Re: NEW - MK808 "all models" Finless 1.7 (Beta is over)
Originally posted by tommylinh View PostHi Leolas, it seems that you forget to attach the zip file. Could you please update your post?
Cheerssorry i forgot to insert the link, when I arrived home I will solve it
Solved: I correct the post with the link included. I tested it and cause I use 1080p the new pointer size looks good to me
Last edited by leolas; 05 March 2013, 12:57.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
A simple fix I have been using for last few days was to install 'advanced wifi lock' from the play store. Given, I installed this before I knew about the never sleep setting - but it is preventing my device from powering down and I haven't had a single hickup yet. It may be worth noting the first time you run the wifi locker app it prompts you to 'modify sleep policy'. Something else I did from within the app is to uncheck 'disable wifi if connection is lost'. It just seemed to me that I didn't want my device to power down if I had to reset my router-
Sent from my MK808
Sv: NEW - MK808 "all models" Finless 1.7 (Beta is over)
Hows Netflix working for you guys with 1.7? On 1.6 it's decent for me (after I "discovered" that the quality setting on the web interface affected the app quality too) But I still find image a bit jerky, especially in panoramic scenes.
I think this is due to problems with the Netflix app and not rom related but I'm not sure. Hoping for improvement with 1.7 :-)
Skickat från min HTC Desire via Tapatalk 2
netflix
Originally posted by T68 View PostHows Netflix working for you guys with 1.7? On 1.6 it's decent for me (after I "discovered" that the quality setting on the web interface affected the app quality too) But I still find image a bit jerky, especially in panoramic scenes.
However there was still a minor stuttering issue which i've pretty much resolved by using SETCPU and running the performance profile when using netflix.
Still looking for improvements though so will checkout the web interface quality setting
Cannot go back to wifi connection after using ethernet adapter
I seem to have a different issue with my wifi, since it only showed up after I have been using the ethernet adapter for about 1 week.
I was using new, original Mk808B with Bob's -great- 1.7 working fine for a couple of days with excellent wifi. Then added the ethernet adapter which also worked fine (somewhat quicker than wifi).
But then tried the unit in a different room with wifi connection again (no ethernet in that room), but wifi does not complete connection, even though it shows a strong signal (4bars). It keeps getting stuck at authentication..... and retrying.
But, wifi also cannot connect anymore in the original room (very close to the router), where connection HAD been excellent.
Turned ethernet off and wifi on in settings, tried a reboot, also uncoupled the wifi connection and re-coupled with correct password, reset router, removed ethernet adapter, tried horizontal and vertical position for the MK808B, but will not connect to wifi anymore. Wifi signal still showing as strong on MK808B.
MK808B still works fine with ethernet adapter. Tab and phone also working fine on wifi.
Anybody else experience problems going back to wifi from ethernet adapter... or have any tips for a noob?
Try restting your router. All the connect reconnect your doing may have tied up the total allowed DHCP IP addresses set in your router.
And maybe can help too if you erase your conection in settings/wifi and introduce the password again.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by wikings1 View PostBut now i have A problem. I flashed cwm But my remote rc 12 doecent work in cwm. Any one can solve this. Maybe remote?
From my daycruiser
Jim
XT907 Tapatalk II
From my daycruiserMK808 w/Omegamoon kernel, CWM recovery, & Finless 1.7 ROM
There are currently 1613 users online. 0 members and 1613 guests.
