Re: NEW - MK808 "all models" Finless 1.7
Originally posted by tsipizic View PostFinless, thanks for great rom. Could you please include the new libstagefright in your next revision with wifi fix because it is a pain putting it afterwards with ADB. Thanks.
REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by leolas View PostYou can use the zip by cwm too.
http://www.FreakTab.com/showthread.php?t=4021
Originally posted by Finless View PostIt is in settings>display>sleep
Never is at the top of the list.
However, someone if you read several posts above, someone installed something that took away the never setting. I do not know what that was and he never explained it. If you do not have never, then somehow you lost the setting. It is there in my ROM.
freeze when wake up from sleep mode
Originally posted by leolas View PostYes I usually put in security option lookscreen in disabled, and in WiFi policy sleep never.
I flashed the fresh finless 1.7 on my MK808B.
I encountered strange freeze with the following condition.
Sleep set at 1 minute
When I touch my RC keyboard the TV screen open with the main screen,
Slide the lock to open.
After few touch on the keyboard it freezes.
( note :wifi advance setting keep wifi ON during sleep = always)
Observed with wifi indicator is gray.
Hope you can advise.
thank you in advance
rico
Originally posted by vlevi View PostI do not have the "never" option in the display settings. However, in the developer settings menu, you can use the "screen never turns off while charging" option. But sometimes, this checkmark disappears.
Cheers
Originally posted by neodoom View Postis this firmware compatible with mk802iiis bluetooth version?
Originally posted by Finless View PostUPDATE March 09, 2013:
Some people reported wifi slow down on the MK808 Original (non-B) with 1.7. Turns out I forgot to patch the wifi stuff like I did in 1.6. So I made a new 1.7a that is reported to have fixed this wifi slowdown. The download links below have been updated.
Note: This was NOT an issue for the MK808B or Sunvel clone!
Enjoy,
with 1.6 wifi= 4mb Download max
with 1.7 wifi=1mb Download max
with 1.7+OmgK = MAX Download
Originally posted by vaha View PostYour ROM 1.7 with omegamoon's kernel have wifi best signal and speed ever.
Originally posted by exglynco View PostTrue. I've done the antenna mod on my MK808 and on three MK808Bs. None have shown any wifi speed differences between 1.6, 1.6a, 1.7, and 1.7a ROMs.
The wifi antenna mod is something I should try, and sounds like something I would do, but the weird thing and the reason why I haven't done it is, my wifi is only slow on 1.7 (and 1.7a) I've tried 1.5 and 1.6 and wifi is fast, I tried stock roms and wifi is fast, that's why I don't think its an antenna issue...
Originally posted by niabi View Postcan you please tell me how you installed omegamoon's kernel ? every time I try that (or Kizs's kernel) I end up in a boot loop
Post # 16 on this thread. All credit goes to Leolas
Originally posted by niabi View PostThe wifi antenna mod is something I should try, and sounds like something I would do, but the weird thing and the reason why I haven't done it is, my wifi is only slow on 1.7 (and 1.7a) I've tried 1.5 and 1.6 and wifi is fast, I tried stock roms and wifi is fast, that's why I don't think its an antenna issue...
Except for the kernels compiled by me :banghead: no way to make rk903 works :P and I am triying.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by dark_angel View Posthttp://www.freaktab.com/showthread.php?4023-Do-you-want-to-flash-your-rom-using-cwm-recovery-take-a-look-here
but using omegamoon's kernel causes freeze after 1-2 min
There are currently 2064 users online. 0 members and 2064 guests.
