Hi Bob,
I have a MK808B sunvell clone and just flashed it with Finless 1.7
Everything work like a charm and I feel the application getting faster than the original ROM one.
But 1 thing that I found that I got this blank display issue after using it for some times. :S
Do I need to provide you something for investigation?
Thanks, and great job !
Is there a way to see the mk808b as a tablet to play store? because I can not find applications such as: Videomediaset HD etc ...., if I use smartphone applications are not displayed well (I think problem between landscape and portrait).
It could usabe fingerprints of tablet 1280x720 (800) in place of that for gt-9100 (which is a smartphone).
Originally posted by niabi View Postcan you please tell me how you installed omegamoon's kernel ? every time I try that (or Kizs's kernel) I end up in a boot loop
Omegamoon kernel
Use Finless 1.7 update tool/folders just use zImage_HDMI_720p.img rename to kernel.img and put in
..\MK808 Finless 1.7 ROM\FinlessROM\ folder overwrite existing kernel.img file
Run ROM Flash Tool.exe uncheck all except kernel.img. Flash.
Re: NEW - MK808 "all models" Finless 1.7
Originally posted by Mandrake2 View PostIs there a way to see the mk808b as a tablet to play store? because I can not find applications such as: Videomediaset HD etc ...., if I use smartphone applications are not displayed well (I think problem between landscape and portrait).
Sent from my rk30sdk using Tapatalk 2
Thanks for reply. try changing the build.prop
I pulled the last rom for MK808B (rk903) from geekbuying: update_mk808b_box_401j1.img, I extracted the rom with "RK29xxImageTools_v2.1" and I see that the bootloader is RK30xxLoader (L)_V1.22.bin and also parameter is different by Finless.(change partition)
If I try to flash this rom, then I can return to Finless? or there will be problems with the bootloader (in the finless is 1.16) and the size of the partitions?
Thanks in advance.
Timingpower RK3066 Mini PC
Just an FYI - As I posted before, I got a Timingpower RK3066 device:
I installed the Clockworkmod MK808 version on it, and subsequently used the CWM method to install the MK808B Finless 1.7 ROM.
At this point, it appears that everything is functioning. I have tried WiFi, Bluetooth, and CIFS mounts, and everything is in order! This ROM has greatly improved the experience! I used boot720p.img, btw.
One thing I am missing out on is the re-partitioning reallocation of some of the internal /sdcard space to /data. If anyone knows how to re-partition this space via a CMW installable zip, please do share!
Thanks!
Originally posted by vaha View Postdownload this:
Omegamoon kernel
exactly what I do and it always = in a bootloopI am starting to think my device is to blame :P although 2dar4u kernel works perfectly
Thanks!
Originally posted by Finless View PostIt's not possible. Only a NAND erase and flash from the flash tool will change the partitioning of NAND.
EDIT: I just flashed with RKTools and partitioning worked fine. Internal Storage is now 1.97GB and NAND FLASH is 685MB. This rocks! Now to try restoring my data backup w/ CWM.
Thanks Bob!Last edited by long2know; 11 March 2013, 21:46.
Originally posted by svezauzeto View PostCan someone give me a link for kriz kernel 720p? I search on google but dont find. I have Sigma webcam, and work only mic, not video, maybe with other kernel work and video.
I have one question for bob...
I'm Just currious but wouldn't be easier to make one roms for all 3 variants of mk808(b)(fake) with drivers for all hardwares in the same roms, than make 3 roms every time?
Envoyé depuis mon CJ ThL avec Tapatalk
There are currently 1876 users online. 0 members and 1876 guests.
