Pipo U1 Pro RileyROM 1.0
    Re: Pipo U1 Pro RileyROM 1.0
    Sounds like a good plan.
    Sent from my M8 pro
    Randy
      Thought I had bricked it when I saw your new splash logo on boot... It's distorted for a little while, then it is fine, but rotated 90* like portrait.
        That's strange. I thought I used the same splash I used last time.
        I didn't brand the kernel yet.
        What is the resolution?
        Randy
        Randy
          Device resolution is 1280x800.
          Your original splash was a badge with freaktab written on it. This one looks like a star trek kinda thing with a pulsating red light and pipo u1 pro written up top zooming in and out...
          Also, fwiw, when I erase nand, it counts to 4096, not 2048.
            Try this...reflash using the parameter file from my first Rom.
            Randy
            Randy
              Also, only getting 1 gig of internal storage with this one. Bluetooth is working now though.
              Tried old parameter file, still said 4096 on nand wipe ( realizing these probably aren't related), flashing rom now.
              EDIT: Noticed several parameter text files that are in this zip that werent in the last one.
              Storage is fixed now with that parameter file, at 2 gigs.
                Sounds like I need to do some new parameter files from the stock ROM.
                It will be later...going out to eat with my family. Once I get started it will be quick. I have to reboot my PC into Linux to grab that file...but I'm downloading two new firmwares for other tablets in Windows right now. It's all quite a process.
                Sent from my M8 pro
                Randy
                  Sent from my M8 pro
                  No worries, I'm getting ready to leave myself to go get dinner and do some lawnmower repair for a friend. Thanks for your help today, and I look forward to whatever you have in store next.
                  Cheers
                    OK, here is a complete ROM kit that is updated.
                    I made all new parameter files and branded the kernel.
                    Download
                    Randy
                      Download
                      Great! I'll give it a shot tomorrow.
                        I'm a little delayed, might be a day or two longer. I'm testing some android apps for a couple of devs at the moment, so I didn't want to wipe the tab just yet.
                          No problem. Take your time.
                          Randy
                          Randy
                            Randy
                            I flashed 1.1...
                            It was only 1 gig app partition, and also, same deal with the splash screen.
                            Kernel version says 3.0.8+ root@lzj-desktop #201
                            SMP PREEMPT Sat Dec 29 16:00:10 CST 2012
                            Version says Build number RK30_ANDROID4.1.1-SDK-v1.00.00
                            I think we had better results making the change with 1.0 - also, was this supposed to have the updated framework jar?
                            here is the splash screen:
                              Ok I'll look at it.
                              The boot animation must be the wrong size. Does it go ahead and boot after that?
                              Randy
                              Randy
                                Ok I'll look at it.
                                Randy
                                Yes, it boots.
                                Here is the order... on power up...
                                1. messed up display (imagine crt when refresh rate is wrong)
                                2. image you see that I pasted
                                3. android
