device?, man, I feel like a lucky man, I have not noticed those issues, Runing 1.7, at 1080p and original kernel patched to1080 too, mk808b "original", antenna modded, tomorrow I will go to my brother house, he has the same device but in stock firm, I will try update his device and see what happend.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by leolas View PostWhat is your device?, man, I feel like a lucky man, I have not noticed those issues, Runing 1.7, at 1080p and original kernel patched to1080 too, mk808b "original", antenna modded, tomorrow I will go to my brother house, he has the same device but in stock firm, I will try update his device and see what happend..
I thought I was going a little crazy with it, I have always been lucky with wifi signal so I was literally scratching my head.
Hmmm OK... live and learn! I think my production ROM I will remove this. It was given to me as a tip for XBMC but it seems to either not matter (does not show any performance improvement) or in some cases causes problems like you have seen. I will take it out I think.
Sorry again to mess you around.
Originally posted by Sniglar View PostBob, I am sooo sorry but it's back after I re-loaded my other apps. I am in the process of uninstalling each one to try and find the culprit but thought I better let you know asap.
Thank you.
Originally posted by Finless View PostI would be interested in what you find please. Then be 100% sure 1.6 does not have this problem also and just a combination of issues with APPs.
Thank you.
It's getting late here in the UK now, I'll post again over the weekend after trying to narrow it down.
Thanks again for all your help.
There are currently 3133 users online. 3 members and 3130 guests.
