No BT modules will work! At least none I have found.
I bought several of them to try and make BT work. The common one is based on the Cambridge Silicon chip set.
Now way back on Gingerbread OS I was able to get BT dongle support working. Alas since ICS, I have been unable to figure out how to make it work! Even with custom Kernels and BT drivers in the kernel we still cannot get it to work! There is some magic somewhere I have not found to make it work. I know CM10 has it working "somewhat". e.g. it works but is unreliable on Rockchip. But for standard AOSP ROMs, we all so far have been stumped on getting BT dongles working.
Oh, one thing I did find is this is related to the hciattach binary in /system/bin. Seems since ICS this binary is compiled to support on chip BT which is possibly why it wont work with BT dongles. Someone with a lot more knowledge of what hciattach does will need to work on this.
Originally posted by Finless View PostNo BT modules will work...
PS: (for example in last few months it was unthinkable to get GPU acceleration working for linux on Android PC-stick and now some people made it works, it is just shame it takes quite a long time)
Originally posted by svezauzeto View PostToday i am arrived mk808 from dealextreme, now i want flesh finless rom, how do I know if I have a copy or the original?
mabye read this post started by Finless
Anyone?
Originally posted by tocaazul View Post
Congratulations Bob. Now yes I am making the most of my MK808, running 100% functional. Amazing this new ROM 1.7 ...... I installed your Rom 1.7 + kernel Kizs v2 1.5 ghz = WONDERFUL!!
Hugs from Brazil !!!
Carnival!
NEW - MK808 "all models" Finless 1.7 (Beta is over)
Originally posted by joe9003 View PostYour 1.7 ROM + kiz kernel + lewy's XBMC add on pack has finally made this rubber stick a worthy android TV
thank you very much for all the time spent.
Originally posted by matobj View PostWhat is lewy's xbmc add on pack? Download link please
http://www.freaktab.com/showthread.php?4021-cwm-recovery-zip-for-the-new-libstagefright-so&p=54888#post54888
http://mirrors.xbmc.org/test-builds/android/
I don't have the link for AdvanceSetting.apk Sorry!
@Joe. Please correct me if I am wrong.
Re: NEW - MK808 "all models" Finless 1.7 (Beta is over)
Originally posted by wikings1 View PostWhere to find kiz kernel
From my daycruiserREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by dark_angel View Postlibstagefright.so Patch by leolas + AdvanceSetting.apk + hwaccel built of XBMC IMO
I've removed the unwanted junk and kept the xbmc folders and settings.
Sent from my HTC One S using Tapatalk 2
Guest
Originally posted by Gasp View Post1 - Cursor press doesn't equal touch screen press in most games => most games don't even register cursor - still can play some games with rkremotetool on your android phone (but it is shitty that you can't see what are you pressing) - even G sensor works
2 - What the?
Hi Gasp, thanks for your help ! Actually I didn't know mouse left button was not the same that a touch screen press, so I tried rkremotetool and worked like a charm ! So thanks for your help.
Now, I have another question, I have a MS Wired joystick that works perfectly, but I tried a lot of things and no matter what, MS Wireless joystick doesn't work that good... I copied file 0291.kl (not sure if the file name is right) to 0791.kl and followed several suggestions I found but no matter what, not all buttons work (digital pad for example) and in all games I need to reconfigure controls (they don't match wired version, they have diferent names for each axis and/or button). The only thing I fixed is the spin problem.
Any ideas or suggestions ?
Thanks.
Originally posted by Mopheus View PostHi Gasp, thanks for your help ! Actually I didn't know mouse left button was not the same that a touch screen press, so I tried rkremotetool and worked like a charm ! So thanks for your help.
Thanks.
PS: android should contain gamepad support in future. For example that apps would detect it and optimize some games to work like with xperia play and some official generic mapping app from google would be nice too...
There are currently 2799 users online. 0 members and 2799 guests.
