Hi, Im running 1.7 for some time now. No problems, gr8 Rom. One thing, I just realized I have 808B original not the 808. Is the BT only difference in this model so when I use 808 rom Im just loosing BT and all the rest works the same?
MK808 Original Gold Edition
Hi !
hmmm did you try highbit mkv / h.264 ?
Anything special you did ? You simply copied it over the existing and restored the permissions ?!
Please let me know !
(They quote the sample page, the bird 42 MBit is my standard example when testing players, can you try ?)
Greetings,
Ender
Originally posted by frog2001 View PostHi Bob!
Your post about the new libstagefright.so really made my day
After figuring out, how to injekt the file and testing it with the experimental version of XBMC posted in the second post.
All works great! With the version on the xbmc downloadpage nothing changes !!!
Now i can watch my 36th chamber of shaolin with 1080p with only minor picture hickups. It´s a difference like night and day. So with xbmc being alpha for android it´s only a waiting issue i hope
No errors encountered with the 1.7 Rom for MK808B since my last post!
If i can only get the keyboard get to work, like i want *maybe a matter of time or beer*
Many,many thanks
frog2001
Re: BETA - MK808 "all models" Finless 1.7 BETA TEST - Report thread
Originally posted by kedat View PostHi, Im running 1.7 for some time now. No problems, gr8 Rom. One thing, I just realized I have 808B original not the 808. Is the BT only difference in this model so when I use 808 rom Im just loosing BT and all the rest works the same?
REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by Finless View PostSince your very close to me, how about sending me this unit US mail and let me have a go. Just put about $5 and a return shipping label in the box. I will be out of town next week so best to ship it about Wednesday next week if you want to go this route.
PM me for address if interested.
I'll PM you when my MK808Bs arrive, as then I'll be able to spare the extra device.
I'm not the lowest of the low, but I am the slowest of the slow (49.6 mpg over 38k miles in Scion xB)MK808 w/Omegamoon kernel, CWM recovery, & Finless 1.7 ROM
Originally posted by leolas View PostYou will loose wifi too!!
i does not have this sticker with BT symbol but on the board there is a sting: "MK808B V1.0 2012.10.24".
I've always installed Roms for MK808 (both V1.6 and V1.7) and everything worked fine (no BT obviously)
sorry we go a bit OT.
Rom still works fine, very good WiFi receptionMK808 Original Gold Edition
Originally posted by kedat View PostMy board looks exactly the same as the first one from this post:
Rom still works fine, very good WiFi receptionREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by watndat View PostFeedback on sunvel clone:
I am using a MK808-B clone which is labeled on the circuit board as sunvel 1808. It is the version #3 without cpu cooler.
Used the sunvel rom. Everything is working except I can only power the unit trough the OTG port. Antutu benchmark gives a little above 7000. I red already about almost 10000. 6600 is what I had with the stock. Bob, thank you for you execellent work, please keep up with it.
my MK808 Sunvel Clone also has a low score in Antutu (6000-7500).
I edited my clone added radiator.
thanks for rom
whether it is possible to connect the remote ATI Remote Wonter ?
mkv sample files...
Originally posted by frog2001 View PostAll works great!
frog2001
I was reffering to these samples, especially the first (Birds 40 MBit mkv).
Does it play okay for you ?
Greetings,
Ender.
1080p kernel problem
HI, first, i want to say, thank you bob, you did a really nice job, the 1.7 rom is working like monster. everything is fine, i mainly test the webcamera, the logitech C170 working great. also google voice search working well, but i get a problem for 1080p kernel.
i try to replace the boot file from boot720.img to boot1080p.img, i have flashed successfully, however, when connect the mk808/mk808b to check, it still show the screen size is 1280*672. i use the following app to test
https://play.google.com/store/apps/d...3JlZW5pbmZvIl0.
when i flash with the kernel boot720.img, the default setting on display is 720p, when i flashwith the kernel boot1080.img, the default setting on display is 1080p. so i think i flash right, but how this comes.
the 1080p kernel is not the true 1080p? still scale from 720p?
for the other 1080P firmware i tried, when i flash 1080p, the screen icon and fonts will become smaller than usual. and test with software, it said 1920*1080 something like that.
wait for the answer.
anyway,thanks again ,bob.Looking for developers
Originally posted by geekbuying View PostHI, first, i want to say, thank you bob, you did a really nice job, the 1.7 rom is working like monster. everything is fine, i mainly test the webcamera, the logitech C170 working great. also google voice search working well, but i get a problem for 1080p kernel.
anyway,thanks again ,bob.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
thanks for the reply, there are 1080P kernel in the " finless rom" folder, check it. can you pm me the download link for vmirage 1080P kernel?
thanks
Originally posted by leolas View PostWhat 1080p kernel are you using? I am using the one patched by vmirage in armtvtech and it is working good. Bob don't include the 1080p kernel in the zip, you have to download it and install. At least in "mk808b original".Looking for developers
Originally posted by geekbuying View Postthanks for the reply, there are 1080P kernel in the " finless rom" folder, check it. can you pm me the download link for vmirage 1080P kernel?
thanksREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
thanks
In his Readme Bob clearly explains that
"Two boot.img's available. While this is NOT a 1080P ROM for those that want to use Kriz MK808 or other 1080 kernels and do not want the boot screen all jacked up, I have added a boot1080.img file. The boot720 is set as default. If you decide to use another 1080 kernel, just change to boot1080.img"
which means that there is no 1080 kernel in the package. You have to download it elsewhere.
There are currently 1739 users online. 1 members and 1738 guests.
