Originally posted by KasSGT View Post
3. The lock screen/sleep mode doesn't seem to be too stable yet. I often get the "no input" message on screen when trying to get the device out of sleep mode and having to pull the power cord in order to get the device visible on screen again. Sorry for not being able to give more info on this subject, but I am unable to tell what might cause this.
I am using a USB mouse / keyboard. Possibly why I cannot recreate it?
Please tell me what you are using for mouse wifi? BT? etc. It must be something to do with this. Does the mouse pointer move when you try to unlock? Do you have any kind of PIN, Password, or pattern in use?
AW: BETA - MK808 "all models" Finless 1.7 BETA TEST - Report thread
Originally posted by Finless View PostI cannot recreate this and your the second person to say this has happened.
I am using a USB mouse / keyboard. Possibly why I cannot recreate it.
Please tell me what you are using for mouse wifi? BT? etc. It must be somehting to do with this.
edit:
but without unlock screen
Gesendet von meinem GT-P3110 mit Tapatalk 2Last edited by son; 21 February 2013, 19:54.
Re: BETA - MK808 "all models" Finless 1.7 BETA TEST - Report thread
Using the RC11 flymouse. I can see the pointer, and it does move when trying to unlock. No patterns of pin, just normal unlock screen...
Also what were you in when it went to sleep? An APP? Or the desktop/home screen?
Using this Rom since you give the link and no mayor issues with it, only one time I didn't wake up the device, I use an air mouse (ipazzport) and I had to unplug usb transmitter, and plug it again, the stick waked up, I didn't report it cause it happened only once and though it was a battery problem in air mouse, but now I see more reports concerned to that...
If it happend again to you, try unplug and plug the usb transmitter.
Bob I can't acces by adb to the stick. Can access in cwm recovery, but not in Rom.
Mk808b, I updated busybox (I dont know if it can be a problem) before I saw your suggestions in other thread about don't update
Obviously I active it in settings\development and active conect to pc in settings\usb
Thanks.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Thanks.
Look at device ID when USB and ADB is turned on in windows dvice manager. Usually rockchip 3066 is 2207. I bet I forgot and this one is different. I will fix it but for now find the device id and add it to adb_usb.ini file.
Originally posted by Finless View PostOoops! I think I know why! The ADB device ID is different in this ROM and I forgot to change it.
Make sure in storage and in USB connection it is set to mass sotrage device and not MTP device.
Originally posted by leolas View PostUsing this Rom since you give the link and no mayor issues with it, only one time I didn't wake up the device, I use an air mouse (ipazzport) and I had to unplug usb transmitter, and plug it again, the stick waked up, I didn't report it cause it happened only once and though it was a battery problem in air mouse, but now I see more reports concerned to that...
Thanks.
Jim
XT907 Tapatalk II
Originally posted by Finless View PostSo when you try to click and slide the unlock slder over to the right, what happens?
It happened to me twice and since then it's gone. Can't recreate the issue.
Situation when going into sleep mode: desktop/home screen
What happened was that I would wake the device by clicking on the flymouse and then slide the unlocker to the right in order to unlock. From that moment the television went into blue screen, meaning that it doesn't detect any input.
Next time it happens I will try what was suggested earlier and remove and reinsert the flymouse usb stick.
Next time it happens I will try what was suggested earlier and remove and reinsert the flymouse usb stick.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
external keyboard layout selection ? and 1080p Question
Hello Bob,
thanks for sharing the ROM !
Up to now my only grief is that i cannot change my external keyboard layout, is there an app for this ? (unable to find one myself).
I am German so my layout is quite different from the usual US layout...
720p version looks fine, but for me 1080p is a must.
Will you also supply a 1080p kernel (maybe one where you can hardwire the Res like Omegamoons kernels). ?
If NOT, which of the 1080p kernels out there do you recommend ?
Thanks, i will report further findings...
Ender
Originally posted by Finless View PostEasy fix and this is not a ROM thing. Go into MX player settings>display>touch controls> and increase delay for hiding the menus.
Tried this, but unfortunately doesn't fix the issue. The issue is: When nav bar shows, no problem regarding showing info when left clicking. When nav bar hidden, information shows a fraction of a sec when left clicking.
I changed the delay from 2 to 4 and to 8 secs. worked fine with nav bar showing, but no change when nav bar hidden (showes only a fraction of a sec).
As you point out it's not a ROM thing, I asume this only happens to me. Any other users recognize this behaviour?
Originally posted by leolas View PostThanks, but that was not I want to say, I can't use adb with this Rom. It's not a big problem but I don't know why I can't do that.
I'm not the lowest of the low, but I am the slowest of the slow (49.6 mpg over 38k miles in Scion xB)MK808 w/Omegamoon kernel, CWM recovery, & Finless 1.7 ROM
ARe you set for auto hide the status bar? Or are you hiding it manually using the down arrows?
Are you running any other hide bar app or something?
ADB:
Guess what, Using Kiz kernel version 4 on my MK808 ADB will not work!
Are you guys that have trouble with ADB using some other kernel?
There are currently 1916 users online. 0 members and 1916 guests.
