    Yeah, I agree... some games are much more impressive now and it's becomming a very cool gaming platform, but without a more cool gamepad support, it's quite hard to do it. I like some games controls, but none of them match a real joystick
    Anyway, it's really strange that Wired joystick works perfect (in games that supported like Dead Trigger) and it's all messup in Wireless version... they are almost the same joystick, just with or without cable ! lol !
      Originally posted by Gasp View Post
      ...I use DualShock3..)
      What version are you using, wired or wireless?
        Well Dualshock is kinda both... It works perfectly on my phone via BT mapping with sixaxis tool, unfortunately i haven't been able to get it working anyhow decently on PC-stick, because it doesn't have BT and sixaxis for some completely retarded reason doesn't support mapping dualshock over USB... (OH GOD WHYYY?!?!)
          The proper spelling is "KIZS". Funny Hungarian names ...
          Originally posted by wikings1 View Post
          Where to find kiz kernel
          From my daycruiser
            Originally posted by joe9003 View Post
            Basicly yes but I've made some edits to his installer script so you can do every thing with adb from your pc and it's all automatic.
            I've removed the unwanted junk and kept the xbmc folders and settings.
            Sent from my HTC One S using Tapatalk 2
            Would you mind sharing your "tweaked add-on" package with us!
            TIA
            DA
              Has anyone had success swapping the internal and external flash? I filled up the nand very quickly and really need to be able to flip these around. Changing the vold.fstab seems to have zero effect.
              Other than that, everything else works great on this ROM.
                If I have installed the wrong ROM on my MK808. What would happen to the wifi?
                Because I just installed 1.7 for my MK808B and wifi is "Authenticating..." and nothing more
                It did work on the Stock ROM.
                Is this is sign I have a clone? Thanks, Greg
                  post deleted
                    I opened up the MK808B as shown here (http://www.freaktab.com/showthread.p...-identify-them)
                    It is indeed the "original" one.
                    I install the ROM again I guess, maybe the wifi problem disappears.
                      Re: NEW - MK808 "all models" Finless 1.7 (Beta is over)
                      Try to delete the connection in settings/WiFi and restart route an try again
                      My devices:
                      Gearbest.com)
                        Yes sure, I tried it. Nope. I reinstalled the ROM but still the same.
                        OK, next step: I'm going to try out 1.6a.
                          Love the ROM, but quick question.
                          Is it just me, or is the device (808B) unable to shutdown? Everytime I shutdown and unplug the device, the reboot will freeze. How are you guys "shutting down" and rebooting your devices?
                            Thank you Bob for this great ROM.
                            But think the image (colors) is too bright.
                            Can we adjust the brightness and contrast of colors?
                            Sorry for my bad english.
                            and this keyboard do not help.
                              OK, didn't work on 1.6a either. I changed my Wifi encryption to WEP and it worked. Well now I will add a MAC filter to make it a little safer until my USB-to-RJ45 adapter arrives.
                                I have a mk808b and havent this issue. Try a clean reinstall.
                                Not so bright for me, but I supose you can adjusy your tv.
                                I have wpa/wpa2 with tpk and no problem maybe router reconfigure can help
                                My devices:
                                Gearbest.com)
