Hi Bob,
I installed 1.7 standard default and now my WiFi is broke.
I have installed 1.6 and All is good.
I can not slide from off to on the WiFi switch but I can check the box to search for access points but none appear.
I always thought I had a standard mk808 bought off amazon but now I'm wondering?
is there an easy way to identify my mk808? could I have a clone?
any other ideas?
pura Vida,
joe
BETA - MK808 "all models" Finless 1.7 BETA TEST - Report thread
any other ideas?
pura Vida,
joe
Sent from my iPad using Tapatalk HD
Originally posted by leolas View PostDo you used the stock kernel or an overclocked one? It seems like defective unit.
Have you try to erase IDB in Rom flash tool before you flash the Rom?
If it repeats in diferent roms I think it is a hardware problem so sorry.
What do you mean about flash on and off? Does the screen flash on/off? Or the led in the device?
I did erase IDB.
Screen flash on/off, The device stays on.
I also noticed something else, it flashes green and purple.
I tryed other cables and a different tv.
I received three new MK808Bs Monday, and have set them up on Finless 1.7, CWM Recovery, stock kernel, ROM, etc, 1080p image. I unsoldered the primary antenna ground wires, and blocked the contacts on the secondary antennae with cardboard.
Wifi on all three works fine 2 meters from my router (maximum 11.5 Mbps download). Once I move them two rooms away (about 8 meters), wifi speed drops to 299 kbps download. My old MK808 with an added antenna from an old router gets 6 Mbps download speed under the same conditions.
One problem appears to be interference or feedback from the air mouse controller, which uses the same wifi frequency. I discovered this by starting speed test (from speedtest.net), and watching the speed increase noticeably when I removed the air mouse dongle from my MK808B(s).
I did 15 back-to-back speed tests with the air mouse dongle connected to the USB-OTG port and the regular USB port, controlling speed test with my RC-11 air mouse.
Then I removed the batteries from the RC-11 controller, left the dongle attached and untouched, and ran speed test on the MK808Bs using my Nexus 7 and RKRemote Control. The average air mouse download speed test was 299 kbps. The average RKRemote Control download speed was 753 kbps, 251% better.
Since this was my first experience with MK808Bs, I flashed one of them to Finless 1.6a to see if there is a wifi penalty from using Finless 1.7, as reported by several users. Sorry, folks. There is no difference in wifi performance between Finless 1.6a and 1.7.MK808 w/Omegamoon kernel, CWM recovery, & Finless 1.7 ROM
Re: BETA - MK808 "all models" Finless 1.7 BETA TEST - Report thread
Originally posted by Maxtone View Postit is normal that sees the device as Samsung GT-I9100?REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
How to identify the type of the Stick
I'm new here and first I want to say thank you for your great work, Bob.
I have a question. I didn't know wich kind of device I have. Is it a MK808, a MK808b or a clone.
In original Formware there was the ability to switch Bluetooth on but it seems not to work.
I flashed the finless 1.7 firmware for the mk808b and wlan works well but bluetooth not.
Is there a way for me to identify my device?
Thank you
Alfred
Thank you for your work and bringing 1.7 test Bob!
I don't regret my donation at all, thanks again!
Just an idea though, why not put 3rd party apps like FancyWidget etc. in /data so they can be uninstalled the easy way?
Greetings
Simon
EDIT: Did I miss it on 1.6 or can the stock RK player play mkv files in 1.7 now? Works great along with the stock rk file explorerOnly the text font is hard to see on white background... need to find a font with better black edges!
Originally posted by bruncek View PostI cant get my MK808 in flash mode manuali!When I plug it in my PC it`not recognized and when I try to reset it with a pinit wont!It`s like there is no reset button in the hole..
There are currently 2779 users online. 0 members and 2779 guests.
